View Full Version : Tremec 6 speed drivetrain for ls2
Motor
01-18-2019, 06:24 AM
For sale is most of drivetrain that came out of my 67 Nova with Ls2. All parts are in excellent condition. Included is low mileage tremec 6speed transmission, QuickTime blowproof bellhousing with steel adapter plate and all associated hardware. Also included is a hydraulic throw out bearing showing almost no wear. The transmission is fitted with a shifter that will place shifter in the stock location for the 67 Nova. Also included is a steel driveshaft to fit a 1967 Nova that has been balanced and fitted with new 1350 u joint. Please CALL David at 614-783-8380 and I can provide more info if needed. I am located in the Columbus Ohio area. $3000.00
160448160449
redbull396
01-18-2019, 08:06 AM
Grrr, where were you last week?! Literally picked up a used last week, and just ordered virtually all those parts new! Needless to say, will have more than 3k in it! And I was in cbus last friday, lol
130fe
01-18-2019, 08:39 AM
Which trans tail is that? What was it originally out of? How many miles are on it?
Just 1 More
01-18-2019, 02:28 PM
Im in Ohio, just south of Canton and want this real bad,,, just don't have the cash right now:banghead::banghead::banghead::banghead:
1985olds
01-18-2019, 04:31 PM
Interested in the bellhousing if you are willing to seperate
Motor
01-25-2019, 04:51 PM
It is a t56 close ratio(.63) 6th gear it was probably out of a Camaro but not sure. It will mount up to any ls engine I believe
- - - Updated - - -
Don’t want to separate the parts at this point
- - - Updated - - -
Ohio is good! I would love to sell it locally. Good luck getting funds!
Motor
01-25-2019, 04:55 PM
The guy that built my car said the engine had 2800” on it but no way for me to know the true mileage. It shifts really nice and doesn’t leak or anything. It’s a nice trans.
- - - Updated - - -
Typo. 28000 miles
silvermonte
01-29-2019, 08:43 AM
What is the adapter plate for?
rchaskin
01-29-2019, 10:27 AM
???? That plate looks like one that is used for adapting LT1 style t56 to SBC motors.
This looks like a LT1 camaro T56 with a Viper tail housing. I would have to see the drivers side of the trans to know for sure.
Maybe a D&D kit from before the TR6060/Magnum transmissions came out???
silvermonte
01-29-2019, 12:14 PM
That was sorta my assumption but figured I would ask to make sure. Ill wait to see what the seller has to say.
Motor
01-29-2019, 05:31 PM
Possibly as now someone is interested and already has the bellhousing. You can reach me at(614) 783-8380.
Motor
01-29-2019, 05:36 PM
I can’t figure out how to post drivers side picture here but I can send to you if you text me at(614) 783-8380. The bellhousing looks like you could bolt an old school 4 speed to it so the plate enables you to mount the newer t56. Also you need that extra 1/2” of spacer so the input shaft has the correct depth into the crank/pilot bearing.
rchaskin
01-30-2019, 07:01 AM
here is LT1 style
160912
Here is LS1 Style
160911
Motor
02-03-2019, 12:31 PM
Thanks for all the interest, item is SOLD!
