View Full Version : Firewall passthrough?
absintheisfun
10-08-2018, 05:05 PM
Just curious how you ran your harness, and what did you use if you ran it into the passenger compartment.
Pics of your wire hiding/routing would be awesome!
firebirdzig
10-09-2018, 01:48 PM
What kind of car and which harness are you running?
79 Camaro
10-10-2018, 07:01 AM
I've used the daystar grommet for the firewall pass thru. More cost effective is making a trip to the local salvage yard and collect a bunch of various grommets from wrecked cars. Firewall grommets and door grommets of all shapes and sizes. I bought a bunch for $10.
GoodysGotaCuda
10-10-2018, 10:25 AM
There is a split grommet that gets riveted into place that summit sells for about $30. I’ll have to dig up the name, but it worked pretty well. It allows for a big enough hole to route connectors and closes back up to a reasonable harness diameter.
Richard454
10-10-2018, 04:58 PM
I used one from a junkyard (OK- my parts car in the garage!)-
Here's a couple of ways-
https://www.diyautotune.com/product/seals-it-grommet-1-00-split/
157356
Here's another-
https://www.diyautotune.com/product/weather-pack-22-position-bulkhead-connector-kit/
157357
absintheisfun
10-10-2018, 05:12 PM
I have a 67 camaro. The main body harness is going through the factory location by the steering column, but im at a loss for what to do about the engine harness for the fitech system. Im up for any ideas.
GoodysGotaCuda
10-10-2018, 05:33 PM
I have the seals-it, works pretty well. It's about the only game in town to pass through giant connectors.
absintheisfun
10-11-2018, 06:07 PM
Anybody run the ecm in the engine compartment? How did you hide the wiring? Im just trying to get ideas/options. A passthrough would clean it up quite a bit, but im curious about running it in the engine bay as well.
Thanks to the idwas so far. Ive considered the seals it, but havent seen the connectors.
Build-It-Break-It
10-12-2018, 12:06 PM
I'm going to use the ones in the link below. They're about the 8th item down the page. They're the most affordable bulkhead and make engine removal easier. You use regular wire terminal crimpers so that makes them more affordable.
https://paradiseracing.com/page/2/?post_type=product&s=Harness
Dark Pursuit
10-12-2018, 02:42 PM
What harness for FITECH ? I was planning that as a future upgrade, But I am all out of under dash space !
But Also to your point--> I added spade connectors to empty slots of the bulkhead connector to add some of my engine area wiring.
absintheisfun
10-12-2018, 04:39 PM
That looks really good also. Thanks for the idea
Warthog5
05-29-2019, 09:23 PM
I used these........ https://www.johnnylawmotors.com/catalog/power-electrical-systems/firewall-solutions/firewall-ports/KICFWALL/billet-firewall-wire-port
https://static1.pt-content.com/images/pt/2019/05/750-1.png
Tsaints1115
05-30-2019, 07:02 PM
An inexpensive item that makes a nice firewall grommet is a gladhand gasket used for semi truck. They're cheap and can pass a 2/0 cable through the hole.
mc1984ss
10-24-2019, 06:06 AM
Here is another low cost option I just came across.
https://ceautoelectricsupply.com/product/large-firewall-grommets/
Erviner
10-24-2019, 06:57 AM
Are these solutions reliable enough?
Rolling_Thunder
02-23-2020, 01:56 PM
I use Mil spec MS3470 connectors - Large bulkhead connectors I use the 32 pin style - Smaller ones I use for things like wiper motors and what not.
downside is the cost
https://static1.pt-content.com/images/pt/2020/02/42-1.jpg
eville
02-23-2020, 02:16 PM
And the cost of the tools to crimp
Tsaints1115
02-23-2020, 05:46 PM
A tool that will always come in handy though.
Rolling_Thunder
02-24-2020, 01:02 PM
Yeah - that for sure is a kick in the junk. I actually got mine at a yard sale for $10 since no one knew what it was used for.
eville
02-24-2020, 04:47 PM
That’s pretty good. I paid about $200 on eBay and thought that was “decent”
