View Full Version : Jason's 67 pro touring Camaro
Pages : 1 [2]
cam1968327
04-28-2022, 06:43 PM
Here some photos of the Wegner Motorsports Valve cover
199138199139199140199141
Also a couple pics of the coolant pipes. Upper is 1.25 diameter and lower is 1.5" with a 3/8" bungs for water temp sender.
I've got se run videos as soon as I figure out how to post.
Those valve covers are the bomb!
TANKMASTERJ
04-28-2022, 07:15 PM
Yes they are killer. The accessories drive also.
Hats off to Wegner Automotive guys and specifically Ben in Engineering who helped get the design I wanted.
Those guys make great stuff. And unlike holley accessories drive this was made in USA. I'm not knocking holley, I know there drives and valve covers are nice stuff. I just like to buy USA when I can.
TANKMASTERJ
05-03-2022, 06:06 PM
Ok so my Nuke Performance Catch cans are here.
One is mounted but not plumbed. For those of you looking for one, Nukes is hands down the nicest machined catch can I've ever laid yes on. Has two inputs and one out put. Can be plumbed outlet to atmosphere or recirculating.
Also a drain on the bottom. Can was 316.00 bucks plus a 27.00 drain valve and hose. Worth every single penny.
TANKMASTERJ
05-03-2022, 06:11 PM
199508199509199510
They have a carbon fiber can, a performance can and a competition can. Get the competition, it's got better filtration and you can loosen the base from the top hat and rotate the can 360 for making fittings connect where you want them. Also has a bullet dipstick.
chevyz240
05-04-2022, 11:08 AM
199508199509199510
Nice to see some Swedish parts! :)
TANKMASTERJ
05-05-2022, 07:17 PM
And now she is plumbed199586199587
mistral
05-05-2022, 08:08 PM
That is so nice!
TANKMASTERJ
05-06-2022, 06:06 PM
Thanks!
TANKMASTERJ
05-08-2022, 08:09 PM
Ok so I narrowed my back seat bottom and top for the tubs. I then fit the anvil carbon fiber mirrors then epoxied the appropriate parts of them and reassembled them .
Put them on the car for a photo and now I got to make a gasket where they mount to the car.199684199685199686199687199688199689199690
TANKMASTERJ
05-09-2022, 04:14 PM
Incant find your build thread where is it?
TANKMASTERJ
05-23-2022, 04:53 AM
Wing windows and carbon mirrors are on. Also my re barrelled wheels are back from forgeline.199972199973199974199975
Just 1 More
05-23-2022, 05:19 AM
beautiful
wareaglescott
05-25-2022, 01:28 PM
Love those mirrors. Great choice.
wfo guy
05-25-2022, 02:21 PM
Each time I check in I expect to hear sound. :)
TANKMASTERJ
05-25-2022, 03:51 PM
Thanks guys. If I knew how to post sound I'd do it
TANKMASTERJ
05-28-2022, 06:27 PM
200070200069200068200067200066
Installed my driver seat. Seats are Braum Alpha X.
Very nice for a vinyl I got no complaints. Will test drive tomorrow.
Also got my center dash piece in it's Anvil Carbon.
I have to say both the mirrors and center dash are anvil and I'm not that impressed with the qualities.
Seriously the mirrors you got to glue the bracket in that holds it to the car and you glue the bezel in. Both with epoxy but for the price just not impressed. The center dash you don't get anything to attach it to the car. Undrilled holes because my entire build is stainless bolts everywhere so it's ok. But it still needs a rubber windlace around the outer perimeter.
Motown 454
05-28-2022, 07:18 PM
They look good
thumper877
05-29-2022, 03:17 AM
Seriously the mirrors you got to glue the bracket in that holds it to the car and you glue the bezel in. Both with epoxy but for the price just not impressed. The center dash you don't get anything to attach it to the car. Undrilled holes because my entire build is stainless bolts everywhere so it's ok. But it still needs a rubber windlace around the outer perimeter.That sucks when you pay that much for speciality parts and you have to still engineer them to mount on the car. Car looks good. Good luck on that first drive. Its exciting and scary lol
TANKMASTERJ
06-04-2022, 12:52 PM
Well after a commercial napa 930 CCA struggles to start my high compression LS7. Im wavered on a single North Star with 1130 CCA or just run 2 Continentals that I had already new. They are 680 each. So I used my original battery tray and a new dynacorn tray and fabbbed a bracket out of 3X5X1/4" thick angle I had and mounted it between my bolt in cage.
