Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 42
    Mar 2015
    68 Camaro #2 pops and I fun times.
    Hi all my dad and I are building our second 68 Camaro. So I thought I would post the build and all the fun.
    Car is a RS that I’ve had for 22 years and needs a lot of work. This will be a street car for the most part with some track fun. Name:  670835B0-FBFE-4526-9BE1-968C9CE1FFFC.jpg
    Her is some pics of it tore down for media blast.Name:  643F960E-D2F1-4056-B17F-5FABD7952DBF.jpg
Size:  232.0 KBName:  A97799C8-0071-4B75-B31E-6E3F3E219DC9.jpg
Size:  156.6 KBName:  89CAD5F1-0C09-438C-8702-F80EEDE1A72A.jpg
Size:  241.1 KBName:  63D2C30F-71F1-464B-B87D-44AEAC38E75C.jpg
Size:  224.5 KB Pics after blasting. Name:  B20A8830-D016-4560-BE3B-39EE29865B4E.jpg
Size:  186.4 KBName:  30A60A27-9FCD-4AFD-9613-0CD191D8095D.jpg
    Mar 2015
    Here is car #1 we just got done with a few months ago. Itís a 68 with a LS1 , 700r trans , 9Ē rear end , Chris Alston suspension. Name:  38AD8BBA-CFEB-4D55-953A-CC7C9761843B.jpg
Size:  130.1 KBName:  E9E7512B-056F-477D-9620-EEF861FAD98C.jpeg
    Mar 2015
    Mar 2015
    Got more done replaced trunk pan , front floor pan mini tubs rear fram rails and quarter panels. Installed brackets for Chris Alston rear Suspension. Name:  CBFBAE03-8AC9-4E26-95D2-798FD55DECC2.jpg
Size:  171.9 KBName:  CBFBAE03-8AC9-4E26-95D2-798FD55DECC2.jpg
Size:  171.9 KBName:  C74C9F09-4E1A-47DD-9CE9-B16764070073.jpg
Size:  224.2 KBName:  C74C9F09-4E1A-47DD-9CE9-B16764070073.jpg
Size:  224.2 KBName:  83E92981-6662-4D6B-A739-8688A8DCA7D0.jpg
Size:  221.0 KBName:  867A6572-BD91-44C9-BEE0-EC218DBB65A7.jpg
    Mar 2015
    Got some work done over the weekend. Floor pan all weld up and in primer and the door skins done. Now time to start putting all the sheet metal back on to do panel gaps and body work. Hope the motor gets hear next week so I can finish the fire wall also.Name:  5237830B-0C4C-461C-A293-3BEF632A2012.jpg
Size:  164.7 KBName:  C1CE362B-3748-42F5-99F0-72749DAD2D0E.jpg
Size:  163.1 KBName:  B4CE874C-CFC6-4C4E-BE39-B1DFCC33DA9E.jpg
Size:  217.4 KBName:  C6BB9DFA-FADC-4A81-B474-66E3809800F8.jpg
Size:  136.5 KBName:  D7389BC9-0673-40CF-967D-38F44CC8887A.jpg
    Mar 2015
    This big bad boy showed up today. 540CUI BBC thanks to Pat at Nyes Racing. Name:  9C666FF0-9753-4572-BA62-7A8912C851D7.jpg
Size:  220.7 KBName:  BBBD76E4-B708-489B-9271-E333A46345FF.jpg
    Mar 2015
    Got a lot done this week. Sub frame painted , front end all together , motor and transmission mounted up. Waiting on headers and starter then might fire the motor just to hear how it sounds.
    Here is some pics of the work we got done and the dyno results. Name:  1C7C8D9A-7977-4710-B5A4-BA36B3C09503.jpg
Size:  232.5 KBName:  3264649C-217E-44DA-825B-12017059A5EA.jpg
Size:  213.2 KBName:  1BBC726C-6C8E-4CEF-8333-179B09C39865.jpg
Size:  266.5 KBName:  0937A454-6D39-44BC-9EB5-2E3EE0C57669.jpg
Size:  274.7 KBName:  53FDB0EA-8B44-4271-93DA-098FB7C8D191.jpg
    May 2011
    Hendersonville, NC
    Looking great! Keep the updates coming.
