    Results 1 to 6 of 6
    Thread: Wheel/tire help
      Socal, Ca
      Wheel/tire help
      I need a beat up factory set of 17" rims/tires that will fit the 67 camaro. This set will be used while I take the car from place to place. I need 17's because the car will be receiving bigger brakes, UCA, LCA, and mini tub. Will rims/tires from a 98-02 camaro fit? Will the 93-97 fit?
      Thanks for the help, David
      FYI: The final set of rims will be 18's all the way around
      Jun 2002
      Long Island, NY
      93-02 F-body rims will fit, with some spacers. You'll want either SS or WS6 wheels, as the Z/28s came with 16s and I think the T/As did too.
      Socal, Ca
      Ralph,
      what is your best guess for the spacer size
      Jun 2002
      Long Island, NY
      David,
      Probably around 1.5-2" or so, but I'm not entirely sure. You'd need one of those "adapter" type spacers, though. Do a search if you can, as the spacing may have been covered in a past thread.
      Los Altos CA
      Well if its just for moving around why not find some spares from a car that had big brakes stock, wouldnt haveto bother with the backspacing and much cheaper
      Socal, Ca
      ilovefirstgens,
      thanks, I will look into that.