And instead of a battery number from one to the other I just ran another #2 up to the firewall bulkhead. So each battery has its own hot to the firewall.
200221200222200223200224
TANKMASTERJ
07-15-2022, 07:53 PM
Well I'm not great at pictures but here the Spoilers by Randy added today.
I like if for a bought one. It still like to add a custom pro touring one later but for now this works200966200967200968
Also having a little driveability issues. Like several have had in older posts I read when in the throttle and letting off or down shifting up to a stop light it wants to die. Runs great at idle, part throttle over half throttle even WOT but then falls on its nose when I let off. I'm using the E38. Haven't had any tuning done yet other than the ECU came from a wreck z06 that ingot as a package.
Considering Gwatney Performance little rock unless someone has another in central Arkansas that's good.
Also got to fab a stainless grill still yet and install seatbelts and rear seat. Got side glass, door panels and hardware and cold ac!
Jason
ryeguy2006a
07-20-2022, 04:37 AM
If you plug in a generic code reader that has live data so that you can confirm all of the sensors are working, it's very likely your tune. I'm sure that you have added several parts that weren't in the original tune so getting it adjusted will be key. Love that spoiler.
berdunord
07-28-2022, 11:03 PM
Love it ! Can't wait to see her running, congrats Jason, you made a huge build !
TANKMASTERJ
07-29-2022, 05:21 AM
Ive got a bosch tech 2. From what I can tell everything looks normal but I'm no expert. I've got a local guy here in conway that's going to hook to it and ride with me to data log and see what he sees.
TANKMASTERJ
07-29-2022, 05:23 AM
Thanks Bernardo. I'll eventually get a video posted. Working on slight tuning issues at the moment. Hopefully get my back seat, seat belt bar in this weekend then all I'll lack is grille and stereo!
As you know it's never done, I see your doing no another turbo too!
slazisme
07-29-2022, 08:00 AM
Jason
I had a problem with my car stalling upon slowing down after I pressed the clutch in coming to a stop/light. I found out it had something to do with DFCO- deceleration fuel cut off. I'm not running a GM ecm, using a Fitech 70050.
https://forum.hptuners.com/showthread.php?1194-What-is-DFCO
Not sure if this is your issue but maybe worth a little investigating or having a qualified tuner check this out.
Simon
TANKMASTERJ
07-29-2022, 08:21 PM
Thanks for the tip I'll definitely look at that.
Jason
TANKMASTERJ
08-02-2022, 08:25 PM
Ok so I'm tinkering again. I installed my LS7 emblems and I think they look pretty good. I also cut a grille pit of some aluminum mesh. I lined the outer perimeter with se black rubber for the pop effect next to the aluminum grille and white grille surround.
I'm happy with the end result.201235201236201237201238201239
wfo guy
08-03-2022, 04:57 AM
Grille looks good. :)
wareaglescott
08-03-2022, 06:45 AM
Digging that front grille Jason. Looks great.
Question on your seats, and how tall are you? Im wondering how you are feeling about your driving position?
I am 6'3" with similar style seats. 300 miles in now and just feel like I am sitting a little high. Considering making a change but outside of a major change at the base probably my only option is removing the slider and going to a fixed location. That would probably put me about an inch lower.
TANKMASTERJ
08-03-2022, 06:48 PM
Bad news I'm only 5 10. Braum Alpha X racing seats with there sold planted brackets fit me perfect. But I have tracks mounted as far back as they go. A taller guy would struggle with my setup. Probably have to remove the planted brackets or have to chop them down and re fab to make it happen.
I had the pro car 90 seats and brackets, they did with lower
Hope this helps
Smooth67
08-10-2022, 06:15 AM
Man, great progress Jason! That grill looks so good as well. I have an extra ‘67 grill that I am modding - can I ask what the black surround material is?
TANKMASTERJ
08-10-2022, 07:20 AM
Brett
it's just some rubber edging material that resembles pinch weld molding. I bought it from custom car grills dot com. They sell the mesh and the edging in couple sizes.
