View Full Version : LS2 Crank Position sensor P0335 no start
csouth
05-30-2017, 08:56 PM
I'm getting a P0335 on my motor that i had running in the past, but no will not start. I did remove my harness and reconnect it when i brought the ECU inside the car. I'm wondering if something happened to the connector? I want to check the voltage which i read should be 5v for a 58x motor? Do I need to check in the key on position or during cranking? Right now no RPM's are registering in HPtuners. Any feedback is greatly appreciated.
12sec ss
05-31-2017, 12:41 PM
sounds like you didnt reconnect the plug to the crank sensor behind the starter.
csouth
05-31-2017, 01:29 PM
Plug is connected that's why I now need to check the voltage at the connector.
csouth
05-31-2017, 08:54 PM
I think I found the issue
https://static1.pt-content.com/images/pt/2017/06/4EA3F0F1983C47A4A468C4BAD15E6624_zps4613-1.jpg (http://s897.photobucket.com/user/csouth89/media/delilah/4EA3F0F1-983C-47A4-A468-C4BAD15E6624_zps4613oc2f.jpg.html)
