View Full Version : Ridetech Compressor Electrical Connector
1bad68cat
01-23-2018, 07:36 AM
Hi,
Hopefully Ridetech reps chime in. What type of connector is used for the compressor. Upgraded from an E2 to an E3 and finally getting around to wiring the system up. The old E2 used a relay to power the compressor (so no connector) and the new E3 provides a ground (with unrecognizable connector) only for the compressor. I'd like to get the both the female and male housings and pins. Also can, the fuses be substituted with circuit breakers instead? Thanks in advance.
Robert
marolf101x
01-23-2018, 11:12 AM
compressor side. . .
connector: 0428180212
terminal: 428171014
wire harness side. . .
connector: 0428160212
terminal: 0428150011
You can get them at Digi-Key, Mouser, Allied Electric, etc.
Let me know if you need anything else!
1bad68cat
01-23-2018, 11:14 AM
Perfect. Thanks Britt
1bad68cat
01-23-2018, 11:41 AM
terminal: 428171014
Hi Britt. You wouldn't by chance be able to sell some would you? The terminals are coming up obsolete and/or having to buy a minimum quantity of 100 or 2500.
marolf101x
01-23-2018, 06:07 PM
Unfortunately we don't typically have many connectors or terminals on hand as we don't build the harnesses in-house. So we may have some in the warranty department for repairs, but I'd have to check how many we have.
Here's the Molex page:
http://www.molex.com/molex/products/family?key=minifit_sr&channel=products&chanName=family&pageTitle=Introduction
You can browse the terminals for alternative part numbers. They offer them gold, silver and tin plated, so there are some options.
Digikey has everything individually:
https://www.digikey.com/products/en?keywords=0428180212
terminal: 428171014
https://www.digikey.com/product-detail/en/molex-llc/0428171014/WM11906CT-ND/5423698
https://www.digikey.com/products/en?keywords=0428160212
terminal: 0428150114 (silver plated)
https://www.digikey.com/product-detail/en/molex-llc/0428150114/WM11904CT-ND/5423696
Hope this helps.
Also, you can use circuit breakers on the compressors if you so choose.
1bad68cat
01-24-2018, 07:51 AM
Thanks Britt. That helps. Initially when I looked at Digikey, it was only displaying cut strips.
marolf101x
01-24-2018, 07:58 AM
No problem. If you need anything else just let me know. Post on here, or send me an email ([email protected])
