black67malibu
05-13-2019, 02:37 PM
430hp LS3
Tr6060 6 speed/ LS7 clutch
Made 403WHP 398WTQ
Moser Fab9 rear end, 40 spline axles with wavetrack Posi and new 3:23 gears
New-Hooker Blackheart mid length headers
New-Hooker Blackhear 3” mandrel exhaust
New-Griffin radiator
New- Might mouse Motorsports Catch can.
New-accel spark plug wires and Iridium plugs
New-AAW classic update kit installed
New-Dakot digital gauges with OBD11 adapter
New-Vaporworks controller upgraded with E85 sensor and the ability to control Dual dewitts pumps for future HP upgrades
New-ricks restomod tank with Ls9 pump
New-PTFE fuel line
New-brake lines
New-Ididit column
New-12:7to 1 steering box
New-Speedtech front suspension
New-ATS spindles
New ATS bumpsteer kit with PRO FORGERS inner tie rods and center link
New-C5 brakes from Kore3
New-wilwood 4 piston rear brakes
New-EBC yellow pads for manual master
New-15/16 Manual wilwood master cylinder
New-wilwood proportioning valve
New-GT pro touring steering wheel
New-UMI rear upper control arms with rotor joint
New-UMI rear springs
New-UMI rear frame bracing.
Varishock double adjustable shocks
Hotchkis rear lower control arms
New- optima Redtop
New- 18’ Ridler wheels
New-Nitto NTO5 front and rear
Dash is freshly powder coated
Grill, headlight buckets and everything up front powder coated.
The car drives perfect and is all sorted out drivetrain wise. Have a new ACC carpet that will need to be installed.... Due to the larger tunnel, the carped will need to be cut down the middle and have a center console installed, or custom carpet kit. The paint is in great driver quality, but it’s no Barrett Jackson show car. A few things I found that I didn’t like was it used to have a cage in it and I wasn’t to please with the patch panels they installed. Besides that, the floors are in great shape! They also cut out the rear braces for the package tray, but we installed a new setup that I believe is stronger than factory. I also have another frame I will include with the sale. I was going to install the speedtech frame kit and swap it this winter.
Car is located in Gardnerville NV, close to Reno.
Asking 38k OBO.
707-362-6556.
https://reno.craigslist.org/cto/d/gardnerville-1966-chevelle-ls3/6888155380.html
Made 403WHP 398WTQ
New-PTFE fuel line
New-brake lines
New-Ididit column
New-ATS spindles
New- optima Redtop
Asking 38k OBO.
707-362-6556.
