Results 1 to 6 of 6
Thread: 18 x 8 1/2 on 69 Camaro front?
12-26-2019 #1
- Join Date
- Jan 2005
- Location
- Benicia CA
- Posts
- 29
I'm looking for new wheels for my 69 Camaro. I currently have Billet Specialties Ventec 17 x 8 with 4 1/2 backspace and 235/50x17 Bridgestone tires all around. The car is lowered with ridetech coilovers in front and Hotchkis with 1 inch lowering blocks in rear. Ground to bottom of fender lip is just under 24 inches front; 24 1/2 rear. I run negative 1/2 degree camber in front to stay away from the inside fender lip due to the 4 1/2 backspace; it should be 4 3/4. The inside of the fender has been "clearances" with a hammer and the top fender bolts removed. It still rubs occasionally. Rear clearance is fine.
I'm looking to go to 18 inch wheels. I'd like to go 8 1/2 wide in front. Is anyone running a 8 1/2 wheel in front? What backspace are you using? My subframe is stock with ridetech strong arms and coilovers.
Thanks for any input.
Joe
Joe G
69 Coupe; ZZ430;TKO 600 5 speed; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Ride Tech Strong Arms and coilovers front; Classic AutoAir AC and power windows now cuz I'm old and lazy!
12-29-2019 #2I installed a Ridetech Tru-Turn front suspension with coil-overs on my 69 Camaro, I’m very happy with the results. I contacted Ridetech on Wheel sizes and they sent this back:
Ridetech Wheel Size
Keep your offset as close to +6mm on a first gen as possible and that should center the wheel between the subframe/fender and the frame rail/quarter panel as possible.
Ideal backspacing for maximum clearance is as follows:
17x7 = 4.25"bs
17x8 = 4.75"bs
17x8.5 = 5" bs
17x9 = 5.25"bs
17x9.5 = 5.5" bs
Wheel diameter is irrelevant, it's the same for any 17"/18"/19" wheel.
12-30-2019 #3
