    Results 1 to 2 of 2
      Sep 2016
      LA - Lower Alabama
      Wiring Column Dimmer Question
      I bought a rebuilt tilt column with the dimmer on the column from Jim here on the boards. Now I'm trying to figure out how to wire the dimmer. All I can figure is I need to de-pin the factory dimmer plug (see first pic below), and I'm guessing the wires should go into some of the empty holes in the factory harness that plugs into the column (second pic below). If so, is there a diagram showing which wires go to which pins?
      Jim tells me it plugs right in the side, but there aren't any plugs that the factory dimmer harness matches.
      Dude are you made of leprechauns? Cause that was awesome!
      Sep 2016
      LA - Lower Alabama
      Just to close the loop on this, the column I was sent was not configured for the dimmer on the column. At this point, I think I'll just keep the dimmer on the floor rather than pull everything apart again and send it back. Disappointed to say the least, but it is what it is.
      EDIT: I should mention that Jim did offer for me to send the column back and he would fix it. Just not sure how long it would take.