Jason
Smooth67
08-10-2022, 08:19 AM
Brett
Jason
Nice, thanks for the info
TANKMASTERJ
08-12-2022, 06:47 PM
If knew how to add sound I'd add it lol
wfo guy
08-13-2022, 02:46 AM
Jason, under hit reply, go to advanced. Under "manage attachments", click the box and then navigate to where ever you have your sound file located and double click it. As long as the file isn't too large, it should load. Then we can hear it run. :)
joeko23
08-13-2022, 09:06 AM
Upload a video to YouTube then copy and paste link
TANKMASTERJ
08-13-2022, 11:44 AM
https://youtu.be/-erNtAE_QVo.
Ok I finally took a few minutes to figure out to post a video to youtube and copy and paste the link .
Hope it works. This video is early summer before my re barrelled forgelines were back and ally was still undone but you can hear it.
I'll slowly work on the youtube channel it's called White Lightning 67 Camaro
wfo guy
08-14-2022, 05:15 AM
Very good. :)
berdunord
08-14-2022, 12:32 PM
Awesome !
cam1968327
08-14-2022, 03:14 PM
Sounds fantastic!
TANKMASTERJ
09-03-2022, 07:43 PM
Alright guys I'm building out my amp and stereo setup and my rear shoulder belts. setup201936201937201938
Now I ordered morris classic shoulder belt kit for the rear. I want to say outstanding kit and quality but it wouldn't work with my ridetech bolt in cage and my custom package tray. So rather than mount the shoulder ratchets on the outside of the car I mounted both in the center between the speakers and fabbed up appropriate bracing under the package tray out of 2X2x 1/4 aluminum angle tying the two ratchets to each other and then 1/4" X2" flat from that down to my battery trays which is made of 3X5 aluminum angle and bolted between the cage points in the trunk. I didn't get good pics of the mount or the ratchet part of the belts installed but will add those tomorrow.
For stereo I'm trying the Mark 4 out of sight audio and running a Hertzs HCP 5D amp. I've got Hertz Milles for the deck in 6X9s and Hertz Milles for the kick panels but I've yet to install those.
As for the cars driveability I had issues with limp mode at 6 grand and no matter what we did tuning it wouldn't leave. Engine came with a gold blade TB when I got it. Ran the VIN and it called for the Silver Blade. Read forums online where other guys had the same issue trying to go to the gold. Depending on which E38 they had. So swapped to the silver blade, did a TB re learn and wallah it runs hard to 7500 now.
Still got a slight lean issue on back one due to very tiny hairline cracks on the runners right behind the intake bolts. Will be swapping to probably an MSD.
Or do you guys think Fast or MSD. I don't care about max effort at 7500 or 8 grand. It's a street car that will see auto x, drag and a little road racing. But predominantly street so I need torque and power 3 -7500.
Jk918
09-05-2022, 02:50 AM
Can't go wrong with either, the MSD typically make a little more HP, just be sure you have enough hood clearance and which one works with your current fuel rails.
TANKMASTERJ
09-07-2022, 06:38 PM
Got my Estopp mounted. Put it on the driver's side frame rail of my Speedtech sub frame. Use studs I already had through the floor from my front door bar cage mount setup and used holes that came at the back of the subframe to mount the bracket. turned out pretty clean.201972201973201974201975201976201977
Just 1 More
09-08-2022, 05:26 AM
E-Stopp looks great, I need to install mine and have been researching how everyone else mounts theirs. I appreciate the pics.
TANKMASTERJ
09-08-2022, 05:55 AM
Buy the CPP kit. It has that long skinny bracket in my pics. I jest welded small fabbed brackets up to mount to my sub. There universal cable kit was also great.
Jason
Just 1 More
09-08-2022, 06:04 AM
Jason
I didn't even know that existed.. Thank you Soooooo much.
TANKMASTERJ
09-11-2022, 08:33 AM
Well made it to 2022 with white lightning.202037202038202039202040
wfo guy
09-12-2022, 05:05 AM
Congrats. :)
ryeguy2006a
09-12-2022, 09:42 AM
Congrats!! It looks fantastic out in it's natural habitat.
