View Full Version : 59 Apache/c6 Corvette build thread
tdishon
06-20-2018, 02:22 PM
So I have built a few resto-mods in the past and just sold my twin turbo & supercharged Grand National and am ready to move on to my next project that will be my passion. As I'm getting older I have been really loving old trucks... So I thought I would spends a couple years building a 59 Chevy Apache with all Corvette C6 Grand Sport and ZR1 components.
I live in Arizona and sourced a good body.
153702153703
tdishon
06-21-2018, 07:52 AM
Progressive Chassis showed up:153710
tdishon
06-21-2018, 07:53 AM
unboxed and Corvette Cradles installed153711
153712
tdishon
06-23-2018, 08:43 PM
Drive train installed. Set engine back about 2", but torque tube still too short.153826
tdishon
06-23-2018, 08:44 PM
Fabbed up motor mounts to move engine back to clear blower pulley from rack.153827
Motoracer838
06-24-2018, 05:00 AM
Your off to a nice start, good luck with your project.
Joe
lilian
06-24-2018, 05:01 AM
nice work, !!
dhutton
06-24-2018, 05:45 AM
http://www.c5-c6torquetube.com
Very cool build.
Don
tdishon
06-24-2018, 06:47 PM
Yep, Gamel street rods took care of the torque tube. They installed a larger drive shaft and ZR1 couplers.
I'm a couple months behind with pics.
01blacks4
06-24-2018, 07:35 PM
very cool!...
im doing the same thing with a '10 vette into 70 firebird. also in AZ... im in chandler, where are you located? lets exchange notes and ideas! marc
01blacks4
06-24-2018, 07:36 PM
ha!! I just saw your using progressive stuff also...thought it looked familiar :) they are good guys and
Gamel street rods !
tdishon
06-25-2018, 07:46 AM
01blacks4: pm sent
tdishon
06-25-2018, 07:48 AM
Thanks for the positive feedback!
Looking forward to a unique build.
tdishon
06-26-2018, 08:34 AM
Cutting out the old dash and putting in the 59 Impala dash. It was about 4" too wide. decided to take it out of the middle to line up the steering column with the factory location(hole in the floor).
153948
153947
153949
tdishon
06-26-2018, 08:54 AM
Moved dash forward about 2 more inches.153950153951153952
blade
06-26-2018, 11:01 AM
nice build, can't wait to see how this one goes!
egoman
06-26-2018, 06:05 PM
I too am using the stock front suspension cradle from a C5-C6 corvette. I have to fab my top rails and could use some measurements from you. If that is ok with you these are what I need.
1. Face to face of the upper mounts across the top.
2. Angle of upper control arms.
3. Height of the upper control arms compared to a set spot on the cradle.
4. static caster.
I can provide a drawing of what I want in the next few days if that would make it easier.
tdishon
06-27-2018, 07:13 AM
Egoman- PM sent
egoman
06-28-2018, 06:23 AM
These are the measurements that I am looking for.
A is the degrees of the upper control arm
B is the distance between the mounting surfaces on the opposite sides
C is the distance from the center of the forward mounting bolt to the center of the control arm attaching bolt.
D is the vertical distance from the top of the sub-frame to the center of the control arm attaching bolt.
E may be redundant but its the distance from the top of the rear sub-frame attaching point to the center of the control arm attaching bolt.
tdishon
07-02-2018, 08:04 PM
Egoman: To the best of my ability
A= 5 degrees
B= 35-1/2"
C= 2-7/8"
D= 6-3/8"
E= 8-1/4"
Hope this helps
egoman
07-02-2018, 08:27 PM
Gives me a starting point, and if it allows me to get a setup that I like then it is perfect.
Thank you for taking the time!
tdishon
07-05-2018, 07:10 PM
Thought I would spend some time on the brake lines. Progressive set up the under cab mount for a 7" vacuum booster, but I decided to go with a hydroboost so I cut out the mount and had a modified one water jetted out and moved the location a little to take advantage of the frame cut out.
jschmidt97306
07-06-2018, 05:38 AM
Very Nice!
SpaceCadet
07-06-2018, 12:19 PM
I know this is my first post, but looked like you need some help... so I finally made an account.
A: 6.57deg
B: 37.244" (945.99mm)
C: 3.410" (86.63mm)
D: 6.455" (163.96mm)
E: 8.484" (215.50mm)
Sending you a p.m.
tdishon
07-06-2018, 01:21 PM
Egoman: SpaceCadet has the accurate measurements. I was close, but no cigar...
andrewb70
07-06-2018, 02:09 PM
Cool build!
egoman
07-06-2018, 08:50 PM
Thank you for the time and the measurements. I have a small amount of stuff to complete before I start my build thread in earnest.
tdishon
07-07-2018, 08:28 AM
I see where one of my measurements was off(B). I measured from the inside of my frame rails. After studying the picture of the factory frame rail...big difference.
tdishon
08-04-2018, 03:29 PM
Getting the door gapping done and rounding the front corner of the door.155294155295
FLYNAVY53
08-05-2018, 05:51 AM
very cool build
tdishon
10-09-2018, 09:04 PM
Been a while for updates.
