View Full Version : CTS V1 caliper dimensions
krom
03-16-2018, 02:53 PM
Does anyone have a drawing of the 4 piston brembo calipers used on the cts V1? looking for the location of the mounting points vs center of the hub, both front and rear.
Or a cad drawing
jlcustomz
03-17-2018, 09:06 AM
This may be of some use. I think the built in bolt on points are the same spacing as either the 98 to 02' f- body or the c-5/6 vette brackets but holding the caliper up an inch higher than f-body if I remember correctly.
What is intended application?
http://lukeskaff.com/projects/car/third-gen-f-body-brake-upgrade/upgrade-options-and-measurements/
krom
03-18-2018, 04:51 AM
I'm building a 72 cutlass, and trying to do it on a budget..
I have solid-works, and access to a bridgport.
The car came with a 350 olds, th350, 2.73 open 10 bolt rear, and 4 wheel drums.
Its getting a junk yard 5.3/4l80e, chinese turbo, nascar surplus 9" floater with 357 and detroit locker
The front is somewhat in limbo as of now (what I want to have is a full ron sutton front clip, what I want to pay for is Chinese knock off a-arms and drop spindles)
The V1 calipers seem to be by far the best bang for the buck so I picked up a set of 4.
so I need to fab up a set of brackets to weld to the rear, and a set of brackets for the front, once I decide on what spindles.
I was hoping to find drawings, prints, or cad models to work with to make it easier.
Btamayo23
03-20-2018, 09:29 PM
I put cts v front brakes on my 70 skylark. I have stock drum spindles. I used the ls1 brakes bracket. I found the template online with all the measurements. I used 2010 camaro ss rotors I just had to open the center up a bit. With some minor tweaking I got it all lined up pretty well.
Btamayo23
03-20-2018, 09:38 PM
150741
I believe this is the cad drawing I used
krom
03-21-2018, 03:53 AM
150741
CODENAMEBLACK
06-26-2018, 06:04 AM
will this also work on a 79 firebird using the cts-v Gen1?
t72ss402
07-01-2018, 04:09 PM
There is a place called Fly n bye that sells the bracket already. It is listed under 67-69 Camaro, however if memory serves me correctly it should interchange.
http://www.flynbye.com/catalog/i220.html
