View Full Version : C-clip eliminator
Shotaro
01-09-2020, 06:59 AM
Is cーclip Eliminator suitable for Auto cross? Is there a risk of the shaft coming off?
I want to improve my Camaro brake knockback.
171555
CSG
01-09-2020, 09:47 AM
They don't do well with side loads leading to leaking. Will they even help with knock-back?
GoodysGotaCuda
01-09-2020, 05:02 PM
A more robust solution is to convert to sliding calipers. I just wish there was an easy way for me to do it with my Wilwoods.
vette427-sbc
01-09-2020, 06:31 PM
Moser specifically states no road racing or auto cross with their eliminator kit
TheJDMan
01-09-2020, 08:01 PM
The C-clip eliminator is simply NOT adequate for autocross. A better solution would be to install big ford ends on your housing. They have tapered roller bearings which can take a side load. But by far the best solution would be to install a set of Baer floater hubs on your housing.
http://www.superchevy.com/how-to/chassis-suspension/1903-installing-baer-floater-system-on-9-inch-rearend/
Skip Fix
01-12-2020, 09:37 AM
Strange does have a C clip elimin kit that does use the same taper bearings as the Ford 3.150s.
djorgensen3
01-12-2020, 10:25 PM
Here is the Strange kit he was mentioning:
https://www.strangeengineering.net/product/small-gm-elim-kit-for-strange-axles-at-1-7735-pr.html/