Chassis is ready to have the cab mounted and trial fit everything.
I had a couple renderings done to get an idea of wheels, colors and grill.
Here is what I have so far:157329157328
skylark guy
10-10-2018, 06:23 AM
I love the second rendering. Very cool build!
tdishon
10-29-2018, 06:07 PM
Finally kissed the cab to the chassis. Time for firewall work. I cut out the small hump and will recess it about 3".157905157906
tdishon
11-09-2018, 11:42 AM
Well, I am working with Bob at Progressive. They made an honest mistake and my wheelbase is 110", not 114". The step in the picture is pushed up to the cab. The fender and step still need to be moved rearward another 1".
I had a good conversation with Bob and worked on putting everything on the front to make sure it all mounted together. Fit great. The side rails to the rear are just short 4". Extending the frame will be the easy part. It's the torque tube that will be the pain. It will take about a month with the turn around times on shipping to be back on pace.
- - - Updated - - -
Bob and I worked things out (great guy to deal with!)
I have the chassis on the frame machine. The front was just a little off so we pulled it level and now adding in some cross members. Next, we are getting the frame set up for a little lengthening in the rear.
windows
11-10-2018, 08:03 AM
Are those 19" wheels on the rear?
tdishon
11-10-2018, 03:10 PM
Yes, 19" in the rear and 18" up front. I think the front need to be 19" too or more sidewall.
windows
11-12-2018, 02:18 PM
I just have used/mismatched mock up tires on mine and the 18” fronts with more sidewall look way better than the lower profile 19” on the rear. I intend to change the rears to a higher profile on the rear. Btw, your build is looking very nice.
www.pro-touring.com/showthread/117557-56-chevy-pu-C6/C5/LS (http://www.pro-touring.com/showthread/117557-56-chevy-pu-C6/C5/LS)
tdishon
11-19-2018, 10:31 AM
I agree. More sidewall the better on the 18". I'm going to try a larger tire on the rear and see what she looks like or go to an 18" rear too.
LERM
11-19-2018, 11:54 AM
Killer truck. Love the dash swap. Chassis is pretty drool worthy as well.
tdishon
11-19-2018, 07:32 PM
Here we go. Bob(Progressive) sent me some matching 2"x6" frame rail so I could extend the chassis. Today we built the inner sleeves to make sure that the extension will probably be the strongest part of the frame. Tomorrow we should have this completed, then torque tube comes out to get lengthened at Gamel Street Rods.158426158427158428
tdishon
12-12-2018, 02:09 PM
Frame extended, Torque tube off to Gamel Street Rods. So I though we would tackle the firewall. We went a little tighter on the driver side for gas pedal room...159144159145159146
ed1le
12-13-2018, 10:09 AM
Very cool build. Nice work!
Sbeck09
12-13-2018, 06:10 PM
Super cool another AZ truck build! I like your choice in body and frame components. This thing should move well.
Feel free to give a shout if you need a helping hand. I'm over at 35th ave/Peoria.
injcted
12-14-2018, 05:41 AM
Such a cool build! Waiting for more updates.
tdishon
12-14-2018, 07:42 PM
Sbeck09: I may bug you since your in the area:-)
tdishon
12-14-2018, 07:46 PM
Some more updates today. Still have metal work to do on firewall, but we are getting it things closer. Waiting for the torque tube to make it's way back from Gamel to make sure the engine is in the exact spot before finishing firewall.159200159201159202
glitchz24
12-18-2018, 10:49 AM
Love the build thread! My favorite style of truck too! I’d throw out my daily if I had a reliable LS powered Apache to cruise in!
tdishon, I have a question for you. I’m doing a similar C5/C6 suspension and drivetrain build into a 73 Challenger with a Viper V10 engine. I’ve got my full drivetrain ready to go, and the shell. Now I’m laying out the framerails. I’m using the stock Corvette subframes although I may narrow them slightly. Can you give me an idea of how they bolt to the frame? Are there bushings required? It sure seems to me the holes in the subframe are much larger diameter than the bolts which would allow for a lot of slop if there aren’t any bushings or something similar.
