View Full Version : LS1 Power steering hose
Pompel
11-18-2017, 06:54 PM
I have a LS1 from a C5 Corvette in my -69 camaro.
What kind of fittings do i need on the servopump? Have Unisteer rack and pinion
andrewb70
11-19-2017, 05:56 AM
What style fittings are on the Unisteer rack?
Pompel
11-19-2017, 06:12 AM
They use 14mm 16mm and 18mm Banjofittings.
I'm don't remember wath I have. I'm at work wont be home in a couple of weeks so I can't check.
dhutton
11-19-2017, 06:35 AM
You are going to need one of these on the pressure side to clear the pulley.
http://www.jegs.com/i/Earl's/361/961961/10002/-1?CAWELAID=230006180015796107&CAGPSPN=pla&CAAGID=44693592161&CATCI=aud-67754331191:pla-210001615991&CATARGETID=230006180039217662&cadevice=t&gclid=EAIaIQobChMIjbSty-3K1wIVh6DsCh2CZQ3KEAQYDSABEgJbVvD_BwE
Return side is just a hose barb on the reservoir.
Don
Pompel
11-19-2017, 06:57 AM
andrewb70
11-19-2017, 07:37 AM
I would also inquire what sort of pressure and volume is needed for the Unisteer rack. Then contact TurnOne for the necessary parts. For the actual hoses, I suspect that a local industrial hydraulic hose maker can set you up. In the industrial world AN fittings are called JIC.
