View Full Version : 68 Camaro #2 pops and I fun times.
KCR
05-21-2018, 09:04 AM
Hi all my dad and I are building our second 68 Camaro. So I thought I would post the build and all the fun.
Car is a RS that I’ve had for 22 years and needs a lot of work. This will be a street car for the most part with some track fun. 152735
Her is some pics of it tore down for media blast.152741152736152737152738 Pics after blasting. 152739152740
KCR
05-21-2018, 01:22 PM
Here is car #1 we just got done with a few months ago. It’s a 68 with a LS1 , 700r trans , 9” rear end , Chris Alston suspension. 152746152747
KCR
05-21-2018, 01:24 PM
152748
KCR
05-25-2018, 01:08 PM
Got more done replaced trunk pan , front floor pan mini tubs rear fram rails and quarter panels. Installed brackets for Chris Alston rear Suspension. 152873152873152874152874152875152876
KCR
07-17-2018, 11:27 AM
Got some work done over the weekend. Floor pan all weld up and in primer and the door skins done. Now time to start putting all the sheet metal back on to do panel gaps and body work. Hope the motor gets hear next week so I can finish the fire wall also.154600154601154602154603154604
KCR
07-20-2018, 02:11 PM
This big bad boy showed up today. 540CUI BBC thanks to Pat at Nyes Racing. 154731154732
KCR
07-28-2018, 02:50 PM
Got a lot done this week. Sub frame painted , front end all together , motor and transmission mounted up. Waiting on headers and starter then might fire the motor just to hear how it sounds.
Here is some pics of the work we got done and the dyno results. 155111155112155113155114155115
LonghornJPS
07-29-2018, 07:50 AM
Looking great! Keep the updates coming.
KCR
08-11-2018, 09:21 PM
Well didn’t get much done this weekend. Was going to mount the headers then install the sub frame. Had a set back the headers I went with was headman they hang way to low and hit just about every thing. Was going to fix the place they hit but way to much time to raise them a 11/4. So sending them back and taking the sub frame over to lemons next week to have a set of headers made to fit the Ride tech true turn and tucked up nice and tight. Here is some pics of the problems I ran in to. 155524155525155526155527
130fe
08-11-2018, 10:26 PM
Great looking project! Is that going to be your ground clearance for your headers?
KCR
08-11-2018, 10:42 PM
That’s the Headman headers that will not work for what I’m doing.
ryeguy2006a
08-15-2018, 03:46 AM
Great looking project! I'm curious what the color is for the Red 68 you built? I just painted my 1968 and it looks like the same color.
KCR
09-02-2018, 02:14 PM
Well work got in the way of getting the sub frame over to Lemons to have the headers built. Was not going to be able to get there for a few months so instead of holding the work up I would try and build some. It’s a slow pace but is fun and I think there looking good. I should have them done next weekend. Here’s some pics of the headers so far. 156152156153156154156155156156156157156158
I beleave the red cars paint is a 2006 vete color.
Gmc427
09-04-2018, 02:55 AM
hi,are you using offset frame mounts that push engine to pass side?regards
KCR
09-04-2018, 06:13 AM
I have both frame mounts but went with the small block ones when I started building my own headers. I didn't like the way it off set the motor and raised it.
Gmc427
09-04-2018, 11:35 PM
i have the same ocd problem,think i will as well,regards
Gmc427
09-04-2018, 11:42 PM
what dia headers are you doing?regards
KCR
09-07-2018, 04:52 PM
2 1/4 primary tubes and 3 1/2 collector
KCR
09-22-2018, 05:17 PM
Got a lot done over the past few weeks. Headers are done and I think they turned out Keller. 156814156815156816
Sub frame now under the car to finish the fire wall. 156817156818
Rear ended all to gather and up under the car for mock up. 156819156820156821.
Doors on for fit meant and gaps. 156822156823[ATTACH=CONFIG]156823
Getting to the point where a lot can be done. Getting the hole car mocked up and body work done. Hoping to paint in December.
Gmc427
09-24-2018, 02:24 AM
headers have come out mint!
Gmc427
10-16-2018, 09:16 PM
hi,are you able to post or pm me a clear picture or two of the bottom of the dash cutout ?mine has been removed in front of where pedal box mounts and im wanting to replace,regards george
ryeguy2006a
10-17-2018, 04:10 AM
Excellent work on the headers! I've always wanted to try and build a set of my own headers.
KCR
10-17-2018, 09:12 AM
GMC427 I'm not sure what you need pics of can you explain a little more and I will get you the pics.
Ryeguy building the headers was pretty easy with the Icengineworks modeling system and I made my owen jig to cut the bends. I ordered right from them so I only got the blocks I needed. I used 3" CLR U bends so I ordered 50 3" CLR 2" bend blocks and 70 straight blocks if I was to order again get 50/50 split. I got my tubing from Race Mufflers.com. It took 17 2 1/4" U bends to build the headers and I didn't waste any. The U bends have enough strait tubing so didn't need to order any.
