View Full Version : 1967 camaro pro touring value
killersingh
07-22-2017, 01:27 PM
67 RS CamaroEngine:
LS364
Horsepower: 446 @ 6200 rpm
Torque: 412 @ 5000 rpm
Compression Ratio: 10.9:1*
Bore x stoke (in): 4.00 x 3.62
Block: Cast Aluminum 6-Bolt main, cross bolted main caps
Crankshaft: Nodular Iron. Powdered metal rods
Heads, Chamber size: Aluminum, Symmetrical Port
Pistons: Flat top cast aluminum
Valves: 2.000 intake/1.550 exhaust
Camshaft, Lift: 0.500 intake/0.500 exhaust, Hydraulic roller
Camshaft Duration @ 0.050 in: 200 intake/203 exhaust*
Rocker arm ratio: 1.7:1
Maximum rpm: 6000
Intake Manifold: LS1 4-barrel
Carburetor: Holley Double Pumper Vacuum-Secondary 750cfm
Holley 97 GPH RED electric fuel pump
Clutch: Centerforce Dual Friction & Wilwood Hydraulic kit
Alternator: Street & Performance Serpentine Kit
Radiator: Be Cool Polished, Dual Core, Dual electric fans
Heater hoses: Cool Flex
Ignition: MSD 6LS-2 Ignition Controller, MSD Multi Spark Coils, PowerMaster starter
Transmission:
Tremec T-56 6 speed with mechanical speedo adaptor and McLeod slik stix shifter
Exhaust:
Hooker Super Competition Metallic Ceramic headers, 2.5" exhaust with 40 series Flow Masters mufflers.
Suspension:
Hotchkis TVS system (coils, sway bars, tie rod sleeves, and leaf springs)
Hotchkis Tubular Upper and Lower A-Arms
QA1 Stocker Star Single Adjustable Shocks
Sub Frame Connectors
Brakes Front/Rear:
Baer Claw Track
13" cross-drilled, slotted
Baer proportioning valve
Wheels and Tires:
Front: Torque Thrust II 17x7.*
BFG G-Force 235/40R17
Rear: Torque Thrust II 17x8
BFG G-Force 255/45R17
Interior:
Restored original state except;
Auto Custom Carpet mats, Custom Autosound Stereo
2007 Specs:
Curb weight: 3338 lbs
Horsepower: Dyno'd @ 455
Mr.VENGEANCE
07-22-2017, 06:53 PM
Hows the paint and body?
was it restored?.. that would determine if you got a 60K car.
the itty bitty TT2s hurt the value tho.. becuase that much HP and no meat.
Id guess unrestored which the list makes it look like a stock car/ stock interior/ with just a hot LS swap, 6 speed and big brakes id guess about 40/45K.
killersingh
07-22-2017, 07:01 PM
Was a rotisserie restoration about 7 years ago no rust paint is about 7ish ill post some pics soon just on the road
killersingh
07-22-2017, 11:58 PM
142554142555142556142557142558
dhutton
07-23-2017, 03:18 AM
Damn, look at those brake lines and heater hoses. I hope the rest of the build quality is better. Steam vents are not connected. PCV plumbing looks sketchy. No EFI and no AC. Around $30k?
Don
Mr.VENGEANCE
07-23-2017, 08:03 PM
yup... thats no 60...
id say max 45.. min 35.
csouth
07-24-2017, 11:26 AM
I don't know about those HP specs either. That's a relatively mild cam and no mention of aftermarket heads.
killersingh
07-26-2017, 12:10 PM
Thx everyone for input cost 36k usd
