Motown 454
07-16-2017, 05:27 PM
Hi guy need to ask a question. My headers which are already coated and on the car are interfering with my transmission connection to the cable for the shifter. I've been thinking of all kinds of fixes, changing the range shift selector rod to a short one which the valve body has to be lowered to remove a nail which holds it in. ( Not in my range of abilities). Then having a new shift lever made, (which I'm not opposed to)
Then the question Hot Rod fix or HACK
I thought of this a while ago while dealing with my oil cooler lines. space the header out at the head, hear me out!! I could get a header flange and longer, better bolts from ARP and put the flange between the head and the original header flange with RTV or what ever would be best to seal then together and the gasket between the head and header. This would also solve my heat and space problem for the oil cooler lines.
Here is the shifter problem
https://static1.pt-content.com/images/pt/2017/07/oOjOW6-1.jpg (https://imageshack.com/i/pooOjOW6j)
Here is with the header flange spaced a little over a 1/4"
https://static1.pt-content.com/images/pt/2017/07/C3ZOnF-1.jpg (https://imageshack.com/i/poC3ZOnFj)
Here it's about 7/16" spaced
https://static1.pt-content.com/images/pt/2017/07/jkrXyQ-1.jpg (https://imageshack.com/i/pmjkrXyQj)
how close the oil line were, they're tighter than they look.
https://static1.pt-content.com/images/pt/2017/07/75Cwri-1.jpg (https://imageshack.com/i/pm75Cwrij)
And with the header spaced out.
https://static1.pt-content.com/images/pt/2017/07/fd8opn-1.jpg (https://imageshack.com/i/pmfd8opnj)
What do you think?
What do you think?
