Results 1 to 3 of 3
12-20-2019 #1
- Join Date
- Sep 2010
- Location
- Germany
- Posts
- 40
which way to go---Studs Adapters and BMW Wheels question
I play with idea to change to bigger studs in conjuction with adpter or a spacer but not sure which was the best solution...for me.
Car would be a 90% Street car ( 65 oLDS with BMW 4,73"--120mm bolt pattern wheels) with only a few laps here in Germany in the year at the track -but maybe with some semi slicks in the future.
At the rear - SOLUTION 1. - corrected the bolt pattern but use the stock studs from the axle flange
new Studs 7/16-20" ---> 1" thick custom billet Adapterplate which convert from GM(120,65) to BMW (120) pattern ---> and the BMW Wheels bolt to adater with M12x1,5 or M 14 x1,5 Bolts or Studs
At the rear - SOLUTION 2. - use the stock GM bolt pattern but with thick studs
Long 1/2" Studs ARP/Moroso ---> 1" thick spacer ---> bolt the BMW Wheels with lug nuts ( maybe exended version?)
I read this about the Adapter -which convert the bolt pattern
They MUST be double hub centric. Meaning the spacer centric on the hub and the wheel centric on the spacer
Is this correct?