TANKMASTERJ
09-12-2022, 12:51 PM
Thanks guys as you all know it's a long time coming
wareaglescott
09-13-2022, 04:00 AM
looks awesome. Amazing work all the way through!
TANKMASTERJ
09-13-2022, 05:26 PM
Thanks man yours as well. I've had my eye on your build all the way through and it's been impressive and you've made great time on it as well.
berdunord
09-15-2022, 09:40 AM
congrats Jason you made an awesome work, she is the sexiest one :)
mistral
09-16-2022, 02:58 PM
Well done, looks awesome.
TANKMASTERJ
09-16-2022, 06:55 PM
Thanks Bernardo!
- - - Updated - - -
Thanks it's appreciated
Smooth67
09-17-2022, 09:09 AM
Congrats Jason!! Looks amazing sitting out there
TANKMASTERJ
09-17-2022, 05:21 PM
Thanks Brett how's yours coming along?
thumper877
09-18-2022, 03:02 AM
Cars looking awesome. Love the grille and the white really pops
TANKMASTERJ
09-18-2022, 06:12 AM
Thanks , I was concerned about enough pop with no black up front. I'm thinking about making another grille of the same mesh and painting it black so I can compare, or maybe even paint the fiberglass surround black andeave the grille aluminum.
TANKMASTERJ
09-20-2022, 05:59 PM
Working on the alignment now. I got the toe set a 3/32 toe in and the Camber at 1/2 degree negative. Now I just got to line up the Caster to 4-4.5 positive. Using Speedtech subframe recommended settings202251202252
chevyz240
10-13-2022, 09:57 PM
The car looks super nice, Jason!
Do you know what scrub radius you have? From the look of the wheels, it looks like you wanted to keep it low.
Threepointtwo
10-14-2022, 07:26 AM
Wow, what a great build and a huge inspiration. Congratulations.
TANKMASTERJ
11-27-2022, 06:31 PM
Thanks for the kind words. It's closer but seems never done lol.
Jason
TANKMASTERJ
11-27-2022, 06:56 PM
So my Speedtech torque arm rear end 9" leaked at both ends. Mine had the roller outer sealed bearings. So I decided to re engineer a little. So I installed the winters performance #2842 gold billet aluminum axle tube seals to keep the oil in the center section. I then drilled and tapped 1/8"-27 holes in the ends of the tubes between where the original inner axle seals went and the sealed roller bearing. I installed a 90 grease fitting here right on top. So I then installed the original national axle tube seal, and then removed the inner plastic seal on the roller bearing so it will receive the grease. So my grease fitting puts grease in between the original style tube seal and the now open side of the roller bearing.
It's .625 cavity there.
I'm now keeping oil in the center and greasable outers separate by the two styles axle tube seals.
What do you guys think?203666203667203668203669203670
wfo guy
11-28-2022, 06:09 PM
I'm sure you know this but if you over lube a bearing, it will overheat and fail. I fought a leaky bearing as you did. I replaced the oring numerous times. Only by accident did I pull on the axle flange and find out there was slack in the bearing. It was starting to fail. After replacing the bearing, the leak went away. In my purchases of new bearings in the last 15 years, I'm right at a 20% failure rate. New parts make me nervous anymore. Some brands are worse than others but none are like it was when I was young. :)
TANKMASTERJ
11-28-2022, 06:44 PM
Yes
Lip seals can fail typically around 500psi. Trick is don't over lubricate. Good thing in my design if I pump just a little bit much it will pass the lip seals and merely get on the dry zone of my axle. Once a year a few pumps will be sufficient but I do have a pressure gauge setup on my battery powered grease guns for certain applications.
To prove just how strong grease under pressure is with a cup seal we tighten tracks on dozers and all track machine we own with grease. But the cup is pointing towards the grease fitting. In this car application the cup points the other way towards the oil end or center section to keep oil out of the grease. Thus even lowering the pressure it would take to bypass the seal.
Case in point your correct.
But I have considered this and engineered my design around your line of thought along with several others.
Jason
TANKMASTERJ
11-29-2022, 07:32 PM
Well I started with one nuke performance catch can, and excellent excellent quality. But I had valve covers and valley cover both plumbed into it. Then I separated the valley cover and just looped it back like factory. Then I decided to add a second so the valve covers and the valley cover pcv had its own.