Rex
dhutton
12-18-2018, 01:44 PM
Rex
Not to hijack but have you seen these:
http://rick486.wixsite.com/dobbertinperformance
Don
glitchz24
12-18-2018, 02:07 PM
I have, and they seem pretty slick, but IMO I’d rather build something than pay someone else to build it. Yes time spent at it will make up for the $ difference, but I’ve got free time in the evenings and weekends.
tdishon
12-18-2018, 03:22 PM
The bolts that hold the cradle to the frame are pretty large. I can find out the threads later, but the length varies from 9 1/2" to 12 1/2" long. The frame has sleeves from the top hole down to the bottom of the from for the bolts. this makes it incredibly strong and zero slop. and there are guide pins and each side so the frame has the guide pin hols too.
Hope this helps.
dhutton
12-18-2018, 03:25 PM
Ok here are some fabricated adaptors that might give you some ideas:
https://www.progressiveautomotive.com/installations-kits-parts/c5c6-corvettefrontrearkit.html
Don
tdishon
12-18-2018, 04:02 PM
Yep, Progessive has the stuff. They built my basic chassis and I am in the process of fitting everything, cutting, fabbing mounts for everything and adding some cross members.
Bob at Progressive is great to work with.
glitchz24
12-18-2018, 07:06 PM
Thanks Tdishon, when I started laying stuff out I bought a corvette frame section that had the bolts attached, I believe they’re 14mm (about 9/16”) if I remember correctly, my curiosity is that the holes in the subframes are closer to 3/4”. Just seems there would be play between the two even with the alignment dowels. Wasn’t sure if I was missing a sleeve/bushing for the subframe portion, but perhaps it’s solid under torque and the alignment pins do all the centering necessary.
I’ve looked into progressive also, they would probably be who I’d use for any parts I decide not to build myself, there’s also:
http://www.streetrodgarage.com/universalc5z06corvetteuppercontrolarmmountplate.as px
Who make an upper control arm mount plate as well as full subframes.
I recently acquired a CNC Plasma, and am hoping to make some of these type parts myself, but we’ll see.
Anyway, I’ll stop detailing the thread, I look forward to more updates!
tdishon
12-19-2018, 05:21 PM
glitchz24: I don't have the original corvette frame sections. I see what you mean. The originals might be a loose fit. The frame from progressive was a different animal all together. The welded in tube(crush) sleeves were very snug with the bolts. No slop.
796spdbu
01-02-2019, 05:06 AM
Cool Build! Those Task Force era trucks are one of my favorites.
Good Luck with the build!
tdishon
01-16-2019, 12:07 PM
Finally have the front end all lined up and ready to make more attractive core support mounts.
lxg44
01-17-2019, 04:57 PM
Really nice build! Subscribed
Workinman
02-25-2019, 06:15 PM
SpaceCadet, do you have the same specs for the C6 rear?
SpaceCadet
02-26-2019, 02:36 PM
I do, will shoot you a PM.
qnitro
02-26-2019, 07:54 PM
great project
dhutton
06-08-2019, 05:46 PM
Any updates?
Don
tdishon
06-13-2019, 04:11 PM
Sorry for the hiatis...
Finally back on things. Chassis was off a little bit so we had to take the cab mounts off the pass side and zero in the cab and front end assembled before welding back on the mounts.
Well, mounts and and the front mounts are tacked on too. Everything is lining up nice now and centered...
Here are current pics.
Motown 454
06-13-2019, 04:39 PM
It looks great, Sweet project.
dhutton
06-13-2019, 04:42 PM
Looks good, can’t wait to see it painted.
Don
Sbeck09
06-13-2019, 09:01 PM
Dear god that rear end shot is NSFW! This looks monstrous compared to my lowly Mustang IRS. I'm liking what I seeing. Keep up the good work!
Also just realized you're in Phoenix too...small world. We gotta get a truck cruise together when our trucks are done.
qnitro
06-18-2019, 11:29 AM
Don
Don you have to get yours done... this thing is awesome
tdishon
06-18-2019, 03:57 PM
A local cruise would be great. This build is a slowwwww project. As you can see by my time line. Hoping to have it running by the end of the year though.
tdishon
08-19-2019, 01:58 PM
Here are some updates. Slowly coming together. I bought the corvette wheels and wanted to stick with the Corvette Z06 factory wheel size and offset. I have to split the rear fenders and add about 1-3/8".
Here is the Mar-K bed coming together. raising the floor about 4-1/4" too.
tdishon
08-19-2019, 06:52 PM
More progress today:
tdishon
10-14-2019, 09:51 AM
I have built a few Corvettes over the years and love the cove(bullet) on the side. I want to keep this truck 50's with the 59 Impala dash and decided to see what the Corvette cove would look like on the side.
I didn't like it so I thought I would see what it looked like with just the Spears behind the front tire and the same color as the body. I like it.
I changed my mind on the color combo too...
