hotroddr
12-15-2005, 11:15 PM
I have searched and searched and found nothing. Is there a universal joint that will eliminate the stock rag joint on my 68 firebird? Or is it accepdable to run the rag joint at an angle? Thanks!
-Dennis
andrewb70
12-16-2005, 06:43 AM
Try Flaming River. They will have a needle bearing U-joint that will work.
hotroddr
12-17-2005, 04:22 PM
I took the steering column out but I cant see how the fitting on the column is supposed to come off...there are no bolts and I cant pry it off. Am I missing something here? i am reluctant to bust out the torch for heat. Should it just slide off the column shaft or is it connected?
