View Full Version : LS Oil Pan Buyers Guide
lsswapguide
10-23-2019, 06:37 PM
Preface: Just wanted to make something nice for this forum of which i've used countless times. My background is taking lots of random data and attempting to turn it into usable formated data. I have collected this information from all over the web in a attempt to help people out when looking for the proper oil pan for their applications. If you see anything wrong please let me know because I'd like it to be correct.
Below are proven pans that work with the given application.
64-72 A-Body - Holley 302-2, 302-3, Mast Retro Pan
68-74 X-Body - Holley 302-2, 302-3, Mast Retro Pan
67-69 F-Body - Holley 302-2, 302-3, Mast Retro Pan
70-79 F-Body - F-Body Pan
60-72 C-10 - Truck Pan Normal to 2/4 Lower, for 4/6 to bagged use a Holley 302-2/3 or F-Body Pan
168564
Holley 302-1
Vehicles: Various GM muscle/classic car and truck chassis
Capacity: 6.2 quarts
Oil Filter Thread: M22 x 1.5mm
Part Numbers & Links
GM Part Numbers & Links:
Oil pan: Holley 302-1 - https://amzn.to/2B5G1ZF
Pickup tube: Supplied with the pan.
Windage tray: 12611129 - https://amzn.to/31CK3n7
Dipstick: 12634547 - https://amzn.to/2MESVDz
Dipstick tube: 12625031 - https://amzn.to/33r5zNa
Pickup tube o-ring: 12557752 - https://amzn.to/2phqmnk
Gasket: 12612350 - https://amzn.to/2q3R03y
168565
Holley 302-2
Vehicles:
LS Swap A/F/X Body Cars
LS Swap Bagged C10 Trucks
Oil pan: Holley 302-2 - https://amzn.to/35waePK
Windage tray: 12558253 - https://amzn.to/2F2oDAln1
168566
Holley 302-3
Vehicles: More Clearance in the Steering Area and Has and oil return bung casted in.
168567
Mast Motorsport LS Swap Oil Pan
Vehicles: - Has built in sump baffling
Premier Pan Anything Stroked Road Raced
Comes with baffle cast into pan
Capacity: 6 quarts
Oil pan: Get Pan Here. - https://amzn.to/2pjrxCU
Windage tray: 12558253 - https://amzn.to/2oDAln1
Dip stick: 12551581 - https://amzn.to/2M8R6iU
Dip stick tube: 12551577 - https://amzn.to/35vnfJp
168568
GM Muscle Car Oil Pan (H3 Hummer)
Vehicles:
H3 Hummer
Capacity: 5.5 quarts
Oil Filter Thread: Post June 2007 M22 x 1.5mm, Pre June 2007 13/16"-16
Full Kit: 19212593 - https://amzn.to/2B4QOU0
168569
GM Truck / SUV Oil PanVehicles:
1999-2014 Chevrolet/GMC Full Size LS V8's
1999-2006 Drain in the rear
2006-2014 Drain on the side
Capacity: 6 quarts
Oil pan: 12640746 - https://amzn.to/2VDCmfc
Pickup tube: 12608579 - https://amzn.to/33pKZN6
Windage tray: 12611129 - https://amzn.to/33rhVVm
Dipstick: 12622055 - https://amzn.to/2Ma6g7L
Dipstick tube: 12609269 - https://amzn.to/32cLGsO
168570
GM 1998-2002 F-Body LS1 Pan
Vehicles:
1998-2002 Chevrolet Camaro (5.7L V8)
2002 Pontiac Firebird (5.7L V8)
Oil pan: 12628771 - https://amzn.to/2M8mDSf
Pickup tube: 12558251 - https://amzn.to/2BcmiHH
168571
1997-2004 C5 Corvette
Vehicles:
C5 Corvettes
Capacity: ?
Oil Filter Thread: ?
Oil pan: 12561828 - https://amzn.to/2OG4E7d
168572
GM 2006-2013 C6 Corvette LS2/LS3 Pan
Vehicles: 2005-2013 Chevrolet Corvette (non-dry sump)
Oil pan: 12624617 - https://amzn.to/2ILqdzt
Pickup tube: 12624497 - https://amzn.to/2MEjRTR
Windage tray: 12558189 - https://amzn.to/2MbeYmg
Dip stick: 12570788 - https://amzn.to/2B5Hz6b
Dip stick tube: 12570787 - https://amzn.to/31781a4
168573
GM 2010-2015 LS3, L99 Camaro / G8 / SS Oil Pan
Vehicles:
2010-2015 Chevrolet Camaro SS
2008-2009 Pontiac G8
2006-2017 Holden VE Commodore / Chevy SS
Capacity: 8 quarts
Oil pan: 12640748 - https://amzn.to/2q8OuJw
Pickup tube: 12611904 - https://amzn.to/2B98AWm
Windage tray: 12611129 - https://amzn.to/2oAp3zW
168574
GM 2004+ LS2 / LS6 / LSA Cadillac CTS-V Oil Pan
Vehicles: 2008+ Cadillac CTS-V (2004-2007 oil pan is nearly identical)
Capacity: 6 quarts
Oil pan: 12631828 - https://amzn.to/31cmYHE
Pickup tube: 12621299 - https://amzn.to/2oB8NPi
Windage tray: 12611129 - https://amzn.to/2oB8ST6
Dipstick: 12584737
Dipstick tube: 12584738 - https://amzn.to/2q8QrWm
168575
GM 2004-2006 Pontiac GTO Oil Pan
Vehicles:2004-2006 Pontiac GTO
2001-2005 Holden Monaro (VT-VZ)
2004-2006 Holden Commodore (VT-VZ)
2001-2005 Vauxhall Monaro
Capacity: 6 quarts
Oil pan: 12581209 https://amzn.to/2IJAqwg up to 2004; 12599397 2005 and later. Difference between part numbers is the newer model has a built-in pressure relief valve.
Pickup tube: 12572654 - https://amzn.to/2MxyisK
Windage tray: 12558189 - https://amzn.to/32c4msT
Dipstick: 92067147
Dipstick tube: 92066941
168576
GM SSR & Trailblazer Oil Pan
Vehicles:
SSR
Trailblazer
Capacity: 6 quarts
Oil Filter Thread:
Oil pan: 12579203
Snowcatter
10-27-2019, 06:20 AM
Great info here. Thank you for taking the time to put this together.
Alwhite00
10-27-2019, 08:15 AM
Thanks for the post, great info.
ORBandit
10-30-2019, 04:26 AM
70-81 F-body, the LS1/98-02 pan works best. The Holley and GMPP hang way too low.
Josh@Ridetech
10-31-2019, 01:10 PM
I can confirm the 4th Gen F body pan works flawlessly on a '79 Firebird/Camaro. I'm using clamshell motormounts and Holley/Hooker motor mount brackets.
Hooker Blackheart engine mount brackets - Part # 12613HKR
Factory clamshell mounts - I used Anchor brand ones, part # 2292
Clearance on the pan is great.
lsswapguide
10-31-2019, 05:55 PM
I’ve updated it.
lsswapguide
10-31-2019, 05:56 PM
I updated the info, thanks!
Josh@Ridetech
10-31-2019, 06:02 PM
Anytime! Thank you for the informative post!
