    Results 1 to 3 of 3
      Oct 2011
      Wheel clearance needed rear wheels minitubbed 68 camaro
      Hello
      Can someone please tell me how much clearance I need from the rear tires
      to the outer and inner fender?
      is 1/2” on each side of the wheel enough space?
      Using a Strange Fab 9 rear with Chris Alston G link
      Thank you
      Dec 2010
      Fredericksburg, VA.
      Well I'm running 18x12 335s with a G-link suspension and mini-tubs. I have about 3/4" clearance inboard and 1/2" outboard. I also have rolled the rear fender lips to avoid having the pinch weld cut the tire sidewall. I have not had any problems with tire rub to date.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Sep 2017
      Steve I've been looking at dust off as soon build my 67. I got Speedtech subframe and rear torque arm with my rear narrowed to a 53" WMS to WMS. Going with Forgeline ZX3. Wanted 335 on 18X12 like yours but don't really want to to roll fender lip. So you think yours would rub/cut if you didn't? If so I should probably stick with the 315s on 18X11??
      Thanks for your take on it.
      Jason / TANKMASTERJ
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
