kiwipip
09-05-2018, 12:11 AM
Hi I'm based in Auckland New Zealand and as the title says I have a 65 Impala that is the final stages an LS Conversion. I was lucky to have purchased a straight and rust free 65 Convertible, It was a genuine SS Big Block Vehicle with Aircon. My brief to Mike Barry from NXT Level Automotive was to the untrained eye the vehicle is to look stock, Air Ride suspension and wicked stance, the engine bay to be detailed and uncluttered.
I researched online and thru various forums imported all the goodies and delivered all the parts and the Vehicle to Mike, to say Im delighted with the result is an understatement.
The vehicle has had the following:
Air Ride suspension from Ride Tech
LS3 Engine Holley Sniper Intake and Cam and Injectors
Willwood Discs all around
Hydrotec Brakes with Wilwood Master
New LSD Diff
New Fuel Tank and intake Fuelpump
Eddie Motorsports serpentine pulley system
Eddie Motorsports hinges
Dakota Digital dash
A Clean Vehicle to start with
https://static1.pt-content.com/images/pt/2018/09/DSC01158_zpsmku1eqjo-1.jpg
I suppose what you would call the before pic
https://static1.pt-content.com/images/pt/2016/11/DSC01166_zpsqhcbtciy-1.jpg
Parts arriving for conversion
https://static1.pt-content.com/images/pt/2018/09/IMG_6777_zpszmqw8lhe-1.jpg
Motor and exhaust installed and test fitted prior to pull down
https://static1.pt-content.com/images/pt/2018/09/imagejpeg_2206_zpsdzzxc5cp-1.jpg
Rather than bashing the transmission tunnel it was cut and a modified tunnel fabricatedhttps://static1.pt-content.com/images/pt/2018/09/imagejpeg_2205_zpsmysava74-1.jpg
https://static1.pt-content.com/images/pt/2018/09/imagejpeg_2205_zpsj1dfgaaj-1.jpg
Engine painted Bright Red . Running hidden coil packs so using SBC Valve Covers and adopters so new oil fill had to be madehttps://static1.pt-content.com/images/pt/2018/09/IMG_0026_zpst5szqbic-1.jpg
https://static1.pt-content.com/images/pt/2018/09/IMG_9889_zpsciaytfry-1.jpg
Strip down getting ready to remove of chassis and clean up fire wallhttps://static1.pt-content.com/images/pt/2018/09/IMG_9243_zpsygbyvxnz-1.jpg
Chassis Powder coated
https://static1.pt-content.com/images/pt/2018/09/IMG_0023_zpsfo6upjsl-1.jpg
Firewall Cleaned up
https://static1.pt-content.com/images/pt/2018/09/IMG_0024_zpsqsq4ydhg-1.jpg
Motor meets chassis
https://static1.pt-content.com/images/pt/2018/09/IMG_0139_zps9f0wkfbr-1.jpg
Hard lines plumbed
https://static1.pt-content.com/images/pt/2018/09/IMG_0311_zpsck4g9jec-1.jpg
https://static1.pt-content.com/images/pt/2018/09/IMG_0144_zpsdab6ymph-1.jpg
Body Meets Chassis
https://static1.pt-content.com/images/pt/2018/09/IMG_0149_zpse1kmxawu-1.jpghttps://static1.pt-content.com/images/pt/2018/09/IMG_0152_zpselpwy0cr-1.jpg
Looking more like a finished product, Happy with the new stance
https://static1.pt-content.com/images/pt/2018/09/IMG_1883_zpsnxgltkrw-1.jpg
https://static1.pt-content.com/images/pt/2018/09/IMG_2329_zpsfsdcz7ar-1.jpg
Air Intake fabricated
https://static1.pt-content.com/images/pt/2018/09/IMG_2326_zpselizpnin-1.jpg
Because I was using SBC Valve covers with the pre drilled oil filler and breather holes fender emblems were milled to fit
https://static1.pt-content.com/images/pt/2018/09/IMG_2349_zpskhcdeucq-1.jpghttps://static1.pt-content.com/images/pt/2018/09/IMG_2350_zps8ztkskfw-1.jpg
Air Intake and radiator fill panel colour coded to match car. Coils hidden below The vehicle is in the final stages computer being installed under passenger seat so the engine remains clean and uncluttered
https://static1.pt-content.com/images/pt/2018/09/38D07F054E6F4E23A38E266E21630CBE_zps9mr7-1.jpeghttps://static1.pt-content.com/images/pt/2018/09/117CDAE3DECD44E284A37912E9470AA6_zpsv8hm-1.jpeg
a bit of before and after
https://static1.pt-content.com/images/pt/2018/09/Screen20Shot202018081320at208310620PM_zp-1.png
New LSD Diff
Dakota Digital dash
Firewall Cleaned up
Motor meets chassis
Hard lines plumbed
Body Meets Chassis
