Results 1 to 4 of 4
Thread: 69 Camaro Kick Panel Vent Delete
03-29-2019 #1
- Join Date
- Sep 2016
- Location
- LA - Lower Alabama
- Posts
- 560
Does anyone make kick panels that block off the vents? I’ve added AC, and I’m working on sound deadening as well. I’d like to block off the vents, but I want to make sure they don’t leak, either.
Dude are you made of leprechauns? Cause that was awesome!
03-29-2019 #2
- Join Date
- Jan 2018
- Location
- Saint Louis, Missouri
- Posts
- 86
I would see if there are any plastic or steel plates that could be secured and sealed to the oval opening with the kick panels off to where once they are in place you can do some water tests to check for things being sealed up and then address any issues and then put the plastic panels in place. Maybe look at cars that are close to your kick panels like on a 73/74 Nova with factory AC and on those the driver's kick panel has no openings on it and on the passenger side, with it's opening for fresh air maybe be able to fabricate a cover over the oval opening or keep in place the curved molded cover to hide the oval opening.
I don't know where you are at with things are what you are working with but maybe reach inside the oval openings and clear out any debris that might have gotten built up in the lower cowl side and flush out the area as well as the rocker sills.
Jim
03-29-2019 #3
