View Full Version : Solid Setup?
fortune
04-25-2019, 07:27 PM
This is for my 74 Nova. The purpose is to make it a weekend cruiser and have the ability to go into corners fairly well. In all honesty I pretty much just want to drive my first car ever and not break the bank doing it. Also to give my daily a break from driving 230 miles or so a day to go to work and back. It's a 2018 Accord Sport 2.0T.
My budget for suspension is to hopefully stay under 3,500$ if possible.
Re-weld the whole subframe? I can do it myself
Speedtech Billet Aluminum Body Mounts
1 1/8" front sway bar - many to choose from
Borgeson Quick Ratio Power Steering Box 12.7:1 Ratio
Ridetech Steering kit w/Power Steering
Ridetech HQ Series Shock
Ridetech Lowering Coil Springs - or does anyone prefer different coils
GlobalWest Leaf Spring Reverse Eye 2" Lower - part # L-2R-2
GlobalWest Econo-Track Kit - part #ETK-6769 - not sure if this set haves tall ball joints or not.
Relocate rear shocks maybe? They're staggered from factory if that matters - I can fab up a setup myself.
Stock height spindle or 2" drop?
I'm not sure on brakes yet, but brakes will have a separate budget on them.
cornfedbill
04-26-2019, 06:18 AM
That looks like a good plan.
Do you need to relocate the shocks for tire clearance? If not, there is no real benefit in moving them.
A cheap alternative for a quick ratio steering box is the 1988 IROC-Z box. Lee sells adapters for the hose fitting flares. You can get a rag joint to adapt the steering column to the newer IROC box. I purchased my box from Advance Auto Parts. It bolts right in.
I would look into stiffer frame mounting bushings. The stock ones are likely shot unless they have been replaced. You may want to consider solid mounts.
For brakes, is there a reason you need anything more than the factory 11 inch discs and good pads, like some Hawk pads? New rotors and good pads should do a lot for braking. If you want more, Kore3 (http://www.kore3.com/) has several nice retrofit options for front brakes that are only limited by your budget.
EODtech
04-26-2019, 08:46 PM
I have Global West L2 leaf springs with their bushing kit and I'm real happy with them. I also have a remanufactured IROC box and was very impressed with the bang for the buck I got by installing it. So far for the front I have some coil springs recommend by David Pozzi on his website and 2" drop spindles. Works well for a street car, but I definitely need better shocks.163817
fortune
04-27-2019, 11:40 AM
cornfedbill
My idea/plan is to try to do a square setup so I gotta see what's the max tire size, i'll be running 18" wheels, I can fit on my car after everything is done and IF the rear shocks is in the way to achieve it I'll do it but that'll be towards the end.
I believe there is a thread on it and even in fact I sub to it
Yes mine are definitly shot, gonna use speedtechs body mounts.
My car came with factory drums on 4 corners so I gotta convert over to disc. Trying to find a good kit, and yes I know there are quite a bit out there but whois the right one to go with, or maybe piece one together myself. I'll check out kore3 though.