Thoughts?
tdishon
06-24-2020, 03:48 PM
Here we go. Getting busy on this project again. Bed mounted and fenders widened. Step is a little work. Also came across a nice 51-52 Cadillac front bumper. Going to work this in.177163177164177165177166177167
wfo guy
06-24-2020, 05:47 PM
Nice to see progress again. Is this a side project of your shop?
David Sloan
06-25-2020, 02:53 AM
love these ol trucks
Very nice build i'm in for updates
Sbeck09
06-25-2020, 09:10 AM
Those renderings look soooo good! I don't think I like the splash of red behind the front fender, but all the others look amazing!
tdishon
07-14-2020, 03:08 PM
This is my buddies shop. Work is slow going on her, but I am getting progress now.
I am working on new renderings. I have changed course a little with the front bumper and grill. Going to use a 1951 Caddy front bumper and blend a GMC and Chevy grill.
here is a pic of the rear fender peeking out just a touch.
tdishon
07-23-2020, 07:18 PM
Getting bed floor situated. Need a 4" floor lift and decided to have a tilt up floor.
I had my old tailgate and thought the script would look good on the back of the floor lift.
tdishon
08-01-2020, 01:51 PM
The bed floor is making some progress.
tdishon
08-22-2020, 05:40 PM
Tilt bed framing done and working. I have several rubber adjusters in several places that keep all squeeks away.178732178733178734178735178736
TANKMASTERJ
08-29-2020, 07:40 AM
That's beautiful. I love the Apaches. Used to have a. 55 stepside I started and never finished. I miss that truck
TANKMASTERJ
08-29-2020, 07:43 AM
I love the silver or titanium color. What about matte black on cab corners?
Jason
tdishon
11-10-2020, 08:41 AM
Bed floor dialed in and done. Ready for wood. Added 60lb gas struts to lift and keep from lifting all the way up. Quick disconnects make lifting all the way up easy. I kept the gas helpers on the hinge, they keep it straight up when I remove the long struts. I added in tunnel clearance on crossmember for the torque tube(drive shaft).
qnitro
11-16-2020, 08:18 PM
Man that is awesome
wfo guy
11-17-2020, 06:42 AM
Is the bed floor for maintenance purposes or to allow people to see your work? A page ago, you asked for comments on the corvette cove. I think that would be a real nice addition to the truck. I wasn't fond of the red but have no thoughts on another color. No question, this will be a heck of a truck when finished. :)
tdishon
11-18-2020, 03:45 PM
O wanted a bed floor that lifted, but was completely unnoticable when closed. I need it to fill the tank and to show off the drivetrain. Well, all maintenance too.lol
Dragonfly
11-22-2020, 05:23 PM
That is an awesome project , very cool and nicely executed. As far as all the renderings that you have , I liked the robins egg blue , the very first ones that you posted. I think that looks awesome and keep the four headlights in it
Peanut1959
11-23-2020, 07:49 AM
I agree. First rendering looks like a winner to me!
Benttube
11-23-2020, 05:27 PM
Mind me asking where the bed wheel tubs came from?
tdishon
01-17-2021, 04:40 PM
The wheel tubs are off a fleetside inner tubs. Just cut them down.
Update:183548183547183549183550
dhutton
01-18-2021, 05:57 AM
Awesome build.
Don
TANKMASTERJ
01-23-2021, 09:54 PM
I love it. I had a. 55 for me and 57 for my wife. Sold both . Mine before finishing bees before starting. I regret selling both. Now neck deep in my 67 Camaro that must be finished
tdishon
02-11-2021, 10:28 AM
Exhaust time
184718
tdishon
10-09-2021, 10:24 AM
Been a while since an update. Here we go:
192537192530192534192531192535192532192536192533
Lots to update: New wheels. Not powder coated yet. Rear fenders widened and front close to dialing in the widened fenders. Hammer Fab has been kicking some butt!
aeroocoupe
10-09-2021, 03:36 PM
Sick build, love seeing pro-touring trucks
tdishon
10-14-2021, 07:36 PM
The front begins:
192767192768
Samckitt
10-15-2021, 05:15 AM
I love it. Great work
tdishon
10-16-2021, 09:06 AM
Here a few pics of the flares and grill progress.192855192856192857192858
qnitro
10-17-2021, 08:50 AM
man this is truck is awesome
214Chevy
10-17-2021, 01:44 PM
What he said...:cool::cool:
wfo guy
10-17-2021, 04:07 PM
I'm anxious to see the fender flares on. :)
tdishon
10-19-2021, 07:49 AM
Progress:
Alwhite00
10-19-2021, 08:52 AM
Progress:
You Sir do amazing work.
tdishon
10-19-2021, 08:56 AM
Thank you, but I cannot take credit. Levi Green at Hammer Fab has taken over this project to take it to the next level. Way out of my skillset. LOL. Out of the box thinking is a little risky, but I love the results so far.
thumper877
10-19-2021, 09:04 AM
Thank you, but I cannot take credit. Levi Green at Hammer Fab has taken over this project to take it to the next level. Way out of my skillset. LOL. Out of the box thinking is a little risky, but I love the results so far.I agree this will be a one of a kind build. Love it so far. Have u decided on a color yet
tdishon
10-19-2021, 09:16 AM
Leaning towards a gray blue or Toyota Calvary blue ish.
thumper877
10-19-2021, 04:01 PM
Like the middle one. That was the hardest thing for me to decide.
tdishon
10-22-2021, 06:40 PM
Fenders flared and holes/dents fixed. Could not be happier...
