    Results 1 to 11 of 11
      Modern style carpet molded to fit
      I am interested in puting modern short carpeting in my 67' Camaro. Does any place mold to fit other than what you would use on a restoration, (loop & shag)
      Peter
      Mountain Springs, Texas
      The Essex option from ACC and Trim Parts is likely the best option you will find.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Dec 2012
      What Don said ... Ive used 3
      Steve
      Build it right ... 'The 2nd Time !!'
      69' SS/RS X11 PRO-TOURING E-Force LS7 - SOLD
      2 Custom FJ40's -SOLD
      77' 911 Hotrod - SOLD
      'Killer Piggy' 73 FJ55
      67 Camaro - TBD
      Oct 2007
      Quote Originally Posted by sheck44 View Post
      Steve
      Got a link I went to trim parts and searched no mas
      67 Camaro In progress
      Quote Originally Posted by XLexusTech View Post
      Hmm I can’t find it either. Here is the link to ACC. Select the Essex option.
      https://www.accmats.com/commerce/196...Flooring/3741/
      Don
      Jul 2011
      Nashville/ Tampa
      Essex is what I have as well. Good stuff.
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
      May 2012
      Kansas City, Missouri
      Will this carpet fit a 69 camaro that has had the bigger tunnel for the t56
      Quote Originally Posted by thumper877 View Post
      It is oversize but sometimes I have had to split it down the middle and hide the cut under the console. Otherwise you are looking at custom carpet.
      I had to put in a huge raised tunnel for my 6L90E and I am going to use the TMI multipiece custom carpet.
      Don
      I went with ACC one piece carpet in Essex. Will probably order Essex floor matts as well.
      Thanks for the help
      Peter
      Dec 2012
      Yessir ... and like Don said you just need to split it down the middle over top the tunnel. Then you'll need to cover with a console ...
      Cheers
      Steve
      67 Camaro - TBD
      May 2012
      Thanks Steve and Don I appreciate the help
