View Full Version : Air intake through radiator support
XLexusTech
11-13-2018, 07:09 PM
Considering running 4inch air intake tube through the rad support to a 90 with a kn cone filter at the end. Anyone done or seen pics of this before ? Pros cons ?
NOT A TA
11-13-2018, 08:29 PM
Pro is that you get ambient temp air at slightly higher pressure when car is moving kinda like a properly set up cowl induction. Be sure it's in an area where it won't get wet in bad weather.
XLexusTech
11-14-2018, 03:22 AM
Yep considering beside headlight but high enough to not suck water.. the other option is directly under where the battery would be but that feels risky for water... I purchased the Spectre heat shield but don’t really like the look so looking for alternatives
ULTM8Z
11-14-2018, 06:52 AM
that's what I did. I relocated the battery to the trunk. cut a hole where the battery used to sit and mounted the air filter directly ahead of the tire. also built some extra heat shielding around it to further isolate from the engine compartment. then routed my 4 inch air tube over to it.
result is my air temps are typically never more than 10-15 deg over ambient when at a stand still. when moving it's right at ambient temperature.
i never drive the car in the rain so water was never a concern.
AU Doc
11-14-2018, 07:14 AM
Have you looked at the Spectre and Airaid kits? They don't go through the support, but they tuck up into the corner and come with a heat shield. The Spectre kit uses a polished aluminum tube.
158300
joeko23
11-14-2018, 07:48 AM
not sure which LS you have but you can use the rotofab from a 5th gen Camaro. I did this with my LSA and 69 Camaro had to trim a little but it does fit very well. You can see a pic of it in my Build thread below. I’m on my cell so I can’t post a pic right now. And you can buy a used rotofab fairly cheap on camaro5.com.
Zspoiler
11-14-2018, 07:54 AM
Have you looked through the Muscle Cars from the 1960`s and 70.s for ideas
ULTM8Z
11-14-2018, 08:53 AM
158300
does this actually work? I found that I couldn't really get good results until I got the filter completely out of the engine compartment.
AU Doc
11-14-2018, 10:28 AM
I haven't really paid attention to intake temps, but here's a screenshot of a datalog with the car up to temp, and the intake temp is pretty well at ambient. I believe I took this is a datalog from a rolling start to WOT through 2nd and 3rd gear. (sorry the image is rotated)
158310
arriusone
11-14-2018, 11:28 AM
158313
arriusone
11-14-2018, 11:30 AM
Works good on mine !! If it’s tuned with the current temp it should run fine.
andrewb70
11-14-2018, 12:12 PM
Tuning actually involves putting in compensation values for changes in air temperature.
DT69Cam
11-14-2018, 01:41 PM
158313
X2, Roto-Fab is what I went with also.
ULTM8Z
11-14-2018, 02:34 PM
yeah I had to do a lot of reworking of my MAT tables.
XLexusTech
11-14-2018, 06:02 PM
158300 yes I purchased the Spectre heat shield but I am loosing interest in using it .. its a plan B right now
badazz81z28
11-14-2018, 06:19 PM
I would try to get it out of the engine compartment if f possible. It’s still
Sucking hot air even with the shield.
NOT A TA
11-14-2018, 07:38 PM
158313
Is it me or is the lower section of the core support cut away?
XLexusTech
11-15-2018, 04:06 AM
It’s you �� the support “leans” forward a bit so it just looks that way
ULTM8Z
11-15-2018, 06:30 AM
agreed