193058
thumper877
10-23-2021, 02:10 AM
193058Look amazing makes me want to go out and find a truck
tdishon
10-30-2021, 11:27 AM
Driver side fender done. Now on to remove the narrowed 59 impala dash we did a couple years ago. Then put in a 59 impala dash that is not narrowed. The steering wheel did not line up narrowing the dash. Now everything will line up correctly. We didn't have the Glide Engineering seat when we narrowed the dash the first time.
tdishon
10-30-2021, 11:29 AM
The narrowed dash looked good, but with the new seat in, the steering wheel was off center to the right about 2+". I just wanted to get it corrected while the time was right and Hammer Fab is doing a new firewall, so...
193578
wfo guy
10-30-2021, 04:10 PM
Looking good. :)
C Presley
10-30-2021, 09:59 PM
Dude, that is a Bitchin Build! The 59 Impala dash a very nice touch! Mixing the Old and the New giving it the right mix of Retro! Look forward to more updates. Excellent work!
tdishon
10-31-2021, 10:40 AM
Thank you Sir
tdishon
12-09-2021, 07:39 PM
Dash done. Lots of work on ashtray to hold A/C controls. But it is in and I like the dash not narrowed with the position of the seat now. The transition needed some work, but looks amazing now.194480194479194478194481194482194483194484
tdishon
12-09-2021, 07:45 PM
And the A/C controls in the ash tray. Very solid design and easy operation. The original was very flimsy and clunky.
tdishon
12-09-2021, 07:54 PM
Now on to the grill. Hammer Fab is blowing away my expectations!
mixing the GMC with the Chevy ends. The ends are enlarged to fill the space and will be blinker and cooling intakes.
wfo guy
12-11-2021, 05:44 AM
Good progress. I was surprised to see that he was brazing parts together. :)
tdishon
12-11-2021, 08:30 AM
I had asked the same thing. I guess the brazing is filler after the welding is done. Easier to work with after welding is complete. Wanted to reduce the amount of body filler in most places.
jaybee
12-11-2021, 04:38 PM
This is very cool. One of my favorite cars I know almost nothing about is from this generation of Chevy truck. I saw it at the Goodguys Des Moines autocross and it never sat still long enough to give it a good look. I believe, however, it was built over a C5 Corvette chassis by shrinking and unitizing the entire truck to fit the chassis. Black, extremely low, chopped, sectioned, and shortened so much the rear fenders were blended right into the cab. It featured 60's style SS script which read "Super Short." Sorry to hijack your thread but the car really made me appreciate these trucks for the first time and I'd love to know a whole bunch more about the "Super Short" if anyone is familiar with it.
Yours is going to a terrific, one of a kind build.
tdishon
12-20-2021, 07:44 PM
Progress
wfo guy
12-21-2021, 06:44 AM
Nice.
ryeguy2006a
12-21-2021, 10:20 AM
Wow, that fab work is amazing!! Just found this build today. Can't wait to see more!
tdishon
01-01-2022, 02:12 PM
Front getting dialed in. Lots of slicing and dicing the 51 Caddy bumper to fit just right.
GM Man
01-01-2022, 03:45 PM
Looks amazing!! Cant wait to see more of it, keep up the good work!!
wfo guy
01-01-2022, 05:47 PM
I like good metal work. :)
tdishon
01-13-2022, 06:41 PM
Baby steps. 59 Chevy V8 hood emblem or 55-57 GMC hood vent?195530195531
dhutton
01-14-2022, 04:37 AM
There is a lot going on there already. I would probably do neither.
Don
thumper877
01-14-2022, 04:38 AM
I agree with Don. I think it takes away from the work you have done. The bumper and grille are definitely the highlite.
tdishon
01-14-2022, 09:09 AM
I found this picture of a 59 with the gmc vent grafted on. I assume the GMC emblem will go in it and the spears removed.
jaybee
01-14-2022, 05:44 PM
I agree with the smooth hood idea.
Peanut1959
01-15-2022, 01:28 PM
The Chevy emblem looks oddly futuristic. I like it with your other grille mods.
