View Full Version : Project Black Widow
74 Camaro
01-25-2018, 06:53 PM
Hi Everybody!
Time to get started... sort of. I will be returning home from overseas toward the end of March and will be able to start actually assembling parts. For now, I have a sub-frame sitting in PTFB's shop getting worked on. I purchased it from F-Body International already set up for the new PTFB coil-over setup. This is a great tuning advantage, and will also save me a lot of time that I would have had to spend repairing my old sub-frame, which was damaged in an accident. The new sub-frame is for a later model, and will need to have holes drilled in the back of the frame to adapt it to my 74 Camaro, so Dave at PTFB is going to do that for me as well.
By the way, in case anyone is considering PTFB for suspension parts, I can say so far the customer service has been great! Dave even picked up the sub-frame in Illinois from the seller, since he was in town to pick up things from his old shop. He then brought it back to his shop in Tennessee to do the final touches for me, crate it and additional parts, and ship it to CA. He is quick to respond to questions in emails, and gives good, detailed information. I'm also a big fan of his approach to performance- making competitive packages affordable for people on a budget so that we get to have fun too!
For now, I'm trying to make sure I have as many of the needed parts on hand as possible for when I get home so I can get started right away!
I'm getting all my suspension, steering, braking, and chassis bracing components from PTFB. I have purchased tires- 275/35ZR18 BF Goodrich Rival S, on all four corners. My next thing to buy will be wheels. I'm considering Team III LT3's in 18x9.5. They aren't cheap, but they are the only wheel I like that isn't upwards of $750 per wheel. I think they are the best looking wheels out there.
153852
I will also need to buy and install a dash, mostly to comply with CAM rules, which require a somewhat finished interior. I'm thinking about going with this fiberglass dash, to save weight and money:
148302
Not only is this dash cheaper than a stock replacement, it may allow me to forgo a gauge panel. If I can, I would like to use a generic 6 gauge instrument kit installed directly into the fiberglass. Just cut holes for each gauge. This seems like it would be cheaper than buying kits specific for Camaros which include their own panel. The difference seems to be about $400 for a generic set vs $750+ for a Camaro specific one.
I already have a complete wiring harness from Painless which I will need to install.
The car as it sits now:
153851
For a little background on the car, see my intro thread:
https://www.pro-touring.com/threads/119873-74-Camaro-Budget-Build?highlight=
The thread that led me to my choice of suspension parts:
https://www.pro-touring.com/threads/127297-Best-2nd-Gen-Camaro-budget-suspension?highlight=
The thread that helped me decide to keep my current transmission until I can afford to get a 5 or 6 speed:
https://www.pro-touring.com/threads/127336-Anybody-Using-a-Saginaw-3-Speed-Manual?highlight=
grendel
01-26-2018, 05:16 AM
In for the ride.
OLDFLM
01-26-2018, 07:43 AM
If you haven't seen it already, Popular HotRodding did a pro-touring build like yours called "G/28"... maybe you can still find it.
74 Camaro
01-26-2018, 05:33 PM
I just checked it out. Very cool build. I like what they were able to accomplish with handling performance on a budget. It's very encouraging! My budget is similar, but with a slightly different focus. With true coilovers in front and adjustable shocks front and rear, adjustable sway bars front and rear, extensive chassis bracing (all on order from PTFB), and stickier tires than what the G/28 started with, I'm definitely biased more towards handling than power. That doesn't mean I will be faster- just that I have the potential to be faster, at least, in the corners. When I do upgrade my engine, that too, will be focused on handling, as my goal is to get an aluminum block ls for reduced weight and increased cornering performance.
They did have a better car to start with in the looks department. I have run across the car before, actually, when I was researching options on what to do with the bumpers. What they did with the bumpers was cool. Not sure if it will be my approach, though. In any case, that will be a future project...
By the way, this build is heavily influenced by what my sister (Hannah) likes. I suggested once that we build the car for straight-line performance and she said she'd rather have a car that can handle. So for now, the focus is not on engine stuff. Her preferences also influence my plans for the engine. There is plenty of potential in the small block that I have now, but I intend to put any engine budget into getting that aluminum swapped in, rather than beefing up the sbc. Money for money, I could probably get more power out of the sbc, but again, I'm focusing on what will make the car handle better, which will be reduced weight. For a few grand, I could either have a mediocre LS1 or beast up the sbc. At a certain price/power point, I think it does make more sense to swap to an LS3, due to the inherent flow of the heads. I will just have to see what my budget for that is in the future. For now, it's all speculation.
