    Results 1 to 9 of 9
      Oct 2015
      Western Mass
      '69 Camaro Dash Insert & Gauges
      My interior is progressing, got the MOMO D36 installed, I love it.
      Now I'm focusing on the dash, because the OEM dash doesn't do justice to that wheel LOL. I photoshopped the dash insert I bought, now I'm trying to decide whether to pull the trigger on New Vintage or Dakota Digitals. I really like the center swing NVU gauges more than the DD who still haven't released a 270-degree center swing HDX or VHX setup. I'm trying to figure out how to deal with all the auxiliary lights (directionals, emergency brake, high beam, ignition, etc.) so thats what the LEDs are.
      So here's the same insert with Dakota Digital's only available universal 6-gauge cluster.
      Seems like a lot of empty space in the bezel and the small gauges especially. What do you guys think?
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
      Jacksonville, FL
      I have had the VHX and now have the HDX. I personally like the HDXs so much more the than the VHXs. not that the VHXs are bad, but you have so many more options with the HDXs. If you went with the DD ones (either one), you will not have to have all of those extra lights such as your turn signals, high beam and CEL as they are built in. Both versions of the DDs allow you to set warning parameters for each one. If you are using an OBD 2 compatible pcm, you can take most of the engine readings directly off of the PCK through their BIM-modules. The displays on the HDXs are better with the larger LCDs and you can change the colors of the needle and gauge backlighting. I just used their iPhone app that allows you to program it via Bluetooth (on HDX only). If you are wanting a retro 69 look, the New Vintage but will I think the HDXs take it upon to the next level depends on your car's look.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Oct 2015
      Western Mass
      Quote Originally Posted by 130fe View Post
      I'm already committed to the 6-gauge insert, and when I talked to DD, they said no immediate plans to release a 6-gauge universal set with 4-1/2" speedo/tach, 2-1/16" oil, fuel, amps, water. So the only DD option is the VHX pictured above. I don't have a OBD II as this is a old school carbureted 454, and that will never change. I've been nagging DD for almost a year, they say "someday" for the universal set. That doesn't fit my schedule. There's also Speed Hut, Autometer, and other options.
      That's my car... other changes coming are RS grill, 17" or 18" wheels, Vintage Air. And the gauge cluster.
      Oct 2015
      Western Mass
      Dug a little more, found that New Vintage also has this setup. Kinda like the blue in it since the car is blue.
      Still wondering about the idiot light hookup.
      Dec 2012
      Oldtimer, I like this .. looks slick
      I know it's kind of pricey but have you considered the DSE dash, I love your design but I'm not a fan of carbon unless your going to have it throughout the car consistently.
      With what you've pictured above with those switches etc. on a satin black DSE dash would be extremely nice
      Cheers
      Steve
      Build it right ... 'The 2nd Time !!'
      69' SS/RS X11 PRO-TOURING E-Force LS7 - SOLD
      2 Custom FJ40's -SOLD
      77' 911 Hotrod - SOLD
      'Killer Piggy' 73 FJ55
      67 Camaro - TBD
      Jacksonville, FL
      The DSE setup looks really good in 69s. When you are talking about the warning lights, you can use the stock harness wiring you already have in the car (assuming it is in good working order). They are easy to hook up, 2 wires- a ground and pos (trigger) wire. I have used similar ones in the past for turns signals and such. Just look for some built in resistor 12v led lights or just normal 12v indicator lights. Here is a cool example of a a turn signal and high beam-
      https://www.denniskirk.com/407359.sk...ad=45713335117
      https://www.denniskirk.com/drag-spec...prd/407358.sku
      Chris
      Oct 2015
      Western Mass
      Quote Originally Posted by sheck44 View Post
      Cheers
      Steve
      Steve... Thanks for the props, I already have the CF dash insert and yes, I am going to go with more carbon fiber in the interior to try and tie it all together.
      Chris... Definitely bookmarking that site. I saw some similar LED indicators on Bitchin'Rides, they had a bank of them with either billet or SS trim. I was also toying with the idea of designing and building a custom backlit billet housing that would fasten to the steering column but be flush against the dash bezel. I know a crackerjack machinist who might mill it out for me if I give him a good drawing.
      I have to search threads to see what others have done with aftermarket dash inserts and idiot lights.
      Dec 2012
      Excellent, I look forward to seeing the final product
      Chris, thanks for the heads up on those flashers, those are cool !
      Cheers
      Steve
      67 Camaro - TBD
      Oct 2015
      Western Mass
      Found one source so far for the warning lights... but its in the UK. Not a huge problem, but I'd prefer to find someone selling these here in the states.
      I'd like to get four (4) indicators; Emergency Brake, Oil Pressure Low, Water Temp High, and Ignition/battery.
      Went with SpeedHut... very nice people to work with. Gave them the artwork for the Camaro script and the redline and they did a great job. Got to decide where the Oil Pressure sender will tap into. Right now I have a real poly oil line to my current SunPro gauges. The connection is just forward of the top of the oil filter. My intake blocks the port by the distributor, but theres another port on the block just behind where the PS pump is. Hopefully get this installed this week. Waiting on new headlight switch and wiper switch plus new vent. I'll pull the dash again when I do the Vintage Air... that should be here in 10 days along with my RS grill!