Samckitt
01-15-2022, 03:28 PM
I would leave off the emblem, but if you are adamant on using on or the other, then the Chevy one.
wfo guy
01-15-2022, 03:48 PM
I don't think either of the choices will add to your truck. I don't have a good idea but encourage you to keep looking. Broaden the horizon as gets said. :)
tdishon
01-21-2022, 07:41 PM
Tailgate work.
jaybee
01-22-2022, 04:52 PM
You really brought a finished look to the tailgate area, a part of every truck from that era which is WAY primitive from the factory. I've seen quite a few treatments for that area on old trucks, and it's a place where every one can be a little different.
tdishon
02-17-2022, 03:05 PM
Doors are next.
Love the new door handles I came across. Knuckle pockets are next for the door handle. I know everybody has different tastes, but I was never a fan of the factory door handles.
Electric door latches off 2020 Corvette and Nu-relics power windows with factory looking interior handle switch for both door and window. #HammerFab
197128197129197131197130197132
wfo guy
02-17-2022, 04:23 PM
Nice. Will you have some kind of backup in case of battery failure?
tdishon
02-17-2022, 05:16 PM
Yes, the Corvette latches have manual levers in case of electrical failure. One on each side bottom of seat and one exterior for the driver side with a key switch under cab.
tdishon
03-05-2022, 08:43 AM
Door jams about complete. Boxed in the switch mechanism with access panel.
thumper877
03-05-2022, 10:56 AM
That is some beautiful metal work
tdishon
03-17-2022, 05:57 PM
On to drip rails. I love them and they create a nice body line that takes away from the German arm helmet look. So just making them look laser straight.198178198179198180
tdishon
03-17-2022, 06:06 PM
Bumper starting to come together and lower tailgate valance. Now time to work in exhaust and license plate into lower bumper. Looks too clean with no license plate and exhaust. That will all change... Also adding some weld-in tailgate anti-rattles that look good. #Hammerfab
198181198182198183198184
wfo guy
03-18-2022, 06:14 AM
Very nice. :)
tdishon
04-16-2022, 03:38 PM
Tailgate bumper bullet installed and front bumper dialed in. The ends turned our great. #HammerFab
199022199023199024199025199026199027199028
thumper877
04-16-2022, 03:47 PM
That is some quality workmanship there. Bumpers are tight. Looking amazing
C Presley
04-16-2022, 04:13 PM
Dude, that's just a Bad Ass Truck! Excellent Craftsmanship!
wfo guy
04-17-2022, 05:47 AM
Lots of good vision. :)
TANKMASTERJ
04-17-2022, 06:00 AM
As with all the other guys I'm digging the metal work.
It's looking fantastic.
Jason
tdishon
04-17-2022, 06:31 AM
Thanks for the feedback. The work is done by Hammer Fab in Liberty Hills, Texas. Best decision I have made in many years. I give feedback and what I want and these guys knock it out. This is way out of my skill set(unfortunately).
Alwhite00
04-18-2022, 09:08 AM
Bumpers are on point. (No pun intended) ��
tdishon
05-06-2022, 08:05 PM
Hood latch is beefy. Release lever is inside the cab.
199603199604
tdishon
05-06-2022, 08:08 PM
Time for the firewall...
199606199605
wfo guy
05-07-2022, 05:21 AM
Nice. :)
tdishon
05-16-2022, 10:26 AM
Door gap time. I think this is everyone's favorite thing(to avoid).
BrianP
05-17-2022, 09:02 AM
You definitely found the right shop to do your metalwork. They definitely have the right tools and skills to use them: that planishing hammer is humongous!! Using the silicone bronze rod to fill and smooth out the steel rod is a neat idea. Fabrication threads like these are my favorite because it is a great way to learn tips and tricks and come up with new ideas.
As far as the hood: Chevy emblem versus GMC vent….
Anyone who sees that GMC style grille will know that it is a GMC truck and wonder why there is a Chevy emblem above it. It would be like adding a Z28 emblem to a GTO.
Senek67RS
05-17-2022, 10:02 AM
199606199605
Bad ass build! Curious what valve covers those are, they look like the match the profile of the lid.
tdishon
05-17-2022, 05:32 PM
That's a tough one on the grill and emblem. The center section of the grill is GMC and the ends are enlarged Chevy. I can't stand he ends on the GMC grill. 58 and 59 didn't have the hood grill so we abandoned the idea. It's tough to pick a direction sometimes.
tdishon
05-17-2022, 05:36 PM
The valve cover covers and supercharger extension were machined my EVOD. They make it all look seamless.
C Presley
05-18-2022, 08:38 AM
Just a Bitchin Build! Very nice detail on every aspect!