Again if anyone wants some very nice billet catch cans, nuke performance has race cans, performance cans, and even carbon fiber cans.203760203761203762203763
CarlC
12-01-2022, 01:32 AM
Having spent a 28 year career in bearings.....
Your relubrication feature should work fine. One challenge with the design is the cavity space on the lubrication entry side is quite large vs. the void space in the bearing. There are a ton of variables here, but.....
1) Due to the design of the inboard seal vs. the outboard seal of the bearing, grease is going to tend to work outboard. Most of the axle seal designs are a double opposing lip design, whereas the seal on the bearing will easily deflect outboard and allow grease to purge. This is normal and often expected on sealed type bearings. It's going to purge what it does not want.
2) Though over-lubrication is often a serious problem, it typically occurs when the dN (rolling element pitch diameter * RPM) is high. A drive axle is a relatively slow application, and likely excessive grease will purge before an overheat condition occurs.
What can be done that is quite effective is to fill the bearing full of grease, and then fill the cavity space about 50% full/about to the axle bottom of grease. Excess from the bearings will purge inboard. There will be 50X+ more grease in the cavity than what the bearing comes with from the manufacturer. As speed and heat dictate, fresh grease will flow into the bearing. In a bearing that size there's likely 3-4cc's as the standard fill volume. In other words, no need to ever re-lubricate unless the axle is removed. Then everything should be cleaned and re-lubricated. The same basics can be applied to a stock front hub with double tapered roller bearings (fill the hub 1/2 full).
TANKMASTERJ
12-01-2022, 01:14 PM
That's awesome insight to a seemingly simple setup. I appreciate the explanation and I love to learn. I definitely have with your reply.
Jason
eversaul86
12-01-2022, 08:18 PM
Super nice work! Love the progress. Great motivation for me!
Martin
TANKMASTERJ
12-06-2022, 05:04 PM
Ok, Long Story but 67 camaro with Early 2008 LS& with E38 ECM Swap. Came out of a burned wreck with new intake and injectors, throttle body etc.
Car ran great to almost WOT and about 6K Plus had limp mode every pull. After much tuning crap and hair pulling, I discovered that what I had came with a gold blade later LS3 style throttle body. My Earlier VIN Vette LS7 actually came with a Silver Blade Throttle Body, so I ordered one, swapped, did a throttle relearn and she ran like a top into over 7 grand no REP, no Limp, no Dead Pedal. For about 3 months. Then one evening while driving home from church, I had an all of the sudden tail lights go out and fuse pop. So tracked that to an extra insulated Jacket Male Connector I had left hanging that touched ground. It was feeding the hot to my gauge pack. So when it happened I lost all Dash and Gauge Lights as well as Tail Lights.
On the way home while driving AFTER that happened i hit Limp Mode Dead Pedal in 4th gear in a slight pull.
Didnt think much about it but came in the shop, found the Male Connector Shorting out on the Steering Column, Plugged it with a dummy female, replace Fuses and all was fine.
Except the Dead Pedal. Now if I turn Key On, Cycle Pedal, Pedal goes immediately Dead with Codes P0122, P1516 and P2135.
Now P1516 I was seeing with the old Gold Throttle Blade.
So I did a Throtte Relearn and no change. But If I turn Key On , Cycle Pedal, then Run Diagnostic with HP Scan, Then Start and run it runs great for a little while, then randomly back to Dead Pedal all the Way, or REP Limp Mode then Dead Pedal.
Could my lit e Wire Short Deal somehow Shorted out my Pedal or Throttle Body TPS or TAC??
All was Fine until that Incident.
. The Wire that shorted out is in the Car Harness, Nothing to do with the Swap Harness. Fused Separately and all.
Any Help appreciated.
extremetoy
12-08-2022, 09:18 AM
Looks like you’re doing it right, very nice car!!!
Hemi8
12-17-2022, 07:41 AM
204166
I have the Braum seats in my 86 GN, they are very nice. I have tried multiple seats including factory/Recaro/Sparco and the Braum is better/more comfortable than any of them.