    Mar 2015
    Well didnít get much done this weekend. Was going to mount the headers then install the sub frame. Had a set back the headers I went with was headman they hang way to low and hit just about every thing. Was going to fix the place they hit but way to much time to raise them a 11/4. So sending them back and taking the sub frame over to lemons next week to have a set of headers made to fit the Ride tech true turn and tucked up nice and tight. Here is some pics of the problems I ran in to. Name:  0199A000-D052-458B-94C6-5AB2A77A2A5C.jpg
Size:  82.1 KBName:  81F6E589-56FA-45DA-BBEF-D9B310E8EAD7.jpg
Size:  151.3 KBName:  2660FA2A-7A02-4DB7-84BD-3699FC75F7D3.jpg
Size:  222.9 KBName:  2B1A168A-0075-43BA-B573-0630E0227388.jpg
    Jacksonville, FL
    Great looking project! Is that going to be your ground clearance for your headers?
    Chris
    1968 Chevy Camaro SS
    LS3/T56 Ridetech suspension
    Mar 2015
    That’s the Headman headers that will not work for what I’m doing.
    Sep 2009
    Great looking project! I'm curious what the color is for the Red 68 you built? I just painted my 1968 and it looks like the same color.
    1968 Camaro LS6, T56, Z51 brakes, 12 bolt, Speedtech, Hotchkis, DSE
    1976 T/A LS1, 6 Speed, C5 front brakes, and etc. SOLD
    Mar 2015
    Well work got in the way of getting the sub frame over to Lemons to have the headers built. Was not going to be able to get there for a few months so instead of holding the work up I would try and build some. Itís a slow pace but is fun and I think there looking good. I should have them done next weekend. Hereís some pics of the headers so far. Name:  B7794322-0623-4DDD-93E6-3966F3000F7A.jpg
Size:  268.8 KBName:  AAAC3B64-2762-4E98-B362-6932B74D8391.jpg
Size:  254.2 KBName:  AC72FD3F-2008-4039-87DE-D55C83A417EC.jpg
Size:  294.8 KBName:  62638970-71B0-475A-8902-7557E19315F6.jpg
Size:  283.6 KBName:  953378CF-336E-4D1A-8F74-A401E72A6EED.jpg
Size:  260.9 KBName:  716D26C1-6003-4BE4-A59C-043985174970.jpg
Size:  268.0 KBName:  D4B7411B-C57B-4DCB-B17A-6B1FE6F78696.jpg
    I beleave the red cars paint is a 2006 vete color.
    Jun 2015
    Country Flag: New Zealand
    hi,are you using offset frame mounts that push engine to pass side?regards
    Mar 2015
    I have both frame mounts but went with the small block ones when I started building my own headers. I didn't like the way it off set the motor and raised it.
    Jun 2015
    i have the same ocd problem,think i will as well,regards
    Jun 2015
    what dia headers are you doing?regards
    Mar 2015
    2 1/4 primary tubes and 3 1/2 collector
    Mar 2015
    Got a lot done over the past few weeks. Headers are done and I think they turned out Keller. Name:  26D44BF5-A98A-4B8A-85FE-231AE54B265B.jpg
Size:  270.6 KBName:  E44F0817-350E-481B-8931-769203E1E70F.jpg
Size:  271.9 KBName:  A062673C-92CD-4D17-97C1-546B5232A146.jpg
    Sub frame now under the car to finish the fire wall. Name:  C1370CA9-CA98-4863-BC73-FB7B770BE6FE.jpg
Size:  216.2 KBName:  47729061-9798-44F8-9A0C-75861A9FDC36.jpg
    Rear ended all to gather and up under the car for mock up. Name:  611386E8-2A2F-401B-B20F-46787FFADD7C.jpg
Size:  200.9 KBName:  73E2F463-7EA6-40C7-8CC9-88D80ED1D8F4.jpg
Size:  197.0 KBName:  70E534EA-EE9E-45A0-BDE2-3B650FBB28FA.jpg
    Doors on for fit meant and gaps. Name:  3270E207-CE13-4222-86FC-4FDBFFF39973.jpg
Size:  200.0 KB[ATTACH=CONFIG]156823Name:  0D77A30A-11EF-4CA8-80CE-6BADBF29FD00.jpg
    Getting to the point where a lot can be done. Getting the hole car mocked up and body work done. Hoping to paint in December.
    Jun 2015
    headers have come out mint!
