    Results 1 to 3 of 3
      Aug 2010
      Los Angeles
      Options for 3 point harness and 4 point cage
      I don't want to use a 5 point while just cruising around town and I wanted to see what others have used as a 3 point retractable harness that plays nice with a 4 point cage. It's a 68 Camaro and I'm running a Chassisworks 4 point roll bar.
      I spoke with Morris Concepts and they make a set that utilize a D ring that you can weld to you cage. Has anyone done this?
      Just want to weigh my options.
      The d-ring has a hole thru the bracket , a 7/16 shoulder bolt goes thru it into a
      bracket welded between two roll bar cross points or thru the roll bar. The d-ring assembly
      can swivel on the 7/16 shoulder bolt.The d-ring is held on with a 7/16 shoulder bolt &
      nut on the back side.
      Thx, Billy
      Aug 2010
      Los Angeles
      Thanks for the clarification Billy. Hoping some fellow members have done this install.