Mike
Steve68
12-17-2022, 09:26 AM
Can't you ohm out all 3 of those items and see if one is your problem??
we were having the same issue with a 05 Tahoe with the 5.3, but it still needs a relearn,
TANKMASTERJ
02-10-2023, 12:44 PM
204166
Mike
Those seats look awesome Mike
TANKMASTERJ
02-10-2023, 12:46 PM
Work on battery kill switches. I added 2. One for each trunk mounted battery. I can run on either charge either etc. So if i got an event or a gathering I can run sound system on one and have a hot one to start on. With both on both charge pretty evenly. The hots are both 2 gauge welding wire from trunk to bulkhead hot pass through at firewall.
Alternator charge wire is 4 gauge from alternator to firewall bulkhead pass through.
Right battery ground goes up front to bulkhead pass through like the + through firewall. The Left battery is grounded to the first and to the chassis.
Dual hot cables on left battery 1 to Sound System Amp, 1 to bulkhead + at firewall. Right battery has 1 Hot cable to Inpower 200amp solid state switch and 1 to bulkhead up at firewall. The 200amp Inpower switch feeds a 10 fuse and 5 relay fuse panel in trunk that handles heated seat circuits, several console circuits, fuel pump, and sound system circuits.
Since my radio is an all blue tooth in trunk, I utilized the two radio circuits in the AAW harness for the electronic E Brake as it needs a hot all the time ( used radio clock yellow wire ) and a hot with ignition on wire ( radio key on power brown wire ) both of which are fused for 10amp like E Stopp needs.
205323
TANKMASTERJ
02-10-2023, 01:21 PM
Now working on the center console. I ordered from Modern Classic Interiors. Took threatening emails and filing a claim with paypal to finally get it 6 months later. But he shorted me the billet ring brothers shift ring and leather boot. But at least I got the console. Now it's fit to the car and I pulled center out to paint. Main console wrapped in black vinyl. Center from AC vents to cell phone pocket will be white to match car and dash and have a black striped down the middle for some pizzazz.
Ive got 5 switches sandwiched in the console storage.
1 for E brake, 1 for dome light in console, 1 for each of the 2 power ports ( got one 12v cigarette lighter style and 1 dual usb style) , and a fuel pump switch. To with fuel pump switch I can key on and do programing no and such without fuel pump running.
205324205325205326205327205328
TANKMASTERJ
02-10-2023, 04:19 PM
Thank you very much sir!
Smooth67
02-11-2023, 03:33 AM
That console looks good Jason!
wfo guy
02-11-2023, 10:32 AM
What did you find wrong with your electrical problem from a few months ago?
TANKMASTERJ
02-11-2023, 08:29 PM
Thanks Brett what's the status on your baby?
TANKMASTERJ
02-11-2023, 08:31 PM
My little spare hot ignition wire I left hanging around , when it touches ground it fried my 650.00 GM silver blade throttle body
So I replaced it with a Dorman aftermarket for $150.00. that cured it.
Smooth67
02-14-2023, 11:05 AM
Driving up tomorrow to pick up the rest of my parts (hood, trunk lid, etc) from the body shop. Still no paint but I should be in a better place with a complete car again.
TANKMASTERJ
03-04-2023, 03:31 PM
Well console finally in. Kick panels and speakers finally in. Driver side cage door bars in, and driver side seatbelt in. All I lack is passenger side seat belt, passenger door bars.
License plate light, back up light, and microphone for my bluetooth setup.
Then it's basically done. OMG.206011206012
wfo guy
03-04-2023, 03:48 PM
Jason, now that the end is near, do you see anything that you would want to change? I'm curious because I often hear there is something we missed or we're disappointed in that we purchased. :)
TANKMASTERJ
03-04-2023, 09:07 PM
Jason, now that the end is near, do you see anything that you would want to change? I'm curious because I often hear there is something we missed or we're disappointed in that we purchased. :).
Well,
That's tough question. For starters I would have ordered a real deal steel Camaro to body complete in epoxy primer already minitubbed. That would have been alot cheaper. Secondly I would have done way more mock up on everything.
Thirdly i would have done all the body and paint because I would have been happier in the end and I would have saved that money for a professional interior job.
Because what i wasted on body and paint, and I got milked, I could have done just as good of a job, and my end result is very nice, but I got milked to get there.
I enjoyed all the build that i did myself which was everything but mud and paint and the little metal work they did around the window channels and such. All that cash I blowed on them taking forever I could have bought the new body.
