class67
01-10-2018, 06:30 PM
I ordered my PSI harness with a 2 pin connector, but have ended up with a 4 pin alternator. I spliced in a 4 pin connector that I got from PSI, but it did not come with instructions and now have a power wire on the 4 pin that needs to be hooked up. I am not a wiring guru in any way and learn as I go, that being said...is this power lead supposed to be switched or constant? if constant, can I just connect it to the power lug on the alternator? (Powermaster alternator, if that matters?).
