View Full Version : Aftermarket Oil Pan for LSX and Speedtech Pro Touring Subframe
DavidCorniola69
02-02-2018, 06:19 PM
Hey everyone,
What aftermarket oil pans are you all using for your Speedtech Performance Pro-Touring Subrames for LSX blocks? I've been told Autokraft makes one that fits, and i've seen one from Mast that looks like it may fit as well, but I'd like to get some actual user opinions if possible. Thanks!
slimjim
02-03-2018, 08:28 AM
the Mast pan fits perfect with this setup
killer69
02-05-2018, 11:19 AM
WE also have our oil pan with a remote filter if that is something your interested in,
if you look on our site in the instructions section and find the oil pan install is gives the dimensions then you can check the others to see if they are close they will need to be VERY close to fit.
nicks67camaro
02-05-2018, 03:02 PM
X2 on the mast pan.
65 drop top
02-05-2018, 05:15 PM
I just bought a Mast pan for my build. Nice piece.
cpd004
02-06-2018, 06:17 AM
I tried a factory Corvette pan which did not fit. This is what I have now:
http://tildenmotorsports.com/tilden-motorsports-pro-series-lsx-sheetmetal-oil-pans.html
carbuff
02-06-2018, 01:01 PM
Dailey billet pan. This is a dry sump though. ;) It is a work of art!
DippedInSauce
02-08-2018, 12:19 AM
I've been running the Speedtech road race pan for the past 10 years. Little did I know the oil bungs would come in to play all these years later with the addition of turbos. Expensive but you get what you pay for in this instance.
Sinnister69
01-29-2019, 05:05 PM
will the holley 302-2 pan work?
Timmah
01-29-2019, 05:19 PM
I have a mast pan with the remote fitting. I remove from box and but never bolted or used. PM your email if interested in seeing picture.
Tim
killer69
01-31-2019, 10:47 AM
so we have a new engine mount coming out in the next month that will allow the 302-2 pan to work we have fitted one in the shop and all id good with it, it is really tight but does fit. also found out that the LSA CTSV exhaust manifolds will work
Sinnister69
02-04-2019, 09:55 AM
i have the speedtech pts with the ats 700001 engine plates the holley pan dimensions are actually shallower in the front but not by much.
im actually handcuffed with the holley pan as i got a gift card to a local speedshop and really the only thing i need is an oil pan and the holley pan is the only one they sell thats cheaper than the others
Sinnister69
02-04-2019, 10:41 AM
holley seems very close