I'm happy with all my chassis, brakes, engine, all that.
I probably would have done LS3 instead of the LS7 because of economics but that story is in my build thread.
I would have done flush glass.
That's about it I think.
Jason
wfo guy
03-05-2023, 04:04 PM
Jason, that's a good answer. Specially the economics of this hobby. Continual growth is an important part of life. If you choose to do another, you will have some idea of time and effort to make the decisions easier. I finished my last project last summer. Most of the parts were purchased in 2021. I've been looking at prices since the 1st of the year and have been surprised several times at the size of increases. It has really changed my mindset about another. :)
ryeguy2006a
03-08-2023, 05:28 AM
Console turned out great Jason! Looks like your car is just about ready for the cruising season. :cheers:
Smooth67
03-08-2023, 12:10 PM
Well,
Jason
You make some great point Jason!
The new body is definitely something to consider in the future. There is a shop in Texas that builds them and will even do a wide body...which I'd have to see in person and look over.
Paint and body...OMG! I never thought I'd have issues in this department. I'd definitely paint mine if I still had a shop to use.
Flush glass is still something to consider, but imo the bottom of the windshield pillars has to be squared off for it to look right.
You have a great car man, still want to get down there and see it in person sometime.
TANKMASTERJ
03-08-2023, 03:34 PM
Thanks Ryeguy
And yes just in time for the shows. I'm doing a couple locals and I'm already booked for my stay at LS Fest Texas. Not sure if I'm taking the car thee but I'm going.
I've been to bowling green 3 times and once with car last September but in an incomplete state although running and driving.
It's been a journey as all of you here know.
- - - Updated - - -
Yeah let's definitely get together.
I've got to run to fayetteville for a business trip soon I may reach out to you once I get the date naed and if time allows on
Just 1 More
03-09-2023, 12:27 PM
Great job on all of it, Looks great
T-Rat
03-10-2023, 04:02 PM
Impressive stuff. Clear to see you put a lot of effort into the details here. Nice!
TANKMASTERJ
03-10-2023, 04:12 PM
Appreciate it
- - - Updated - - -
Appreciate the kind words. It's got flaws but it's my baby!
TANKMASTERJ
04-01-2023, 09:20 PM
Well did a car show today In cabot arkansas.
Got 2nd place in the 1st gen category.206733206734206735206736
Seen alot of killer rides. Everything from Vegas to jaguar
Motown 454
04-02-2023, 01:59 PM
Congratulations! It looks like you had a beautiful day to enjoy.
TANKMASTERJ
04-02-2023, 02:01 PM
Thanks Wayne
How's your recovery been and are you back working on your car yet.
wfo guy
04-02-2023, 03:11 PM
Congrats on having the car out. :) Awards are what we get from driving. :)
chevyz240
04-03-2023, 04:20 AM
The car looks really good, Jason! Congrats!
ryeguy2006a
04-04-2023, 05:36 AM
Congrats on the trophy! You definitely deserve it after all the hard work.
TANKMASTERJ
04-04-2023, 05:23 PM
Haven't got that kind of award yet!
- - - Updated - - -
Thanks Henrik
Hurry up so you can drive the Z !
- - - Updated - - -
Thanks Ryan. It sure is a lot of work but crazy how therapeutic it is
wareaglescott
04-05-2023, 08:12 AM
2nd place?? What the heck got first place then. Must have been the show organizers buddy! haha
Car is looking awesome.
TANKMASTERJ
04-05-2023, 06:23 PM
Another 1st gen that to be honest was a nice restomod but that's it.
Another guy there had a 69 about like mine but with DSE under it instead of Speedtech and he didn't even place.
But I was tickled to place at all
jrhyno
04-12-2023, 09:45 AM
Just looking around. Which subframe and components did you use?
Thanks!
TANKMASTERJ
04-12-2023, 03:27 PM
Thanks!
Speedtech front sub
Speedtech rear torque arm
Couldn't be happier
Rowdy LS7 and tremec 6 speed 9" with 4.11s
Gmc427
04-15-2023, 02:15 AM
car has come out great,i know you would have posted wheel and tire size but are you able to tell me what you are running?regards
TANKMASTERJ
04-15-2023, 08:27 PM
Rears are 18X10.5 with 295-40-18 drag radials
Car was build for 315-40-18 nitto 555g2 but couldn't get them during covid. So I ordered it the 295s I drag radials and street tread both. When those wear out I'll go to the 315s.