BrianP
05-19-2022, 08:31 AM
Boy did I have a brain fart! I had it in my head that this truck was a Jimmy.
tdishon
05-23-2022, 09:59 AM
With the slimmer door handles, I wanted knuckle clearance.
Dodge383fi
05-23-2022, 11:50 AM
THAT IS NICE! Man I wish I could afford to have you work on my truck.
I assume when you welded that in you had some warping of the thin section between it and the large hole that needed to be flattened?
It looks like you can’t get a dolly behind it. How do you go about fixing that?
-Ed
tdishon
05-23-2022, 12:28 PM
-Ed
Excellent question. But since Hammer Fab is doing the metal work, I don't have that answer. These are the same knuckle pockets Levi Green at Hammer Fab put on their 58 Apache SEMA truck for 2019. They must have figured out either controlling warpage or a way to straighten.
tdishon
06-03-2022, 09:48 AM
When the bed floor is up, the rear section looked very unfinished and ugly. This panel looks right. #HammerFab
thumper877
06-03-2022, 11:12 AM
Those guys do some amazing metal fab.
tdishon
07-17-2022, 10:51 AM
Update: HammerFab has been moving to their new shop. Column and exhaust parts ordered. Waiting for the move to be complete and progress in August.
200988200989
Samckitt
07-17-2022, 01:14 PM
Love it, it's bad ass.
wfo guy
07-17-2022, 02:46 PM
This is another build that unless you know what was done, you would need a stock truck next to it to see what happened. Looking good. :)
C Presley
07-18-2022, 10:36 AM
Such a Bitchin Truck! Love the Stance!
72srcool
07-20-2022, 06:52 PM
Great project that took some extraordinary skills to get to this point. Keep up the good work!
tdishon
09-21-2022, 09:08 AM
I spent the day at HammerFab. Took some video and pics. We also discussed everything going on. Looking forward to the next step of new firewall and inner fender refinement. Got the column in the right spot and ordering the steering wheel. Exhaust is looking good/ Mufflers and resonators are from Stainless Brothers. Rear bumper is so clean, but making room for the license plate and still figuring out exhaust exit through the bumper.
tdishon
09-21-2022, 09:32 AM
No success on my video. The file is too big. Here is a video Levi Green did and my truck is in it.
https://vimeo.com/748363090/2ab2db72e9
tdishon
09-21-2022, 09:49 AM
Ok, I uploaded to Youtube. This link should work.
https://youtube.com/shorts/dXUmh28d2b4
tdishon
11-19-2022, 08:17 PM
Back to work: Dash getting more mods. Added another spot for the pass pwr window switch(Original A/C was in this area). It was off balance and bare. Inner fenders are getting finished. Exhaust is about done. Just have to figure out how we want to exit.
203533203534203535203536
C Presley
11-19-2022, 09:36 PM
Truck screams Pro-Touring! Gorgeous!
jaybee
11-20-2022, 04:30 PM
That's one fancy exhaust hangar!
tdishon
11-29-2022, 07:27 PM
Firewall about done with countersunk booster.
203759
eversaul86
12-01-2022, 08:44 PM
Sweet build. Nice work! Plenty of motivation for me, in my dreams!
Martin
Alwhite00
12-02-2022, 04:07 AM
Beautiful craftsmanship. Love it.
tdishon
02-22-2023, 07:20 PM
Getting close. 95% of metal work is complete. Grill has ducts for intake and transmission cooler. 3D printed until all bugs worked out, then off to get machined out of aluminum. Blinker is around the duct just behind the lip.
tdishon
02-22-2023, 07:33 PM
Working on intake to air box.
205805
wfo guy
02-24-2023, 09:08 AM
Nice thinking on the ducts. :)
C Presley
02-24-2023, 11:03 AM
Nice work Dude!
Mommy Wagon
03-17-2023, 03:15 AM
Love this combination……. Sub’d
iadr
03-25-2023, 11:58 AM
Beautiful work. Going to the video now.
IMO one tiny detail that should be "looked at" is the grill mesh- thats modern, too fine a mesh aesthetically. Hoping at most that is a mesh designed to "hide" the components behind it. And that you plan to put chrome fins or something across it? Something era-matching.
//edit- saw vid. Definitely needs a horizontal element. One thick one (1/2 aerofoil cross section), or maybe a pair- long and short, slightly thinner.
tdishon
05-15-2023, 09:56 AM
Been a while for updates. Front is coming along nicely.
207527207526207525207524
thumper877
05-15-2023, 11:38 AM
Truck is looking awesome. Going to be a world class truck for sure. They are doing incredible work
tdishon
06-12-2023, 09:41 AM
Progress on air intake, trans cooler, brake pedal support and gas pedal mounting.
207926207927207928207929
wfo guy
06-13-2023, 05:21 AM
Very nice. :)
dcozzi
06-13-2023, 05:50 AM
Looks like you got it near 56th St/Sweetwater?
