View Full Version : 700hp tire selection help!!!?!!
1sikride
07-16-2018, 03:28 PM
Hey guys.
Car is dyno’d
https://instagram.com/p/BlGyLeCFBqefjEumy3P2rh3D4bXX2BK7oLa5GE0/
Now I need new rubber...
Car is on 18’s
285/40/18 I’m pretty sure is the target size
P zero?
sport cup 2
nitto 555?
street use. Occasional drag strip.
No track or course time.
Straight line. No rain.
And somthing that should last
a couple seasons. Nothing that dies
in 1000km...
recommendations please.
USAZR1
07-16-2018, 03:41 PM
What size do you want to run, on the rear?
1sikride
07-16-2018, 03:45 PM
285/40/18 - ish
xavier296
07-16-2018, 04:42 PM
Toyo R888 was the only tire I have ever used that hooked up with that much power. I used them on a track occasionally, and sold the car with good rubber still on them. I personally dislike Nitto 555s, but it has been a few years since I experienced them.
I am considering putting Sport cup 2s on my 550 hp car, would love to hear impressions from these smart folks.
USAZR1
07-16-2018, 09:21 PM
Harnessing 700hp with a 285 street tire might be more than a little optimistic. Just a suggestion but I would look at the Nitto NT05's.
sheck44
07-18-2018, 02:50 AM
LOL ... 700 on a 285, not a chance, just cross your fingers and pray !!
I had 900 using 325's and would light up the tires in 4th doing 60mph
Steve
1sikride
07-18-2018, 06:01 AM
What’s the widest tire I can get
On a 9.5 wide rim?
Typhoon1015
07-18-2018, 07:32 AM
I have pretty good luck with the current top 200TW brands and my 800+WHP car. Rival S and Bridgestone RE71R. They are super soft compounds and besides slicks/DR's and the R888 probably the best options for a 18 inch high HP tire. Of course you can employ some power management and right foot management to help with traction limited situations, but as far as tire selection go with the above mentioned imo.
killer69
07-18-2018, 09:41 AM
:rotfl::rotfl::rotfl:
Next question please
USAZR1
07-18-2018, 02:20 PM
On a 9.5 wide rim?
Anything wider than a 285, is probably pushing it on a 9.5" width.
1sikride
07-21-2018, 05:51 AM
What about the MT street radial 2??
Agne1982
07-31-2018, 11:56 AM
either it is 700hp or 800 hp, we can use same tires, am i right? thanks Fried Eggplant Infused in Herbs (https://delicerecipes.com/fried-eggplant-infused-in-herbs/)
1sikride
07-31-2018, 01:13 PM
155164
andrewb70
08-02-2018, 08:32 AM
155164
I was about to recommend those. I got 3 years out of my last set. That includes three trips to LSFest with drag racing, although they showed chords at the last LSfest. They were toast. If you are careful, you should easily get 10K miles out of them. Tire wear is directly proportional to your right foot!
1972Mach1
09-17-2018, 12:43 PM
I know it's a bit of an old thread, but I'm new here. I've got 285/40 on 18x10s on my Mach 1 (dyno'd at 673 HP and 748 ft.-lbs.) and I can tell you that anything less than drag radials is going to be fun for sure, but futile....My regular Nitto 555s light up at anything under 60 mph with my 3.90 gears. The Mickey T's are the best set of drag radials out there, they've been much better than the old BFGs and Nitto 555Rs I've ran before.
shelteredchevelle
09-17-2018, 04:31 PM
My CTSV is 713 whp and I am currently running PSS' ,and have run Sport Cup 2 also. Traction is futile. Period. You can get a 305 on a 9.5 inch rim, just get some DR's. Mickey T. is your friend. I am running a R888 345/18 on the Chevelle with a set of Mickey T's on a spare set of rims for when it counts.
