View Full Version : PCV Routing
robby8388
04-28-2017, 02:52 PM
I spent the last hour searching this website and the internet and I think I'm more confused now than I was when I started. Basically where should the tube I'm pointing to with the screwdriver be hooked to? Somewhere on the air intake between the air filter and throttle body?
Also, my rear drivers side port is capped. Is that correct?
its for a LS3
https://static1.pt-content.com/images/pt/2017/04/IMG_7258_zpsobmxr2vb-1.jpg (http://s86.photobucket.com/user/Robert_Padron/media/IMG_7258_zpsobmxr2vb.jpg.html)
dhutton
04-28-2017, 03:36 PM
You tee the two valve cover ports together and then connect them to a port you add to your intake tube between the MAF and throttle body. That way the fresh air is metered by the MAF.
Don
jwcarguy
04-29-2017, 09:28 AM
That port goes to the air intake tube (after maf, as mentioned) or throttle body port (if one exists , on a DBC TB, but yours is a DBW TB, so would be air intake tube)
see pics
hope this helps
Jeff
Peter Mc Mahon
04-29-2017, 10:44 AM
What is that last picture of? Off road buggy?
jwcarguy
04-29-2017, 11:11 AM
Peter,
Yes, that a pic of our new Desert Dynamics dual sport sand rail, that I just finished building
Thanks, Jeff
robby8388
04-29-2017, 11:50 AM
I got it all put in today. Thanks for the advice!
Those are definitely some nice rides you have there!
