View Full Version : Ecm wiring through fire wall?
Omgbigdeal
03-07-2017, 11:30 AM
I have a 1979 trans am getting an ls2. My question is my wire harness was made to run inside the car. It is on the passenger side it says to cut a 2" hole to run the wires. I may be blind but I'm having a hard time locating a good spot to run the harness. Does anyone have any insight ?
teroy
amargari
03-07-2017, 05:14 PM
You can hide it by putting the hole in the side of the trans tunnel
408maro
03-07-2017, 05:35 PM
That's a good idea. I wish I would have done that mines not so clean but works...
I just made a hole on the firewall.
https://static1.pt-content.com/images/pt/2017/03/20161218_155315_zpsrj6or4os-1.jpg (http://s296.photobucket.com/user/408maro1/media/20161218_155315_zpsrj6or4os.jpg.html)
https://static1.pt-content.com/images/pt/2017/03/20161221_135712_zpsbjqnnvjk-1.jpg (http://s296.photobucket.com/user/408maro1/media/20161221_135712_zpsbjqnnvjk.jpg.html)
Omgbigdeal
03-07-2017, 10:57 PM
Good ideas I'm gonna look into the tunnel spot I suppose the ecm can be hidden under the dash als. Any pictures of the tunnel hole?
raustinss
03-08-2017, 03:55 AM
Hell of a lot of work and not sure what your budget is but some guys have cut the harness and added a mil spec connector
Build-It-Break-It
03-08-2017, 06:37 PM
I found some mil spec type connectors I'm going to run on my car. Better price and uses a "standard" style crimper. http://paradiseracing.com/?post_type=product&s=Bulkhead
raustinss
03-08-2017, 07:15 PM
Yeah just like those ...run one in the tranny tunnel and then whenever you need to do work ...ie detail engine bay, swap motor etc the harness is a easily removed
DT69Cam
03-17-2017, 06:30 AM
I would also like to use a bulkhead connector for my GMPP harness which hasn't arrived yet. Which connector have you guys used ??? How many pins are needed ?? I heard that cutting the harness will cause problems with the ECM ?? Anyone know if this is actually true ???
dontlifttoshift
03-17-2017, 02:39 PM
It will only damage the ecm if you screw it up. I was using the the Molex XRC 31 pin connectors but have switched over to the Delphi HES 47 pin connectors. Mouser and Waytek have both. I spent a boatload of money on crimpers, though.
Twentyover
03-18-2017, 12:44 PM
Why did you switch from the Molex to Delphi? What kind of crimpers are you using? Thanks- I'm about ready to start wiring an old OBD1 system, probably switching to Megasquirt
amargari
03-18-2017, 03:44 PM
Sorry, I looked through my site and I don't have clear pictures. It was on the left side near the firewall at about the 2:00 position if you think of the tunnel as a clock with 12:00 top dead center.
dontlifttoshift
03-19-2017, 08:50 AM
The Molex really only come in one size, the Delphi has several options. Also, the 47 pin means getting a LS harness in 2 connectors instead of three. There wasn't a huge difference in money between the two but the Delphi gives us more options. Some sizes can carry 12 ga wire and 40 amps.
I have the Molex branded crimper and bought a Rennsteig and several die sets to do the Delphi.....all from Waytek. If you are careful they both can be crimped with weather pack style, non ratcheting, one step at a time crimpers. We do enough of these that it wasn't worth the time to not have the right crimpers.
Twentyover
03-19-2017, 01:40 PM
Thanks dontlift.
I'll take a look at Wytek's catalog and see what I can afford. I like the ideaof being able to unscrew a single conector or two and being able to take the entire engine wiring harness out with the engine, not needing to jack around with 20 separate connections
