View Full Version : LS3 Cam Selection
v8 stingray
01-14-2019, 03:18 PM
Hi Guys,
Just working on the shopping list for the new LS3 swap into my '73 TransAm and wanted to get your advice on the best cam to use. My builder is suggesting the use of the CompCams Hydraulic Roller 146-460-11 LSR (https://www.lsxceleration.com/comp-cams-hydraulic-roller-146-460-11-lsr-285lrr-hr13-very-strong-mid-range-high-end-torque/). Anyone got any real hand experience of this in an LS3?
Shopping list below ( tax man here in Europe will be happy with this! :hmm: )
Part
Link
Cost
Pistons
https://www.summitracing.com/int/parts/man-596265c-8/make/chevrolet
$793.99
Main Bearings
https://www.summitracing.com/int/parts/cle-ms2199h
$136.99
Rod Bearings
https://www.summitracing.com/int/parts/cle-cb663hnk
$17.99
Camshaft
https://www.summitracing.com/int/parts/cca-54-460-11
$389.99
Roller Lifters
https://www.summitracing.com/int/parts/cca-15956-16
$544.99
Pushrods
https://www.summitracing.com/int/parts/cca-7955-16
$140.99
Rockers
https://www.summitracing.com/int/parts/cca-19028-16
$524.99
Valve Covers
https://www.summitracing.com/int/parts/hly-241-402
$279.95
Head Gaskets
https://www.summitracing.com/int/parts/nal-19170419
$152.00
Head Bolts
https://www.summitracing.com/int/parts/arp-134-3610
$101.99
Headers
https://www.summitracing.com/int/parts/hed-45123
$696.99
Starter
https://www.summitracing.com/int/parts/pwm-9509
$217.99
Water Pump
https://www.summitracing.com/int/parts/mor-63566
$476.99
Plug Leads
https://www.summitracing.com/int/parts/acc-9070c
$110.95
Oil Filter
https://www.summitracing.com/int/parts/nal-12626224
$15.99
Spark Plugs
https://www.summitracing.com/int/parts/ado-41-101
$55.92
Fluid Damper
https://www.summitracing.com/int/parts/ati-918628
$436.00
Clutch
https://www.summitracing.com/int/parts/acl-t2r-g05/overview/model/acl
$1,060.00
EFI System
https://www.summitracing.com/int/parts/fif-72213
$2,140.00
Radiator
https://www.summitracing.com/int/parts/bci-10010
$329.99
Wiring Harness
https://www.summitracing.com/int/parts/prf-20112
$949.99
AN Fitting's/Plumbing Fuel, Brakes, Coolant, Power
Propshaft
Stainless Exhaust System
Hardware/bolts/nuts/washers/rivnuts/cable ties/
Mufflers
https://www.summitracing.com/int/parts/flo-8043041
$179.90
Rear Axel & Pinion Gearing
https://www.summitracing.com/int/parts/yga-24161
$309.40
Front Disc Brakes
https://www.summitracing.com/int/parts/wil-140-10738-dr
$1,074.99
Rear Disc Brakes
https://www.summitracing.com/int/parts/wil-140-9315-dr
$864.99
Brake Booster
https://www.summitracing.com/int/parts/sum-760166
$137.99
Master Cylinder
https://www.summitracing.com/int/parts/ssb-a0469-5
$395.99
POWDERCOATED HYDROFORMED SUBFRAME - (1970-81 CAMARO / FIREBIRD - SINGLE ADJUSTABLE SHOCKS - SBC / LS)
https://www.detroitspeed.com/powdercoated-hydroformed-subframe-1970-81-camaro-firebird-032014-group
$8,684.00
DETROIT SPEED, INC. QUADRALINK™ REAR SUSPENSION KIT - (1970-81 FIREBIRD - SINGLE ADJUSTABLE SHOCKS)
https://www.detroitspeed.com/detroit-speed-inc-quadralink-rear-suspension-kit-1970-81-firebird-041714-group
$3,380.00
Subframe Connectors
http://www.globalwest.net/1970-1971-1972-1973-camaro-tubular-subframe-connectors-global-west.html
$259.95
LS Swap Kit?
