View Full Version : 1969 Camaro - LS3 TKO 600 Flaming River R&P
wickster1965
11-09-2018, 03:22 PM
Researching my LS Swap and (I think) I have most "big" items sorted out..although I have a couple questions i cant seem to resolve after hours of searching.
Car is currently running a ZZ4 with a TKO600; both a VERY low miles. Flaming River manual rack and pinion steering.
I am looking at the following:
- LS376..most likely 480. Was going to go 525 but seems the 480 is better street manners
- Car has stock subframe but has a Flaming River manual rack and pinion steering
- TKO600 transmission is virtually new, so will re-use.
- Holley/Hooker Blackheart Engine mount brackets
- Holley/Hooker Blackheart clamshell engine mounts
- Holley/Hooker Blackheart 1¾” mid-length headers
- Holley/Hooker 302-2 oil pan
Two questions right now;
- will the above work with the Flaming River R&P? I'd rather not mess with this setup as it is also new and works well.
- what transmission x-member can be used with the Hooker mounts?
Any advice will be appreciated.
badazz81z28
11-09-2018, 04:00 PM
If you're using Hookers mounts, look into their crossmember. Its hard to say if your R&P will cause any issues. Where is it located?
wickster1965
11-09-2018, 10:36 PM
Hooker does not have a crossmember for a TKO...hence the problem.
Here are a few pics of the rack (rear mount).
158195158196
dhutton
11-10-2018, 03:45 AM
You are not likely to find anyone here running that rack conversion. There is a couple guys over on Camaros.net with Holley and TKO. Post your questions over there.
Don
DT69Cam
11-10-2018, 04:55 AM
I have the Holley mounts and Hurst Driveline x member, LS3/TKO 600. (NO R and P set-up). Only problem is with exhaust clearance. I'm using the Holley/Hooker headers and the exhaust will hit the x member. You will need a custom exhaust shop to help with this.