Hannah's take on the bumpers is that the car needs the chrome. She is one of the most sensible people I know, and I usually come around to agreeing with her taste. While others see the G/28 bumper mods as an improvement, I actually see them as a compromise. They say their approach reduces visible bulk, but I think that taking out the rubber strip creates a tall, flat area that looks blocky. Also, the shortened sides make the side of the bumper look almost square. The longer side extensions of the stock shape go better with the low-and-long flow of the overall car design. Somewhere I read an opinion that tucking the bumper too much detracts from the shape of the grill, which is leading to a point. If you snub it off too much, it looks abbreviated. I think people want the 70-73 look, but don't realize that those cars had a much more vertically square front end, whereas the 74-on are more angular. You can see the stock/modded bumper comparison pictures here:
http://www.hotrod.com/articles/0802phr-1976-chevrolet-camaro-disco-bumpers/
In my opinion, for all the effort, I would stay with the stock look. Again, this is all just blah, blah, as I am far away from seriously attacking that kind of project anyway. For the record, my interest in modifying the bumpers comes from more of a desire to reduce weight, which increased by about 300 lbs from 73 to 74, the bumpers being a large part of that equation.
I hope I'm not droning on too long about irrelevant topics. I find it all to be interesting, and enjoy speculating. Thanks for reading, and I would love to hear your comments!
74 Camaro
01-26-2018, 07:16 PM
Quick update:
I decided to go with the wheels that were suggested to me by Dave, the Vision 143's in 18x9.5, 0 offset. I paid $546.64 on Amazon with free shipping. I'm not crazy about the style, but they are unbeatable at that price. Also, I'm planning on going wider eventually, when I have time to carefully mock up what back spacing I will need and clearance fenders. When I do that, I will get 8 spoke wheels more to my liking, either the LT3's or a forged option- depending on budget. If I were to get those beautiful LT3's now, it would be hard to replace them after a 2K investment. The 143's are disposable in comparison, costing less than half of what my BFG Rivals cost me!
The Vision 143:
148399
HotRod47
01-27-2018, 05:06 AM
I'm digging this build so far. Pretty good plans for it. I also like the car, you don't see that many of this year range of the Camaro. Mainly a lot of the 70-73 and then the 78 and up.
On the bumper topic. I'm not so sure about the bumpers being tucked throwing off the grill comment that you read somewhere. I know we all have opinions, but to me the tucked bumper helps the aesthetics of most any car, especially these. It gets rid of that Park Bench look of them. While I agree i would prefer the chrome look instead of painting them, there are options. After being tucked/modified, there is options. They could be chromed, costly. They could be painted in a chrome look paint, or even powder coated in a nice high luster silver or even an HPC type coating that will resemble a chrome look. Options are out there. But in the end it is your car and you are the one building it. Do it to your taste and not what others think you should.
74 Camaro
01-28-2018, 10:26 PM
I think I should clarify. The guy I referred to owned a big bumper Camaro himself, and tried a more extreme tuck before he settled on something a little more moderate, like 1 inch, I think.
One approach would be to shorten the straight sections on the front to bring the sides in a bit. I would leave the sides long, and trim as necessary to fit. Chrome would be the preferred finish, but that would depend on budget. I would try to replace the triple-flat-spring structure with a tubular structure, in order to retain some of the crash protection, but drop some weight. Pic of the heavy structure (not my car):
153853
Alternatively, I could get a full fiberglass front end, such as the one below, which incorporates the bumper. It would all be body color, but the weight savings would have the performance advantage. Besides that, the shape is quite well executed. To be fair, it does have the rubber strip area flattened out, but I'm okay with it. The Glasstek front end:
153854
OLDFLM
01-29-2018, 06:55 AM
Another affordable rim option would be the CL205 which is the grey centered Torque Thrust II. A great looking rim for these early F-bodies imho!
These can be had in an 18x8 wih 4.5"bs for the front and 18x10 with 5.5" bs for the rear. Allowing you to run a 255/40/18 up front with a 295/35/18 out back.
