View Full Version : 69 Camaro Suspension Question - Will this combo work
mtm87tx
05-22-2017, 10:03 PM
Gents,
I am trying to figure out my suspension as i have got the what i call "two thousand dollar yourself to death" bug on this build.
Long story short, I added about 50 more HP to my 427 big block and the factory 6cyl 10 bolt didnt like that very much with a 275 tire. So i ordered a Moser Engineering 12 bolt (yes i know 9" conversions work but something about keeping it GM i like)
Here is what I have:
Front:
Spindles: Stock
Control Arms: Unknown Tubular
Springs: 6cyl with spacer (no i didnt do this)
Shocks: Factory style replacement
Sway Bar: 1"
Rear:
Rear End: 10 Bolt
Springs: Mono Leaf
Shocks: Monrow Air Shock
Sway Bar: None
Here is what I want to do:
Front:
Spindles: CPP C5 Hub with ridetech true turn (i want to get a 9-9.5" wheel with a 265/35/18)
Control Arms: Keep Current tubular for now
Springs: Viking 650#
Shocks: Viking Hybrid Coilovers from Speedtech
Sway Bar: 1" for now
Rear:
Rear End: 12 Bolt Moser (3.55 33 spline Truetrac)
Springs: Speedtech Torque arm or Chasis works G-bar (cant decide)
Shocks: Matching single adjustable coil overs
Sway Bar: None
Comments:
I plan to mini tub the car at a later date
I cant currently afford a full front subframe
I will be running Wilwood brakes on all 4 corners
Advise comments or concerns? Any help is greatly appreciated
BMR Sales
05-23-2017, 07:42 AM
It's going to cost more than $2,000
Show us the Tubular A-Arms that you already have - if they are Chinese, I will tell you to replace those
650lb Spring is too much for the front
Why wouldn't you want a ViKing Double Adjustable Coilover for the Rear to match the Front?
mtm87tx
05-23-2017, 09:00 AM
Yes what I meant by my comment was everytime i turn around its another 2 thousand here and there. I know im going to be in the 10k range with brakes and rear end.
I will send a picture of the A arms and I agree with your recommendation I just need to get the wheel off so i can see what I am working with.
You think 650 is too much for a iron block and head big block?
The vikings are double adjustable you are correct
Thank you for the support.