Fronts are 18X9.5 with Nitto nt555g2 in 275-35-18
TANKMASTERJ
05-05-2023, 06:39 PM
Added a radiator expansion tank from Radium engineering. Very nice billet piece setup to take steam line from head, return that back to either water pump or radiator and also can plum existing radiator overflow into it. Has sight glass. Works great. I run it half full. It expands to full in sight glass when hot, and back to half when cooled down. 207349207350207351
berdunord
05-08-2023, 03:37 AM
Really happy to see her running Jason ! Congrats that's an awesome work !
TANKMASTERJ
05-15-2023, 01:20 PM
Thanks Bernardo
It sure is great to driver her
TANKMASTERJ
05-28-2023, 03:17 PM
So literally
Words cannot describe the help I have received here from all of you. If I name names I'll miss several or many. Probably. I'll bet 30 guys have commented and impacted my build. From choices of parts to how to's to troubleshooting.
A gigantic thanks to all of this PTF community. You guys rock. I would like to see more guys post in the section that has the regionals and states you are from and more guys post when your going to LS Fest or Good Guys type events. I'd sure like to meet some in person.
Again many thanks to all of you.
I'm looking for another candidate now but for a less intense build that I can pound on and not want to cry when I scratch it lol.
All I lack on finishing my build on White Lightning a 100% is sun visors, rear view mirror, dome light in headliner, and some minor touch up.
joeko23
05-29-2023, 04:49 AM
Jason, have you thought about putting PPF on the car to protect paint? Thinking to do this to mine when it’s finally done with paint.
TANKMASTERJ
05-29-2023, 09:49 AM
Yes and I already have so many tiny rock chips. I didn't realize how bad these wide sticky tires cause it. I'm thinking run a couple years and when the lower quarters and rocker look crappy, to have them re shot and blended then have that applied. I'm thinking maybe it's too late now I'm I don't really know.
joeko23
05-29-2023, 03:27 PM
That sucks! My painter said to wait at least 6 months before applying the PPF to make sure the paint fully cures and airs out. Wow that means I can’t drive the car because I’ll def get rock chips.
TANKMASTERJ
09-27-2024, 06:50 PM
So I've been out and won some car shows. Happy about that but time to work on white lightning again. 214868214867214866214869
Added a Mamo ported MSD, NW103 and 850 injectors.
Now for a tune and I'm going to try GPI in Jacksonville Arkansas as I wasn't ever fully happy with my last tune.
Also had clearance issues with the MSD and my Wegner accessories drive. So I purchased some Supercharger intercoolers .400 thick spacers. They sell them for insulated supercharger applications but was just what I need to clear the water pump and stuff. Included a pic of those on the heads.
ryeguy2006a
09-30-2024, 03:53 AM
Looks great! Glad to see you out enjoying the car!
TANKMASTERJ
09-30-2024, 06:01 PM
Thanks Ryan
What are you working on now. I'm just starting on a 74 C10.
ryeguy2006a
10-01-2024, 05:26 AM
That Square body sounds nice. I'm keeping my eyes out for a solid bodied truck to build too. Either that or a late 80s F150.
Sold my 68 Camaro a few years ago now, and picked up a 55 Nomad project. I've got a build thread here, it's taken a lot of work to get it to where it is now.
chevyz240
01-19-2025, 02:10 AM
As I've said before, everything looks super nice and clean! Very well done, Jason!
Is the grille surround a stock Chevy piece? I don't think I've seen that version before. Or maybe I just notice it because it's white. I haven't seen the aerodynamic rounded inlet design before (I think).
TANKMASTERJ
01-24-2025, 07:36 PM
Henrik,
It's a custom piece that somewhat mimics a 69 by being inset rather than flat like a 67. A guy used to make these and sell them on eBay and then he vanished!
Jason
chevyz240
01-28-2025, 10:00 AM
Henrik,
Jason
Cool! Then my eyes weren't lying to me! ;)
berdunord
02-03-2025, 12:07 PM
It's been a long time I did not look at your thread, she looks awesome ! Congrats Jason !