But you may be limited to a 275 or 285 in the rear with the Camaro wheel arch being flat at the top vs a Firebird/TransAm.
qnitro
01-29-2018, 07:03 AM
Im gonna watch this pretty close, Im thinking of doing a 1974-77 Tribute Z28.. bumper are just so ugly :)
74 Camaro
05-17-2018, 12:49 PM
Alright! The front brakes and mc have arrived. I pick up the rest of the parts tomorrow on crate. I'm stoked! I may try to get that mc installed today.
153849
These parts are arriving just in time for me to be done moving and helping my friend renovate her apartment. Also had to work on 3 different vehicles other than the Camaro. Seems like life just wants to get in the way of what I really want to do. But now I should be able to actually get going on this. Is it too good to be true?
Something else that I'm pretty stoked about, these wide, sticky tires! Pic shows new tires next to the old, which were already wider than stock, being from an 80's Camaro.
153850
74 Camaro
05-21-2018, 09:19 AM
Friday I picked up the parts. PTFB everything, which look to be high quality.
153856
I wanted to test fit the cage, so I started stripping the interior. The old wiring harness is a complete rats nest, so that had to come out. The carpets looked dingy, so those had to come out. The headliner was warped, so that had to come out. Everything was dirty, so everything came out, even the foot pedals.
153855
Saturday, in order to further facilitate cleaning, the fenders had to come off. My dad helped me scrape old cracked caulking off and scrub off the dirt with a dish brush and windex.
The plan is to follow up with a much smaller, neater bead of caulk. The car needs all new weather seals, but I would like to paint the interior and door jambs before installing the weather stripping. I don't like the idea of having to remove the stripping later to do paint. This is not exactly a frame-off restoration. More like a frame off cleaning. I like a clean interior. Even if the body needs work, I at least like my car to be clean. I am not fond of carpets in cars, or in life, and I also really like the contours of body stampings. Something beautiful to me about seeing what is actually there. So I'm thinking about using some kind of rubberized paint on the floor boards, like an underbody or bed liner. Preferably something that is easy to clean. This way I will not need floor mats, which would slide around during autocross or canyon carving and present a possible safety concern. There is some pitting in the floor boards, but they are still holding together. I will probably use a rust stopping primer first.
Sunday, went up to Ridgecrest to get my brake hard lines and front bumper from storage, as well as some other parts. Ordered some more parts from Classic Industries. Unfortunately they are out of stock on weather stripping. I have till Sunday to do what I can before I head out to Michigan for a family event. Will be gone two weeks. When I get back, I will have one month to finish the current build stage. Hopefully, this week I can have the interior done. That way when I get back I can get right to installing parts.
Parts inventory revealed a few things missing. PTFB accidentally held onto my spindles which are modified for the big brakes. I also meant to order their cowl brace, but somehow wasn't clear about that in my emails. I discovered that I needed upper mounts for the rear sway bar, so I ordered a used stock set from Ebay. My car was a base 6 cylinder car, so it didn't have a rear sway bar.
In other news, well, this isn't new, just funny. So, when I got back from deployment I took a look at my engine to get casting numbers to see which Edelbrock crate engine this was exactly and get an idea what kind of horsepower I'm making. Well, apparently I've learned a lot about cars since the original purchase of the Camaro some 5 years ago. I don't know when I picked up the knowledge, but I hadn't actually stopped to look at the engine in, well, years, apparently. So I get home from deployment, glance at the engine, and right away I know this is not an Edelbrock crate engine. Edelbrock heads are aluminum. These are obviously iron. I've been telling people that the engine I have is worth what I paid for the car. Joke's on me and I'm not even mad about it. I don't even think the guy who sold me the car knew either, because I don't think he did the swap. I remember he told me the engine makes 350 horsepower. Even then, I knew enough to be skeptical of that, especially with a stock looking exhaust manifold. 1 hp per ci is pretty good, and I doubt you can get that with those restrictive manifolds. Those also were a clue that whoever put the engine together was going cheap, so it never made sense that it would have been an Edelbrock crate engine. It just had Edelbrock intake, valve covers, and air cleaner. Even the carb is a Carter. Knowing that the engine isn't Edelbrock, everthing makes a little more sense. The bondo over giant rust holes in the fenders. The original 3 speed manual trans that came with the 6. The electrical tape wiring job for the aftermarket sound system. The roughly circular hole drill pattern in the rear plastics over the speakers. The blue masking tape over jagged holes cut into the rear deck metal for other speakers. The inch-thick stack of shims on the right front suspension to try to correct for a past accident. A hundred little details that say someone either didn't know what they were doing, or didn't give a crap.
