View Full Version : Holley Injectors
Chuck0379
10-03-2017, 02:13 AM
For sale are some used, but still good 48 lb/hr performance fuel injectors, set of 8 for max hp 765, part# 522-488. $100 shipped. Sorry, but I don't have any pics.
BlackHD
10-03-2017, 09:15 AM
Do you know if these are the same height as the Ls2 injectors? I'm currently running the fast lsxrt intake and fast rails, want to make sure they work. Thanks!
Chuck0379
10-03-2017, 11:49 AM
body length on the Holley are 2.85" can't find anything yet on LS2 height
rickpaw
10-03-2017, 12:16 PM
Is that the length between the o-rings? If not, what is the distance between the o-rings, center to center?
Thanks.
Chuck0379
10-03-2017, 12:32 PM
O-Ring to O-Ring is 2.415"
- - - Updated - - -
https://www.holley.com/products/fuel_systems/fuel_injection/injectors/parts/522-488
Corey R.
10-03-2017, 03:59 PM
These are taller. If Your wiring harness is most likely set up for ev6 connectors, You will have to try and source adapters. These are ev1.
JustJohn
10-05-2017, 07:17 AM
Pretty sure you meant to say "if your harness is set up for USCAR connectors, you will need a set of Amp connector pigtail adapters."
EV6 injectors are produced with Amp, USCAR, and Sumitomo connector styles.
Chuck0379
10-06-2017, 08:59 AM
Photos added
144871144872
Chuck0379
10-30-2017, 03:10 AM
bump
bigblock55
10-30-2017, 07:58 AM
I'll take them. PM me your PayPal info.
Chuck0379
10-30-2017, 08:08 AM
PM sent
Chuck0379
10-30-2017, 08:14 AM
Sold.
