View Full Version : variable speed controller for a single speed a/c blower motor
justanova
08-02-2017, 05:13 PM
I know this isn't necessarily pro-touring related but does anybody have any recommendations for variable speed controller for an a/c fan motor?
we had to replace the a/c blower motors in my dads 73 peterbilt cabover and the originals are a 2 speed motor with 1 wire for high, and 1 wire for low speed. The only replacement motors are a single speed motor so we have wide open or off for fan speed. I have searched around a bit and can find all sorts of controllers but as I have no experience with such controllers I don't know which ones are good and which ones are junk. I would preferably like a controller with a "remote" mount speed control knob so that hopefully I can put the knobs where the toggle switches that controlled them before are.
ProTouring442
08-03-2017, 05:21 AM
You could always use a resistor pack and a 3 or 4 position switch. The resistor pack should be mounted in the ducting so it gets airflow.
www.millsupply.com/resistor-51527.php?p=4466
Richard454
08-03-2017, 07:12 AM
I've had good luck with this company- out of Canada- and used several of their PWMs
The potentiometer is not remote- but could easily be done-
This one handles 30A- and shipped about $30
https://store.qkits.com/pwm-dc-motor-speed-control-30-amp-mxa066.html
https://static1.pt-content.com/images/pt/2017/08/MXA066-1.jpg
andrewb70
08-03-2017, 08:00 AM
This seems like a slick way to do it!
justanova
08-13-2017, 05:20 PM
that's exactly the kind of thing I'm after, google turns up numerous choices so its good to know that someone has used this brand and had good luck. thanks guys I may give these a try.