$1,995.00
Electric Fans
https://www.summitracing.com/int/parts/spu-ix-30102049
$303.12
Power Steering Pump
https://www.summitracing.com/int/parts/hly-198-100
$294.00
Power Steering Tank
https://www.summitracing.com/int/parts/mor-63788
$135.99
Power Steering Pulley
https://www.alpermotorsports.com/index.php?l=product_detail&p=181
$94.00
Clutch Pedal Conversion
https://www.classicindustries.com/product/1973/pontiac/firebird/parts/kw328.html
$89.98
Master Cylinder Kit
https://www.summitracing.com/int/parts/awr-hmgm30001sr
$403.99
Slave Cylinder
https://www.summitracing.com/int/parts/nal-24237634
$194.99
Stealth Fuel System
https://www.summitracing.com/int/parts/aei-17168
$1,177.00
Air Filter
https://www.summitracing.com/int/parts/knn-ru-3102hbk
$60.99
Shifter
https://www.summitracing.com/int/parts/baa-2010bc-2bv8
$285.00
Air Con System
https://www.vintageair.com/surefit/complete-kits/?make=Pontiac&year1=1973&model=Firebird
$1,480.00
CVF LS Engine Serpentine Kit
https://www.cvfracing.com/chevy-ls-engine-serpentine-kit-ac-alternator-power-steering/
Electric Cut-outs
Electric Window Kits
https://www.mattsclassicbowties.com/contents/en-us/d2971_Power_Window_Kits.html
Glass Set
https://www.classicindustries.com/product/all-years/pontiac/firebird/parts/*e355t.html
$627.00
Bonnett Hinges
https://www.mattsclassicbowties.com/contents/en-us/d2319.html
Wheels
$4,700.00
Body bushings
solid, rubber or poly
$36,702.95
andrewb70
01-14-2019, 05:10 PM
I guess the first thing I would want to know is the compression ration, and the second thing would be how the car is going to be used. The cam that your builder suggesting is pretty wild, personally I would never use it in a street car, but people's tolerance for big cams vary quite a bit. I tend to like milder cams because they make for a nicer driving car and are easier to tune.
For what it's worth, a friend of mine purchased the LS3/430, then added the BTR racing Stage 2 LS3 cam with the suggested valve springs and pushrods. The engine is installed in a 1966 Farilane and weighs about 3900 pounds. The car has run a best of 11.65 at the drag strip. It is a beast, and drives really nice.
v8 stingray
01-14-2019, 05:34 PM
I always liked a bit of wild! :jump:
Its calculating out at 11.57:1 at the moment... its got 821 heads on the block.
I guess its all about the brief.... told him I wanted something with lots of power, but something that I could equally drive long distances to shows without having a massive headache!
Its initial figures at the moment - but getting feedback from others is all part of the process and trying to get a sense if it is just a bit "too much".
andrewb70
01-14-2019, 05:43 PM
For me, it is definitely too much, but others may have different opinions.
Tweak
01-14-2019, 07:35 PM
I have that exact camshaft on my 408.
Its awesome, accelerates very hard
andrewb70
01-14-2019, 07:42 PM
A 408 is not a 6.2L...lol
68Formula
01-14-2019, 07:48 PM
Displacement plays a big role on a cam behavior.
OP, what is the max rpm that you plan on shifting? Are your heads ported or stock (do you have the head flow values)? What's your transmission are you using (hopefully it has overdrive with those 4.56 rear gears)?
Z06vet
01-14-2019, 08:14 PM
I agree it's a tad on the radical side. If you end up sticking with that fitech system, I'd definitely go smaller on the cam. I have not run one personally, but know guys that have and the ones with big cams had some annoying issues. With that intake & cam, it will want some gear- at least 3.90/4.10 range. What trans are you running? I would personally step it down just a bit. I'd rather see you CNC port the heads and go with something closer to a stage 2 cam. I'm really picky about driveability though.
v8 stingray
01-15-2019, 01:54 AM
I guess there's no right nor wrong... it would be great to drive the car with the two cam options and decide, but in the absence of that I'm just going to have to decide a route. When you say you think its too much, do you mean from a drive-ability perspective? It would be really useful to know the cons of such a cam with regards driveability (not sure what a cam like that does to idle etc).
v8 stingray
01-15-2019, 01:59 AM
Good question... I'm not really going to be driving this at the top-end, so low-down grunt & acceleration are the primary points. Shifting RPM, havent really thought of that to be honest - but like I said this isnt a track-day car, something more with the "wow" factor that I'll drive weekends and take to shows. I'm guessing max shifting RPM is going to be the 6,000-6,500 range. Heads will be stock, and I've purchased a new Tremec TR6060 transmission for the build.
v8 stingray
01-15-2019, 02:06 AM
What's wrong with Radical??:rotfl::rotfl:
Not stuck on the Fitech system. In fact, wanted to run the Edelbrock LS3 Crossram (https://www.edelbrock.com/cross-ram-ls3-intake-manifold-7141.html) intake but builder reckons we will need a different system to drive those twin throttle bodies. I'm in Ireland, so CNC porting these type of heads isnt something thats readily available - I'd probably have to ship to the UK to get that done. Noted the transmission below (new Tremec TR6060). I am a bit concerned about driveability now, so glad I asked for opinions!
