View Full Version : pcm options
1985olds
05-01-2019, 05:16 PM
I know its new and most people haven't received theirs yet. Im putting together an l76/tremec magnum and don't know which pcm to use. Car is a g body and summer daily driver, road trip car. Engine will have a tsp cam and cnc ported heads. I narrowed it down two options:
-Holley terminator x
-psi conversion harness
The cost will end up about the same. I have been weighing pros and cons and have reached a stalemate. I like the ability to run a DBC throttle body with the holley, but don't like the issues wiring the alternator. Also have to figure out the A/C trigger.
I like the idea of OEM simplicity, but feel like I am shorting myself on the flexibility of the holley.
Anyone have any more insight on this predicament?
btmatt
05-02-2019, 06:04 AM
Watching. Working on the same combo in a '57 Chevrolet truck, but like to run DBW. Thanks, Matt
Z06vet
05-02-2019, 10:19 AM
I definitely prefer the DBW vs Cable. I feel tuning the idle stability on a cam'd motor is easier and no AC trigger is needed. If you ever ad cruise, DBW is easier that route as well. The holley seems to be well liked, and has a ton of options and parameters. Do you have a good tuner close to you that can handle the GM ECM? I feel that's important unless you can tune it yourself. IF not, the holley might be the way to go.
1985olds
05-02-2019, 01:54 PM
I have a tuner who can tune the gm computer, but not the holley. I'm torn on DBC vs. DBC, 50 different people have50diffent opinions on that argument as well. I only have DBC, so other than driving various cars at work, I have never lived with DBW. I have thought of the cruise control variable as well. I have cruise right now, but from a separate module. It would be nice to clean up the engine bay and get rid of that box.
1985olds
05-05-2019, 04:36 PM
Why wouldn't I need an a/c trigger with a dbw?
Z06vet
05-06-2019, 04:24 AM
ECM will compensate for the idle.
