View Full Version : Gbody frame bracing and notching
72'Monte
01-31-2019, 09:11 PM
I plan to notch and brace my frame for my 86' monte.and looking for tips or ideas on how i should do it.pics help too.
BMR Sales
02-01-2019, 06:40 AM
What is the end goal of the Monte? When you say notch & brace - mini-tubs?
silvermonte
02-01-2019, 11:10 AM
When I did my olds cutlass a few years ago I cut just out the wheel well really well and then just moved them towards the center by 3" and then put in a filler piece to fill in the gaps. That worked out pretty well and still looks factory. For the notch I cut the frame portion out and then ground down the piece I cut off till it was flat and then welded it back in, my frame is about 1 1/2" wide now if I recall correctly. As for the bracing after I did that i sorta did a cross x-brace sorta thing. This link should give you a pretty good idea. Not saying this is the best way but its pretty low buck.
https://gbodyforum.com/threads/1981-malibu-build.48520/page-14
72'Monte
02-01-2019, 10:51 PM
Yhanks
