View Full Version : Coilover Compatability with DSE Control Arms
Underliner6
01-28-2019, 06:06 PM
I just purchased some Detroit Speed upper and lower control arms for my 1972 Camaro. I’m not interested in running the Koni shocks or JRI coil overs that DSE offers in their kits.
My question is, will any manufacturers coilovers work with these arms? I would like to run Viking double adjustables if they are compatible. I may call DSE directly but like another thread i read, DSE is going to suggest I run one of the products they sell and not a competitor’s product with their arms.
Thanks for any insight!
Jim
dhutton
01-28-2019, 06:31 PM
So long as they have compatible mounts then you can run anything you want.
Don
BMR Sales
01-29-2019, 06:51 AM
Number One, check with DSE
Number Two, pictures would help, but if the Lower Arm has the holes for a T-Bracket, then a ViKing should fit
c4racer2
01-29-2019, 08:21 AM
I only see a stock spring pocket on these. Not sure how the dse coil overs mount.
https://www.detroitspeed.com/tubular-lower-control-arms-1970-81-camaro-firebird-stock-spring-pocket-031204
c4racer2
01-29-2019, 08:24 AM
Also unclear how the DSE coil over mounts but says here they work on any 2nd gen and don’t require the DSE arms. that may also be the case with the Viking setup.
https://www.detroitspeed.com/front-coilover-conversion-kit-1970-81-camaro-firebird-base-shocks-sbc-ls-030313
Underliner6
01-30-2019, 07:13 AM
160913
Thanks for all the replies.
I emailed Viking and they said the same thing. It should work as long as the lower control arm has a T-Bar mount on the lower shock mount. Attached is a photo of the DSE lower control arm.
c4racer2
01-30-2019, 02:03 PM
Looks like such a mount. Let us know when you get it installed. I have these arms too on my 71 and want to keep track of my options for coil overs down the road.
BMR Sales
01-30-2019, 02:27 PM
the ViKing is going to attach at the Bottom with a T-Bracket, it will work
https://i.hmjimg.com/images/2019/01/30/VIK-B258_large.md.jpg (https://www.hostmyjunk.com/image/bAo3H)
c4racer2
03-06-2019, 09:43 AM
Did you get some installed yet ? Any update on how that went ?
