View Full Version : 1970 GTO LS Turbo
sennygoat
08-24-2019, 09:03 PM
Hello everyone, my name is Josh and I have a 1970 GTO to rebuild. It is complete but rough. I have torn it down to body, frame and powertrain left. It is a rust bucket. Bought another clean 70 GTO body out of Reno. After spending weeks, slowly realizing rebuilding a Pontiac motor by anyone good will cost a small fortune. I decided to go LS. I am shooting for a $15k budget. I am going to Turbocharge the LQ4 block out of a2005 H2. Its a 6.0L iron block, aluminum head truck motor. I am either going to fully build the motor or leave it stock. Shooting for 500-600 whp. 4l80E trans. Stock rearendwth 3.23s. Will post picks soon.
Ideas:
stock rebuilt 4L80E or stage2-3 but cost is a factor
summit pro LS pistons and rods stock length and bore because boost and thin walls after boring- .005 over max, -12cc dish pistons stock rod length, summit rings
18x8 front wheels, 18x10 rear, 245/40r18 front tire, 275/40r18 rear tire
.550 int/.550 exh cam from jegs
Cam Motion full valve train kit, seals, retainers, dual springs, timing kit, pushrods, etc. or just PAC 1218 springs and stock hardware, with upgraded trunnion kit
stock crank, micropolished
LS6 intake
80mm truck TB
stand alone wiring harness stripped (by me)
80 lb/hr siemens injectors Ev6
flat truck 6.0 flexplate, with spacer/adapter and bolts
corvette 58 psi fuel regulator
450 lph pump with manifold and fittings
EFI tank notched
holley 302-2 oil pan with gaskets and pickup
melling water pump
LS9 head gaskets- on 4.00-4.005 bore block
summit control arms fr/rr, springs, shocks,
s475 turbo
precision turbo 46mm wastegate and 50mm bov
arp head studs
summit stock oil pump
speedmaster fuel rails
summit intercooler
160 deg thermostat
summit sway bars and spindles stock height
CPP or Right Stuff big brake kit
HP Tuner Pro
and probably some things i forgot
Thanks. -JB
sennygoat
08-24-2019, 11:50 PM
I came back to post pics and it I harder than I expected. I guess I am unsure of how to do this haha. I will get pics up though. Any help is appreciated. Thanks- JB
alocker
08-25-2019, 03:42 AM
Its a pretty good start.
A stock 4l80e rebuild with dual feed and recalibration will take you pretty far. Dont forget the converter$$$.
I dont think the vette fuel regulator will work. You need boost referenced.
68Formula
08-25-2019, 02:51 PM
Unless the LQ4 needs a rebuild (and usually they don't), I'd recommend leave it alone. Even on high mileage examples, they show very little bore wear. For the intake, use a Dorman LS2 and a truck 88mm throttle body.
On the wheels, if you're running 245s, you'd be better off with 18x9s. Measure, but with the right offset, you may even be able to fit 255s on the front.
sennygoat
08-25-2019, 07:42 PM
Hey guys, thanks for the info. Keep the suggestions coming. The only thing I have bought so far is the LQ4 and a LS6 intake. Bought the LS6 because of the flow numbers were best for a stock intake other than the tbss intake but it was ugly and I would have had to change some stuff and more moolah!
The LS6 bolts up, uses my existing tb with 3 bolts and after searching for dbw tb's I realized the cost to power increase was negligible, since I am going boosted anyway. Might port match the intake and tb though, who knows. The 4L80E in stock form is pretty stout from all accounts but they are costly for a
beefy built stage 2-4. Think the stocker rebuilt with maybe a little something extra. Any thoughts? Converter I am thinking Circle D or Jakes. For fuel regulator, I chose the corvette because its a filter and pushes exactly 58psi to the rails. You think I should add an Aeromotive reg up front and somehow
tie in a boost solenoid to give the computer fuel reference? Or what did you imply? Finally, the wheels I haven't bought yet, butI am finding it hard to find wheels I like that aren't $2000 a set so I was sticking with American Racing VN510's 18x8, 18x10 because they are cheap, look good, and that's what size they come in. Still may change my mind if I can find some with a 18x8.5 or 18x9. I have read 18x9 up front is doable on my car but difficult and has to be perfect to fit well and not rub. Thanks again. Can anyone recommend a trans shop for the 80e?