68Formula
01-15-2019, 07:05 AM
Good question... I'm not really going to be driving this at the top-end, so low-down grunt & acceleration are the primary points. Shifting RPM, havent really thought of that to be honest - but like I said this isn't a track-day car, something more with the "wow" factor that I'll drive weekends and take to shows. I'm guessing max shifting RPM is going to be the 6,000-6,500 range. Heads will be stock, and I've purchased a new Tremec TR6060 transmission for the build.
Then you definitely want something else. First of all, the LS3 heads stock, reach peak flow around .600" lift on the intake side. So any lift above that will only gain a handful of horsepower and push the rpm where it peaks, up higher. And it's already going to be pretty high (7000+rpm) with that duration. Plus even on ported LS3 heads, the flow is almost flat by .600" lift. So unless you plan on supercharging or stroking it, going that big will provide no benefit with a large loss of power in low and mid-range rpm.
If you plan on shifting around 6500rpm, then Comp 146-458-11 would be a better choice. Peak hp will be the same as the cam your builder wants to use. If you're really planning on shifting closer to 6200rpm, the Comp 146-456-11 is a better fit. http://www.compcams.com/Technical/Catalogs/NP2009/pdf/page8.pdf Both will sound healthy, but have better driveability, and whoever has to tune this beast will appreciate it . Andrew's suggestion for the BTR cam is a good fit too. (http://www.compcams.com/Technical/Catalogs/NP2009/pdf/page8.pdf)
68Formula
01-15-2019, 07:24 AM
Which gear set did you pick for the Tremec? With those 4.56s, if you're doing distance then I'm assuming some highway driving (120km/hr), so you're going to want the .50 overdrive to keep things sane. Either the wide ratio set D, or close ratio set F (F probably better with your setup).
Also, to add to the camshaft discussion, be mindful of piston to valve clearances above .600" on that engine.
Tweak
01-15-2019, 03:30 PM
Your a **** lol!!!
Tweak
01-15-2019, 03:39 PM
Hey
Max shift probably 5k when tune finished. 11.5:1 compression, Heads are bone stock. TKO600 with close ratio overdrive, 3.5 diff gears with 26" tall tire.
We have amazing roads here in NZ, no freeways anywhere close to where i live.
68Formula
01-15-2019, 04:40 PM
Hey
OP, what is the max rpm that you plan on shifting...
https://www.webopedia.com/TERM/O/op_original_poster.html
Also, I have to go with Andrew on the whole 6.2L is not a 408. lol
Tweak
01-15-2019, 06:46 PM
Another ****!!!!! Go america!!!!!
badazz81z28
01-16-2019, 06:12 AM
I would call Texas Speed. Dyno Proven, in house design cams. They even grind their own now.
andrewb70
01-16-2019, 04:05 PM
The Holley Dominator can drive dual DBW throttle bodies and would be an excellent system no matter which cam shaft you choose.
v8 stingray
01-16-2019, 04:47 PM
That looks like a nice setup - you used that before Andrew?
andrewb70
01-16-2019, 06:16 PM
Yes, Sir. On my Cougar...with dual DBW throttle bodies. Tons of details in my build thread.
99socalfrc
01-16-2019, 09:41 PM
I have an LS3 crate motor. 100% stock with a 229/236 cam. It runs 10.79 in the 1/4 mile. I like it a lot. It is truly very driveable with excellent street manners. If you’re going to run a 235/251 cam you better have a VERY good tuner lined up. Anything short of a great tune is going to make that miserable to drive.
Z06vet
01-17-2019, 11:55 AM
> I run the exact same cam and agree with everything stated above...
badazz81z28
01-19-2019, 02:48 PM
What car is that installed in? That's way quick for a full interior street car.
redbull396
03-07-2019, 05:19 AM
I second the BTR stage 2 or 3 cam. Plenty of proven track results from the corvette world with those cams.
Also, would highly recommend RPM B3 cam. I have that cam in my c6 z06, and it makes amazing power and tuned properly, drives very near to stock. The RPM B3 and AI heads threw down 620/540 in my Z06.
99socalfrc
03-16-2019, 07:05 PM
68 Camaro, it weighs about 3,150, full interior with AC, power steering and power brakes. Car will actually hook on motor only passes on a 275/40/17 drag radial mounted on my torque thrust II.
Nitrous passes require a 15” drag radial, but have yielded 9.86 at the track. All of this is on pump gas 91 octane. It’s a pro touring car that hurts drag racers feelings. LOL
