View Full Version : Adjustable Proportion valve design.
Olav
09-06-2017, 11:43 AM
Are the typical adjustable valves like Wilwood etc. Just a needle valve ? Reason for asking is that I have a 1/4" stainless 6000psi Hoke needle valve in my shop. If this can be used I don't see any reason getting another one.
a67
09-06-2017, 12:28 PM
No.
Bob.
Olav
09-06-2017, 11:04 PM
Thanks, have seen people using this style needle valves. : https://www.new-line.com/nldocs/catpages/587.pdf
Olav
09-09-2017, 12:35 AM
This looks like a needle valve ? http://www.speedwaymotors.com/Speedway-Compact-Adjustable-Brake-Proportioning-Valve,1979.html
raustinss
09-09-2017, 04:16 AM
Or just buy the right part to begin with ...Yours and others lives depend on it !
a67
09-12-2017, 01:06 PM
Here are a couple of articles that explain brake front to rear bias and why proportioning valves can be required:
http://www.stoptech.com/technical-support/technical-white-papers/proportioning-valves
http://www.stoptech.com/technical-support/technical-white-papers/white-paper---brake-bias-and-performance-why-brake-balance-matters
Bob.
Olav
09-12-2017, 09:34 PM
I will not or don't have any intetnions of doing a short cut. I found the speedway motors valve http://www.speedwaymotors.com/Speedway-Compact-Adjustable-Brake-Proportioning-Valve,1979.html and it made me thinking. I also saw a valve of same design as the one on link i posted. (The small one on bottom of page) fitted to a camaro a few weekends ago.
raustinss
09-13-2017, 02:23 PM
phew ...I've heard too many stories of short cuts and it hasn't had good results , best of luck with whatever you do hope everything works out