Gmc427
10-18-2018, 02:23 AM
hi ,the dash cut out hole in this picture,mine has been cutoutfor some reason where the rods hang down and support the steering colunm ,apicture from above of the reinforcing peice where the rods pass though would be great if possiable and one from under would be good,regards george
- - - Updated - - -
hi ,the dash cut out hole in this picture [last pic in post 4],mine has been cutoutfor some reason where the rods hang down and support the steering colunm ,apicture from above of the reinforcing peice where the rods pass though would be great if possiable and one from under would be good,regards george
KCR
12-02-2018, 12:12 PM
Update. Been working on getting all the panel gaps done redid the finder to door and A-piller. I will be doing no trim glass so I wanted the door and finder to match. Also got the serpentine elf installed. 158781158782158783158784
KCR
01-28-2019, 10:25 AM
Finely got some work done. Got the front end sheet metal on and gaps look good. Fixed the head light Area redone. Cut off the rain gutters and got welded up nice still need to touch up the lead work. Some pics of the whats been done. 160856160857160858n160859[/ATTACH[ATTACH=CONFIG]160862
FormTA
01-30-2019, 05:37 AM
Nice body work. You got skills. Looks great!
KCR
01-30-2019, 08:11 AM
Thanks TA. This is the first time going to depth of body work. I want the car to be slick with no chrome. Got the wheels ordered up from Boze and they should be here in 4 weeks. Ordered the Chicane wheels in brushed.
KCR
03-28-2019, 05:43 PM
Wheels got here to day and they look great. 162948162949
Thanks Zach at Boze wheels.
This weekend I will get them mocked up on the car and make sure they fit good then time to start the body work.
Gmc427
03-29-2019, 11:08 PM
what sizes have you gone with?
KCR
03-31-2019, 07:04 PM
GMC I went with 18x8 in the front and 19x11 in the rear both with a 5” back spacing. Cooper tires 245 40 18 and 325 30 19.
I got them fitted up and everything fits good and they look great. Car still needs to be lowered a bit. 163021163022
Now I can finish up the little bit of metal work and start doing the body work.
Gmc427
04-01-2019, 02:43 AM
nice,what width do you get with the dse tubs at 12oclock inner tub to wheel arch lip?regards
KCR
04-01-2019, 06:36 AM
GMC if I remember right just under 15".
Gmc427
04-02-2019, 02:36 AM
is that inner to the outside? regards
KCR
04-02-2019, 05:22 AM
GMC That's from inner wheel tub to inside outer lip.
KCR
10-15-2019, 06:31 PM
Sorry I haven't been keep up on updates. We have been making progress on the project.
We got the motor in and fired up tested the brakes also had just a little fun.
https://www.youtube.com/watch?v=Cfke8b4yq5o
I will also load the body work pics when I can get them to transfer.
rchaskin
10-16-2019, 05:44 AM
Nice!!
Sounds pretty Rowdy!!!
Just 1 More
10-16-2019, 06:11 AM
very nice
jetmech442
10-18-2019, 08:14 AM
Very awesome.When he gave it a few short revs you could hear how mean that motor is.
Gmc427
02-03-2020, 12:40 AM
looking good!!!
Bad Bowtie
02-03-2020, 01:56 AM
KCR,
Great job on the car. I know a lot of hours go into getting body work just where you want it, I am in the middle of that weld here, cut there, grind here lol. I did notice you were using port fuel injection and that's what I plan on I'm just curious to see what ecu you are using. I plan on a Holley Dominator so that I can control my 4L80E trans all in one unit. If you are using Holley how has it been with setting up the 540? Continued success on your build
BB
KCR
02-05-2020, 08:46 AM
Bad Bowtie ,
I'm using the Holley HP ECU. The set up was real easy. Just put in motor specs check all wiring and hit the key.
I really need to update. Car is getting paint next weekend and goes to the upholstery shop end of the month
KCR
05-06-2021, 09:31 AM
188197188198188199Hi All I did a really bad job at keeping up with this thread. The car is done and been driving and working out all the bugs of a new build. the biggest one was the TH400 didn't last long so a month or so ago we added a 4L60E built by Profomabuild what a beast and what a difference. With the TH400 the car only did 500 HP had to be something wrong with it from the start but now 600 + HP and overdrive. had some issues with the cooling but that turned out to be not getting enough voltage to the fans.
KCR
05-06-2021, 09:43 AM
For the interior I went with 2016 mustang seats hand built the center console and trunk area.
minendrews68
05-06-2021, 12:22 PM
what color is your car. I really like it.
KCR
05-06-2021, 02:54 PM
The color is Rosetta Red from a 2019 Range Rover.
LonghornJPS
05-07-2021, 09:58 AM
Beautiful craftsmanship as always. Congrats on a great build!
