View Full Version : Mann Hummel Pro Vent Plumbing
whitepark
01-10-2020, 01:49 PM
I have a 416 LS3 in my Camaro. Dart block and heads, Holley throttle body injection - 600hp. Currently the engine vents into a firewall mounted catch can (see catch can beside a/c firewall lines), with vent hoses plumbed off the back of the thick spacers which sit between the engine block and coil / valve covers on both banks, and thus both sides of the engine feed into the vented catch can - venting to the atmosphere.
I'd like to go to a Mann Hummel closed vent system, draining back into the sump and I am seeking plumbing advice.
Is the plumbing as simple as taking the existing hoses from each bank and plumbing them into the Mann Hummel Pro Vent 200 can; plus routing the Mann Hummel drain vent into the LS3 sump?
parsonsj
01-10-2020, 06:45 PM
that's some nice plumbing! Love the vent on the upper radiator hose.
dhutton
01-11-2020, 05:23 AM
No it is not if I understanding you correctly. You need an inlet and an outlet, not two inlets. I would think you also need a source of clean air.
Instructions are here.
https://oe-products.mann-hummel.com/fileadmin/user_upload/kataloge/kataloge-wartungsanleitungen-mann%2Bhummel/kurbelgehauseentlueftung/ProVent_en.pdf
Don
whitepark
01-11-2020, 11:36 AM
Thanks for the advice and the link Don
CarlC
01-14-2020, 10:05 PM
............and to add on to what Don says, a PCV valve.
dhutton
01-15-2020, 08:25 AM
Thanks Carl. I’m so used to using the stock valve covers this never occurred to me.
Don
whitepark
01-15-2020, 08:38 PM
Thanks Carl