Those houses always have all sorts of vehicles sitting in the horse property out back.
tdishon
06-13-2023, 07:40 AM
I picked it up in Gilbert. It was a horse property and the guy collected old trucks. Probably had about 30 of them.
I went back for some parts a couple years ago, but he had passed and everything was gone. I think it was called Johnny's Junkyard.
tdishon
06-28-2023, 07:21 PM
Getting some pics done for a poster in its current state. Still need the impala taillights and other things, but she looks good in bare metal.
208106208107208108208109
Gil
07-02-2023, 10:25 PM
looks very good imho... sexy... Very well done sir !
wfo guy
07-04-2023, 05:00 AM
Very nice. :)
tdishon
07-17-2023, 10:25 AM
Brake pedal assembly about dialed in.
208384208385208386
C Presley
07-17-2023, 01:28 PM
Just Bitchin!
tdishon
08-02-2023, 12:44 PM
Engine bay getting closer.
wfo guy
08-03-2023, 03:12 AM
That will be an engine bay that you will want the hood open on. :)
tdishon
08-14-2023, 08:03 AM
Looking for input on exhaust exiting.
A or B?
B might be changed up a lil. Just trying to figure out a direction.
208729208728
ryeguy2006a
08-14-2023, 08:51 AM
That's a really tough call since they both look really good. I went back and forth and each time I was thinking the picture I was looking at was the best. I don't think you'll go wrong with either choice, but B is way more unique and to me matches the theme of the truck. It's super clean.
thumper877
08-14-2023, 11:02 AM
Agreed custom truck your building deserves custom looking exhaust so B for me.But I also think either one looks good
Alwhite00
08-15-2023, 05:07 AM
That's one fine 59. Craftsmanship is beautiful. I vote for B on the exhaust. It drives home the Corvette aspect.
tdishon
08-21-2023, 09:29 AM
Well, it looks like wrapping the gas tank with exhaust is about the only way to do exit by the license plate. Decided to un-complicate the exit. In the options with the exits on the outer bumper, the muffler is right in front of it. Well, we will figure out some cool machined tips. I didn't want to have turned down exits facing the ground. It really stirs up the dirt. Eh, its a work in progress. Thanks for all the input!
tdishon
08-25-2023, 03:39 PM
Getting closer:
3d scanning helps.
wfo guy
08-26-2023, 04:21 PM
I like where that is headed. :)
tdishon
08-29-2023, 12:46 PM
Taillight design. Based off 61 impala, but with back lit turn signal like the front vents. The lens will be 61 impala.
tdishon
09-13-2023, 11:04 AM
Great show in Nashville. Got to meet Chip Foose and Dave Kindig. Made the trip well worth it. Also got to see my truck and hang out with Levi Green. Very good trip.
209192
tdishon
10-09-2023, 09:18 AM
Time to get the interior figured out: Phil Cato is doing the interior.
Seat getting dialed in with the impala center. The emblem will be swapped out for a 1954 Pontiac chieftain emblem(Apache).
209678209677209679209680209681209682
wfo guy
10-10-2023, 08:35 AM
I like what I see. :)
tdishon
01-13-2024, 12:19 PM
Lots of updates: Electrical, Windows and door nu-relic switches installed with modified studs to accommodate the Chrysler inner handles that match the Impala knobs on the dash(who da thunk...)
Skid plate finished with tow hook, Inner fenders done. That was a big project to make nice and solid. Stake pockets bottoms finished. Rear suspension needed major beefing(before and after pic). Done. Ride height set and adjusted.
It's been a busy last couple months...Getting so close!
211664211665211666211667211668211669211670
wfo guy
01-13-2024, 01:09 PM
I don't remember, are you painting or leaving in bare metal?
tdishon
01-13-2024, 01:48 PM
I still can't decide. The bare metal looks so good. Interior painted and underside coated for sure. Engine bay satin black. Exterior?
TotallyHucked
01-16-2024, 09:11 AM
Man this is such a killer truck! I saw it just briefly at Triple Crown and it blew me away, wish I would've had more time to really look close but I had to get back to our booth
wfo guy
01-16-2024, 03:25 PM
I think the maintenance of bare metal might be worse than a really good paint job. But in my world, I grow tired of the "unfinished" look after a while. I have become my own worst enemy in regards to the finished product. My current project is my daily driver. I wasn't going to cut and buff. About 30 days in, I can see that after it warms up, that will happen. If you have done really good stuff, I find it tough to go backward. It's not about logic but about always trying to be better. I struggle more with color now than any other decision on a project. You have a great project. The decision to go forward or not I doubt will be easy. I hope the rest of your project goes well. I'm excited for you. :)
