View Full Version : Piping fabrication finally completed!
twinturbo69
08-16-2018, 01:43 PM
I've finally got my hot and cold sides fabricated. Any good recommendations for a local shop for ceramic coating work here in SoCal, preferably in the Inland Empire?
155635155636
65 drop top
08-16-2018, 08:45 PM
Embee in Santa Ana. Nice job on your car too.
twinturbo69
08-20-2018, 03:44 PM
Thank you!
speedfreak391
08-28-2018, 10:55 AM
Looks great!
tigerracer
08-28-2018, 07:16 PM
Try Young Guns in Rancho Cucamonga for coatings
twinturbo69
08-29-2018, 09:40 AM
Thank you!
1Bad Ls
09-09-2018, 03:55 AM
Nice build! I’m building the same thing 69 with twin turbos what size engine and turbo?
twinturbo69
09-10-2018, 02:21 PM
Thanks! Motor is a 383 with Dart Pro 1 heads and FAST efi. Turbos are Turbonetics T04B (60mm) and running a two-stage boost controller. I plan to run street trim around 8-10 psi and my track tune is 15 psi. Made about 750HP/750tq prior to reworking the hot side to flow better, I anticipate putting down around 800 which is about as much I want to throw at the original GM block but should be enough power for the street. How about you?
sam 74
11-19-2018, 05:12 PM
looks good, I'm about to start my hot and cold side plumbing.
therobski
01-12-2019, 03:27 PM
That's really nice I wish I had the skills to do that fab work...
mklinger
01-13-2019, 09:51 AM
Looks good. Curious on your plan surrounding the brake booster / master. Piping looks a tad tight back there.
twinturbo69
01-14-2019, 09:51 AM
Yes the downpipe interferes with the stock location. Putting in a reverse swing mounted Wilwood setup with the master cylinder inside the car with a remote fluid reservoir located on the firewall. Brakes are Wilwood four pot on all corners and currently manual. In the future I might consider going with a hydra boost if I can make it fit.
