View Full Version : FiTech "ECU no response"
TEDDYGT350
08-05-2018, 08:34 AM
I am having trouble getting my FiTech up and running. Ford small block, FiTech EFI, MSD 6. The handheld is working but when I go to initial setup I get "ECU no response". I have a separate wire direct to battery for the +12 volts, the white wire (key) has +12 volts in the on and start position, also tried a separate ground wire from battery to throttle body. The shop that built the motor dyno'd with the FiTech so I am thinking it must be something I have done or not done. Any suggestions?
bishop
10-17-2018, 04:07 PM
Do you have the key turned on? You want to turn it on as if to start. Now the unit has power and can talk to the computer.
Bob
minendrews68
10-18-2018, 05:35 AM
what bishop said. If that's now the fix, call FiTech.
WallaceMFG
10-18-2018, 06:52 AM
Sometimes the handheld in our car needs unplugged from the EFI to restore communication. Give that a try before you go too far.
TEDDYGT350
06-08-2019, 09:42 PM
Thanks for the help. Got my car running. It was running rich so I adjusted the IAC steps (drivers side screw) down to approx 6, still running rich. I noticed that there are two idle adjustment screws, one on the drivers side and one on the passenger side. Do I have to adjust both?
minendrews68
06-14-2019, 10:11 AM
Look at your ecu settings before you start messing with the efi. Again, maybe call FiTech.
