View Full Version : 70 Camaro Pro Touring & Track Day
michics
06-10-2017, 11:25 AM
Car is no longer available.
New Price Reduced to $32,995. Spring is coming I'm motivated to move it. Next project is in the garage.
Rockford, Illinois
The car came from south Georgia and previously South Carolina. Car has spent it’s life in the south and the body is straight and rust free. This car is very solid and as you can see has many quality parts. Car is sorted out and everything works as it should. I'm going another direction with my car hobby so this one needs to go. Well built car for the price.
E-mail me at [email protected] for more pictures.
If you want to discuss call me @ 815-312-8353
406 SBC- original Chevy block
9.1 compression ratio
Lunati Rotating assembly -internal balance
Professional Products Harmonic balancer
Splayed main bearing caps
AFR cylinder heads- 195
Comp Cams Xtreme Energy Cam w/ Lift of I 502 E 510, Duration @.050 I 224 E 230, LSA 110 deg Hyd/Roller
Cower Hyd/Roller Lifers & 1:7 rockers
MSD Distributor
Aluminum water pump
Power Master High torque starter
Edelbrock Air gap intake with new Demon cfm carburetor
Black wrinkle valve covers
New K&N filter setup
BeCool Aluminum radiator with dual electric fans
3" Stainless exhaust , Magnaflows dumped in front of rear axle
DynaTech headers
LT1 /T56 Transmission
Mcleod billet flywheel with clutch & pressure plate
DSE power steering pump w/ remote reservoir
Hydraulic clutch
Custom Aluminum driveshaft
Ford 9" from Strange, Moser 4.11 gear center section with Posi, 35 spline axles
Ricks Stainless Sumped tank, Aeromotive A1000 with 10 and 100 micron filters
All black braided -10 to carb, -8 return
No A/C or Heat
Mini tubbed
Subframe is connected and welded with 3x4 tubing all the way to back bumper, basically a full frame car now
Wilwood 4 piston brakes with Wilwood master cylinder
Original split bumper
Complete AAW wiring kit
Anvil Auto Carbon Fiber parts:
-Power Bulge hood
-Deck lid
-Center Spoiler section
-dash panel
-filler panel
-core support closeout
-Front inner fenders
-tail lights
Fesler:
-Hood Hinges
-strikers
-halogen head lights
-jamb vents
-core support braces
-Hood adjusters
new door handles
All chrome fits great
INTERIOR:
new carpet
billet shifter with black leather boot
4 point harness
Aftermarket seats from Summit, front rear covered in custom leather
4 point cage installed when I got it. All attachment points are plated and welded
new door handles and trim plates
Carbon dash panel with Autometer Speedo, tach, oil, water temp, volt, oil temp
New dash pad, New sun visors
Dash is complete with all the original vents
Momo steering wheel with billet adaptor
Tilt column
Pioneer CD, (2) 6" 3 way in the doors, and (2) 6x9 in rear package tray, 200 watt amp
Power Windows , switches under headlight knob
Remote battery in pass trunk, with main shutoff switch
Suspension
BMR upper and lower front arms
BMR rear torque arm, with welded brackets on rear end
AFCO remote reservoir triple adjustable shocks setup
BMR watts link
BMR trans X-member
Tires and wheel
Formula 43 RAD S5's
18x9 front with 255/35 18
18x12 rear 335/30 18
Toyo R888’s
michics
06-13-2017, 04:26 PM
Delete
BMR Sales
06-14-2017, 08:01 AM
that's a shame, you haven't had it very long. GLWTS
michics
08-08-2017, 04:45 PM
New pictures added. Heading a new direction so it needs to move.
Peter Mc Mahon
08-09-2017, 03:20 AM
That looks like a great deal. Good luck with the sale
michics
08-27-2017, 03:23 PM
Still available. Motivated seller.
michics
09-23-2017, 05:23 AM
This is a very good car for the money. Still available and I'd like to move it before winter. Lets talk.
michics
10-11-2017, 04:16 PM
Bump
michics
12-10-2017, 05:41 PM
Bump with price reduction.
Bob in St. Louis
12-11-2017, 05:19 AM
Wow, that's a SUPER nice car. Great price too!
michics
01-21-2018, 04:48 PM
Bump
michics
02-23-2018, 02:20 PM
Note new price reduction. Next project is in the garage.
~STOLEN~
03-21-2018, 11:48 AM
its a shame you dont want to trade i have a 07 z06 with 55k on it and a lingenfelter top end (3500mi on top end) made 6XXna on a mustang dyno
your car is amazing, close to where i wanna end up with my next car to cruise and have a blast in
michics
04-22-2018, 04:15 AM
Car is no longer available. Trying different marketing approach.
