    Results 1 to 10 of 10
      Dec 2019
      68 Chevelle Wheels & Tires Concern, help!!
      Hey guys, I have a 68 Chevelle SS Convertible that I want to change my wheel and tire package on. I want to go to a more of a pro touring look. Thinking about running 19" in the rear and 18" up front. The rear isn't tubbed and the lips aren't rolled. A particular set of wheels I was looking at was a 19x10 with a 8.45" backspacing and 18x8.5 with 6.72" backspacing..would that work? What's the biggest tire I could fit? Also I posted a pic of the car incase you have a wheel in mind that would look awesome, thanks!
Size:  94.0 KBName:  1576797206938_20191219_180625.jpg
Size:  97.2 KBName:  hAR9249-1024x958.jpg
      Oct 2018
      San Jose, CA
      That’s way too much backspacing for a factory chevelle chassis.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      May 2010
      kitchener,Ontario,Canada
      Is the car lowered and do you ever have people in the back seat .?
      Ryan Austin
      On Instagram ryanaustinss70
      Dec 2019
      Car is lowered with coil over suspension front and rear. I do plan on people sitting in the back occasionally.
      Dec 2008
      Detroit
      6" of backspacing is probably the most you would safely want to put on that car without measuring, anything else I would use a wheel fit tool first.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      May 2010
      You might be able to get a 305 in the back , problem with 68-72 A bodies is how fast the wheel well gets narrow , if you follow what I'm saying
      Ryan Austin
      Dec 2019
      Think I found the wheel I want. 18x10 in the rear but they offer, 5", 5.5" and 6" back spacing. I want to run a 305 35 18. What back spacing would work?
      May 2010
      5.5 might ... do some home work on the site here theres enough threads about it with the info again the biggest issue is the rear wheel wells once you lower and or add load aka passengers and the suspension compresses you will rub . If I recall correctly you should be able to do a 305 . Again do some homework and remember not all 305s are the same width . I'd look for a narrower one if possible . Good luck
      Ryan Austin
      Dec 2019
      Everyone I'm finding who runs an 18x10 with a 305/35/18 had around 5.75" of backspacing. So the 6" I think would be better, correct?
      May 2010
      I believe the most you can run is 5.75 . So unless you find a rim with that offset I'd say no to the 6 inch
      Ryan Austin