The engine is more revvy than the 350 in my 75 pickup, so now I'm curious what it actually is. This is where my knowledge ends. How do I go about figuring out what kind of parts are in the engine? Should I get headers?
153857
74 Camaro
06-24-2018, 11:12 AM
I've been so busy actually working on the Camaro that I have not had time to post. I have a lot to cover, so I will try to be brief and just show pics.
74 Camaro
06-24-2018, 12:05 PM
Removed most everything, including front body panels. Drive train and rear end still in place.
153858
Wiring harness out:
153859
74 Camaro
06-24-2018, 12:11 PM
Removed heater box
153860
74 Camaro
06-24-2018, 12:16 PM
Test fitting the roll cage:
153861
Help from my nephew:
153862
74 Camaro
06-24-2018, 12:27 PM
Rear Bumper off. Ordered parts from Glasstek
153863
74 Camaro
06-24-2018, 12:34 PM
Rear end out
153864
Leafs, old vs new
153865
Gas tank out
153866
Oops
153867
74 Camaro
06-24-2018, 12:40 PM
Brought home some proper equipment
153868
Much better!
153869
Damage from engine drop
153871
Tires mounted and road-force balanced
153870
74 Camaro
06-24-2018, 12:56 PM
Two-week vacation to Michigan to see my other sister, and to Indiana for my grandfather's 90th birthday.
Of course, while I was in Indianapolis I had to see the speedway museum.
There, I saw this IROC Camaro:
153872
Got to see the Gilmore museum too. Lots of cool stuff. Mostly I was just anxious to get back and start working on the Camaro again.
74 Camaro
06-24-2018, 01:04 PM
Outlet for a welder installed $$
153873
Test fitting the frame
153874
Not gonna happen
153875
Having to wait a couple days to get the welder I wanted so I can fix this.
74 Camaro
06-24-2018, 01:13 PM
Seats came in. They weren't supposed to be leather, but I suppose Corbeau may have sent these due to low inventory. Word from CWP is that Corbeau is going through some big changes. The leather may not be as good for autocross as cloth, but they are so beautiful I don't mind!
153876
Ideas for door bars
153877
153878
153879
74 Camaro
06-24-2018, 01:26 PM
Repairs to sf mount:
Cut out damaged area
153881
153882
Drilled out spot welds and flattened the pieces
153883
Welded the cage back on
153884
Welded the first piece in
153885
Welded the bottom piece in
153886
For a newb, this welder is awesome!
153893
74 Camaro
06-24-2018, 01:48 PM
Problem area with fitting the PTFB lowered body bushings. The sharp corner you see here was pinching against the frame
153888
So I cut it
153890
Welded and smoothed
153891
And fit the frame!
153892
74 Camaro
06-24-2018, 02:17 PM
The lca not fitting properly due to poor factory tolerances on the stock frame
153897
So I got a solid bar, 1' cut down to 2 3/8" ($10), which I used to beat the openings a little wider
153898
The lca's installed (backwards). Also test fit the strut braces. They will have to be installed permanently after alignment shims are in.
153899
74 Camaro
06-24-2018, 02:22 PM
The lca's in correctly. Also steering and sway bar
153900
74 Camaro
06-24-2018, 02:34 PM
Drilled out the holes on the axle housing for the u-bolts
153901
Didn't want to pay $120 for a new steering collumn u-joint, so I
153902
Cut out the old dust boot and cleaned out the grease
153904
Then re-greased and made my own dust boot out of a heavy-duty rubber glove
153905
It will get another hose clamp on the larger section, just have to go get one.
74 Camaro
06-24-2018, 02:44 PM
Installing leaf spring bushings
153907
153908
Rear end in!
153910
74 Camaro
06-24-2018, 03:05 PM
Rear sway bar installed! (upside-down)
153913
Rear sway bar installed! (Right side-up)
153914
Trying to install rear brake calipers, leaf spring interferes with bolt
153915
I have to swing the caliper bracket down to get the bolt in, but the allen key wont fit between the bracket bolt and the axle housing
153916
Cut off a 1/4" drive section from a 1/4" bit, fit that into a 1/4" wrench
153917
And use like this
153918
Finally got everything together and rear wheels on
153919
I did discover, though, that the stock parking brake cables do not work with Wilwood brakes, so I have to order their cable kit.
