View Full Version : Carburated engine return line
70CougarXr7
03-03-2019, 06:20 AM
Not sure where to post this since its not an EFI.
Running a carburated 408( well should be when it arrives in a few weeks)
Stock fuel tank with external electrical fuel pump from holley
Got filters, pressure regulator and a return line in place.
Question is, where do i best install my return line?
My fuel tank has a drain plug so i was thinking to connect my return on the drain plug.
(Just not sure if this might cause an issue?)
https://static1.pt-content.com/images/pt/2019/03/5qo4UyV-1.jpg
What are your thoughts?
Thanks!
Schwartz Performance
03-03-2019, 06:52 AM
The higher the better so the fuel has an unrestricted path.
-Dale
Skip Fix
03-08-2019, 05:00 PM
Get rid of that glass filter! They crack and leak.
70CougarXr7
03-10-2019, 03:42 AM
Thanks for the heads up
968ls1
03-11-2019, 07:03 PM
Return line to the top of the tank if possible, X2 on the glass filter asking for trouble, return line should prevent vapor lock.
OLDFLM
03-12-2019, 04:57 AM
Just checking... you have a "bypass" regulator, correct?
03-12-2019, 09:36 PM
You could tap or weld a bung low on the filler neck.
70CougarXr7
03-15-2019, 11:17 AM
This is the one i have:
https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/regulators/carbureted_regulators/parts/12-881
- - - Updated - - -
Was thinking about doing it that way, saves me the issues of dirt getting in my fuel tank when drilling a hole into it..