Moving on to the front- I tried to put the front hubs on and discovered that I was missing some hardware. Tried these, but there is obvious interference. Must require a really low-profile head.
153920
74 Camaro
06-24-2018, 03:15 PM
So, here I am at the computer, just updated from over a month ago. Please note that I left out many many details. I have been working hard on this project every day. Every inch is fought for, and everything is a force-fit. Everything requires a new tool or an additional part. Or people forget to ship you part of what you paid for. One thing I should mention is that UPS has lost my freight, which was the fiberglass front end, hood, doors, and rear bumper. I'm being told that they should find the missing freight soon, but it's been over a week now since it was supposed to be delivered. Glasstek says this happened to them once before, and the freight was found a few days later. UPS is investigating, looking through footage for the unmistakably huge crate. Good news is, I have plenty to work on in the mean while!
74 Camaro
06-28-2018, 10:37 PM
Over the last four days I have been building an aluminum dash. First, I built some cross bars out of 1" x .125 steel,
154008
then mocked up the dash out of cardboard.
154009
Lay-out how I want the gauges.
154010
Then built it out of .063 aluminum. I ended up not needing the upper steel cross bar, as the aluminum was plenty strong without it.
154011
Ended my day making these chassis-stiffening brackets. You will see the full application soon!
154012
74 Camaro
09-09-2018, 03:16 PM
I see that I didn't put an important update here. Important, not because of all the progress I've been making, but because of my current complete lack of ability to make progress. I'm overseas for work again, this time for a year. I'll be back middle of next July, and plan to continue working on the car at that point.
What's left to do:
- Install Wilwood parking brake cable
- Install exhaust
- Fabricate front and rear bumper structures
- Install Glasstek rear bumper
- Install Glasstek front end, fabricate brackets for headlights, grill, and radiator support
- Install Glasstek doors with hinged horizontal door bars, fixed angled down door bar (There will be no side windows, at least for now.)
- Fabricate chassis bracing additional to PTFB roll bar, sf connectors, and g-braces
- Install Speedway Motors 6 gauge kit
- Install Painless wiring harness, complete engine and chassis
- Install aluminum battery box (My plan is the back seat, not the trunk. The back seat is deleted anyway, and this location will give the battery a significantly lower cg, as well as a more centered moment of inertia.)
- Install mirrors, headlights, taillights, blinkers, seat belts, etc.
As you can see, I will have my work cut out for me! I will have 4 months to get all that done, but I'm not working when home, so hopefully I'll be able to knock it all out. The results should be pretty cool, though. The car should weigh about 400 lbs lighter than when I started, so around 3200 lbs. This is a strictly functional build. I want to be fast in autocross. So I don't think I will be getting any painting done. The idea is to have a super rigid and light weight chassis with a lot of tunability on a relative budget. That means aesthetics won't be prioritized, at least for now. I'm running square 275 BFG Rival S tires for now. With the fiberglass front end, I should be able to fit wider tires pretty easily, but I will have to see what kind of room I'm working with once all the fabrication is done. However, I won't mess with that till after I have worn out the set of tires I have now. The important thing is to get some seat time in. I'm hoping to to race some of you guys in CA next year!
For now, I wait...
09-09-2018, 07:07 PM
Wow Tim, I’m impressed! I haven’t checked in with you in a while on Facebook. Glad see you’re making meaningful progress.
Zspoiler
09-09-2018, 09:19 PM
Very nice build Will be interested in further updates.Here is a picture of my 1979 Z-28 RS .That was inspired by the 1975-81 IMSA GT Camaro road race cars.
74 Camaro
09-09-2018, 09:47 PM
No, that list is all the stuff I HAVEN'T done yet. jk Really, I am happy with the progress thus far. It certainly helped having your prepped frame rather than trying to repair and modify my old one! Can't wait to get back and finish her up!
74 Camaro
09-09-2018, 10:20 PM
I remember your car from when you posted on my introductory thread. I also find those old race Camaros quite inspiring!
09-10-2018, 07:33 PM
I'm glad you are happy with everything. You got an awesome deal! Hopefully one day I can get mine going and we can both hit a track. I've got a bunch of work to do myself though haha.
